Hi Kurt, I did try that also. The volume is all the way up. So frustrating. I've had this tv for years and was just watching it in the morning. Then when I got home and turned it back on I messed something up.
SOURCE: Hughes Remote works the satellite but not the TV
You have to push and hold down TV and Mute button (for 2 seconds at the same time), then release them at the same time, then push channel up until the TV turns off. Be patient and continue channel up until the TV turns off. When it turns off, then push TV again to lock the code.
You were doing fine, but missed to push channel up to fine the code.
SOURCE: Remote volume control for Sharp Aquos 42inch LCD not working
User 'rapolley' is absolutely right. One can cycle through the functions to access different options, ie. 'TV', 'Audio', 'DVD', etc. I stumbled upon this solution when I thought my 'Menu' button wasn't working. All I had to do is cycle through the 'Functions' and choose 'Menu' once I get to 'TV'. Thanks!
SOURCE: Sharp Aquos 32"
TV is under warranty. Get a tech to look at it. It could require a new IR sensor, a firmware upgrade or a system reset that only a tech can do called an Industry Initialization that is in the service mode only
SOURCE: X2Gen MV37R Flat Panel TV Sound & Universal Remote
I also have the issue with the sound out of sync highly annoying...is this an HDMI issue?
SOURCE: Brand new LC 42D65U
Sounds like your powerboard, take it back or call tech for replacement, dont settle for this, you paid good money for a working tv
