SOURCE: HDTV Rear Projection
The color wheel is the most common problem when it comes to noise from DLP's. To determine if it is a color wheel or fan: Turn on the set. When the noise starts, turn off the set. If the noise goes away within 5 seconds, then the color wheel is bad. If the noise goes away after one to one and a half minutes after the set was shut off, then one of the fans are making the noise.
SOURCE: fixing a Kenwood KD 491F turntable
The reason why the audio is low, is that todays receivers do not have a phono input, and these types of inputs are differant then the ones of today. You will need whats called a phono preamp, and one should still be available from Radio shack. Or you can go here to find out more about them: http://www.phonopreamps.com/ To reseat the belt, take off the rubber mat on the turntabe disc. Install the belt around the inside ridge, there should be a couple of holes on the platter disc. Install the patter back onto the center spindle. Turn the platter around till you see the motor pully through one of the holes in the platter. Take the belt that is around the turntable platter, and pull it over to the motor pulley. Good Luck
SOURCE: JVC KD-85 Cassette Deck Stops in Seconds in play, REW., & FF
Hineovision1
The deck will need new belts and idler drives cleaned and serviced, and perhaps some idler tyres replaced. You can get a belt kit from these guys. replacing them is not such a difficult job if you have some mechanical aptitude. Just take it slowly, and focus on getting the transport out of the unit.
I am more than happy to answer any other questions you may have aboutit, please get back to me here, or use the ASK function to go straightto me :) If you are still unsure, have problems, or we need to look atthe situation more deeply, then before you give a rating for thisadvice, hit the ASK buttonThanks for using FixYa, If you consider the advice I have given you assound, a FixYa rating is a great reward for my efforts to help you.Cheers.
regards
robotek
SOURCE: PUT ON BLET
The belt normally wraps around the bottom of the metal platter. Put the
platter back on the turntable, and you'll see holes on opposite sides
of the patter. Just pinch the belt out a little, and wrap around the
motor shaft - should be a brass shaft assembly.
- OPTiC
Turntable Repair Expert
Digital Analog Therapy
SOURCE: motor sounds loud and high pitched
most likely your bearings are shot. it will need a new motor
