Question about Car Audio & Video
Why everytime i open the stereo of super grandia i always press and hold the + in the screen?how to save the settings i did?
Posted by Jayson Bernalez on
2 Related Answers
Anonymous
  • 377 Answers
SOURCE: A105
There was a hardware failure / problem on your laptop. If I'm not mistaken it's probably on the Memory Module.
Thanks,
Posted on Mar 01, 2008
AndrexT
Andrew Taylor
  • 34047 Answers
SOURCE: how to reset check engine light of 2015 toyota super grandia.
First you need to check the code which tells you what the fault with the engine is. It would be foolhardy to just cancel it. The code reader is also the piece of equipment to cancel it. Your local garage will normally tell you what is wrong with it for free in the hope they get the business.
Here is a list of all the things it is telling you that could be wrong.
http://www.obd-codes.com/trouble_codes/toyota
Posted on Jul 17, 2016
How to set time
Press and hold SEL until menu appears Using the scan button (FWD/REV), select Clock H Using the volume knob, set the value
Using the scan button (FWD/REV), select Clock M Using the volume knob, set the value Press SEL to save and exit
Jun 13, 2014 | JVC AM FM CD DET FACE CAR STEREO
Snes no sound
Installation steps:
These steps work for Wii, Nintendo GameCube, Nintendo 64, and Super NES hookups.
Gently pull the yellow cable of the Stereo AV cable apart from the two Audio cables (red & white). Plug the yellow cable into the Video Input on the TV or VCR.
Locate an open set of Audio inputs (left & right) on your home stereo. Do NOT use inputs marked "Phono."
Plug the white cable into the Audio Left input on your home stereo. Plug the red cable into the Audio Right input on your home stereo.
Set the input select on the stereo system to match the label on the set of audio inputs. (For example, if you plugged the Audio cables into the AUX port, switch the stereo to AUX or "auxilliary."
Make sure the game is placed properly in the system.
Plug the controller(s) into the front of the Control Deck using the left most port for player one.
Plug the AC Adapter into the back of the system. Plug the other end into a wall outlet.
Turn the power on.
Turn on the TV or VCR and locate the input select. It's often called Input Select, AUX (auxilary), Line, Line In, Input, Source, Select, In, or EXT (external. Switch the input select to show the Nintendo game.
Note: If you are using a VCR, you will need to set the VCR's TV/VCR button to VCR. You can do this by putting a movie in the VCR, pressing play, then pressing stop.
The game image should now be displayed on the screen. You're ready to play.
Dec 31, 2012 | Nintendo Super NES Console
No video or sound
External Speakers
Installation steps:
Turn the power on.
Dec 27, 2011 | Nintendo Super NES Console
Samsung.. don't know how to take/send pictures
1. From the Home screen, press and hold the Camera Key on the right side of the phone.
Tip: The Camera always opens in landscape mode. While taking pictures,
use the external command keys, or the QWERTY command keys.
2. Set Options, if desired.
3. Using the display screen as a viewfinder, compose your
picture by aiming the lens at your subject.
4. Press the Camera Key or the Center Select Key TAKE to take the picture.
Tip: Open the phone immediately after taking a photo to resize the photo and
create a new picture message with the new photo attached.
5. After taking a photo, use the soft keys for these options:
• Press the Right Soft Key Erase to delete the new photo.
• Press the Center Select Key SEND to resize the new photo
and attach it to a new picture message.
• Press the Left Soft Key Save to save the picture to My
Pictures.
Mar 19, 2011 | Samsung Intensity II U460 Verizon
Computer doesn't start normally. Hangs everytime.
your battery is dead change the battery the bios is not saving your setting due to battery and popping up to find hard drive again it is using the defaults settings
May 07, 2009 | Dell Dimension 3100 PC Desktop
How to set the clock on Pioneer car stereo Super Tuner 3D
ok what u do is turn radio off hit clock so that it displays the time then hold audio button in until clock starts flashing then use your arrow ****. not your vol. ****.
Mar 04, 2009 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
How to set the clock on my car stereo
With cd player off, press and hold the funciton button I think that gets you in. I remember th stereo, but can't remember exactly how off the top of my head. Now, if you were here in pwerson, no problem lol!
Jan 27, 2009 | Car Audio & Video
Cant set the clock on my Wharfedale ip76 stereo.
Hold down iPod/MEM/C-ADJ till it flash's 24 Hours, choose between 24 & 12 hour clock, press MEM again to move onto hours, MEM again for minutes, MEM again to save the time
Nov 15, 2008 | Wharfedale Open Box WH-LOUDM-LIM LOUDMAN...
Clock
CLOCK SETTING
1)TURN CAR IGINITION "ON"
2)TURN STEREO "OFF"
3)PRESS "AUDIO" AND HOLD TILL CLOCK APPEARS IN DISPLAY
4)SET CLOCK BY PRESSING UP,DOWN & LEFT, RIGHT KEYS SITUATED NEAR SRC/AUDIO SWITCH.
5)TURN THE STEREO "OFF" AND "ON" AGAIN TO SAVE THE CLOCK SETTINGS .
6)SELECT THE "CLK " SWITCH TO ALWAYS DISPLAY CLOCK WHENEVER U ARE NOT LISTENING TO MUSIC.
Oct 23, 2008 | Pioneer DEH-2800MP CD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
