Question about Hardware & Accessories
Hi, is there a way to reset my GE-15132 timer to factory default?
Posted by Tom Emfinger on
Vincent Migliore
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 36 Answers
Remove the internal battery for at least five minutes. The capacitors will drain and default to factory settings when you put it back.
Posted on Apr 09, 2019
5 Related Answers
Anonymous
SOURCE: How to reset WD My Book World Edition to factory defaults?
Unplug power. Hold reset button. Plug in power while holding reset. Wait until light flashes, then release reset button.
Posted on Sep 14, 2008
Anonymous
  • 4 Answers
SOURCE: How can I load factory defaults??
I don't know about factory defaults but there is a Firmware UpDate v 2.4.0
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/dlf/000000/002800/dlf002854.html?reg=us&c=us&lang=en&prod=mfc640cw_all&type2=4&os=7&flang=4&dlid=dlf002854&dispforlist=1
give it a try ...hope this works kiddrock
Posted on Feb 14, 2009
Joe Hogan
  • 10865 Answers
SOURCE: GE Digital Time Switch (15132) for basic landscape lighting
Leave the breaker off, remove the wires from the timer and just connect them. then turn the power on. Unless you have a short somewhere, the lights should come on. What you have just done is made the breaker your switch. If the breaker kicks you know to keep looking for a short as it is not the timer. Regards, Joe
Posted on Jan 13, 2010
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: hi i need to reset my rvx 1000 to factory
Page 42 or 69:
"To reset all of the parameters to the factory-set values
Use "9 PARAM.INI" on the SET MENU to reset all of the parameter values of all DSP programs within the selected group to the factory-set values (see page 42)..."
Posted on Feb 10, 2010
Anonymous
SOURCE: Trying to install GE 15132 Digital Timer - for use
Voltage is not given.
Open following link for illustrations:
http://waterheatertimer.org/How-to-wire-GE-15132-timer.html
Posted on Oct 05, 2011
My GE timer, model 15132 has stopped working. I can see that resistor R2 on the circuit board has fried (it's black). Anyone know the value of this resistor?
Usually if you look close, several parts have burn or blackened area at point of solder.
This indicates that multiple parts are affected... replace timer.
Otherwise, there is no schematic for these types of digital timers that shows the value of parts.
Following resources have images of similar problem, and similar timers.
http://waterheatertimer.org/Timer-caught-fire.html#resistor
http://waterheatertimer.org/Boxtype.html
http://waterheatertimer.org/How-to-wire-GM40-timer.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 10, 2015 | GE Hardware & Accessories
Does the Defiant Daylight Adjusting Indoor Digital Timer also uses a battery?
No battery.
This single-pole or 3-way, programmable or dawn-dusk timer is same as GE 15312 sun smart timer, and requires a neutral wire to power the electronics.
GE renamed all their wall timers, or sold their timer business to Defiant in year 2013-4.
http://waterheatertimer.org/Programmable.html#15132
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
If you want a timer with same capabilities, that uses a battery, and does not require neutral wire, then choose Intermatic ST01 or Ei600 timer
http://waterheatertimer.org/Programmable.html#st01
Gene
Dec 05, 2014 | Hardware & Accessories
The display has gone blank on T1033 . the only way to get towel rack to work is by pressing the on/off selector
1) Try resetting timer. Aube/Honeywell TI033 7-day 2400watt timer cannot be exposed to temperatures below freezing, even though manual says -5 F. High temperature range is 122 F .
This timer has 3-year limited warranty. Internal battery is non-replaceable.
http://waterheatertimer.org/Aube-timers-and-manuals.html
2) There is no other programmable in-wall timer that can handle 2400 watts without using contactor.
3) Replace with GE 15132 timer for cold environments, and single-pole or 3-way operation: Use contactor for heavy loads.
http://waterheatertimer.org/images/Dawn-dusk-120Volt-pump22-28.jpg
4) Add comment as needed
Dec 28, 2012 | Hardware & Accessories
No digital display on my ge 15132 timer
Reset timer and reprogram.
If functionality is not restored, then timer has gone bad.
GE15132 digital timer from Home Depot has 1 year limited warranty.
Digital timers do not have replacement parts, and are susceptible to power surge such as simple power outage.
Buy new timer at Home Depot, and return defect timer in new package for refund.
Oct 10, 2012 | Hardware & Accessories
How to ground a Tork EW103B time switch wired for 240Volt since there is no ground lug in the plastic housing or on the body of the timer itself
Many plastic timer enclosures do not have ground screw.
Simply join the ground wires inside wiring space using wire nut.
http://waterheatertimer.org/Tork-Digital-timers-and-manuals.html#ew
Since the timer mechanism is plastic, it is non-conductive.
It's like using all-plastic electric drill. The drill does not have ground wire because the electrical components are housed completely in non-conductive plastic.
You can buy the Tork 9000A metal Nema3R enclosure if grounding is preferred. Or buy Intermatic 2T511GA metal Nema3R enclosure plus buy Tork IAP adapter to fit Intermatic enclosures.
Choose the metal enclosures when conduit needs to be supported and timer could be hit by some object.
The non-grounded box and non-grounded timer is also true of GE digital timers 15132 and 15136. Which coincidentally have same wiring as EW103 when using 240Volt.
However the Tork DTU40 timer has ground screw >>> but the timer is not grounded, so ground screw is merely for joining wires together.
http://waterheatertimer.org/images/IMG_2232-Tork-DTU-timer-600.jpg
Jul 31, 2012 | TORK Hardware & Accessories
My GE 15132 was operating fine for a year but now is losing time..the clock runs about 4 hours a day slow...I am resetting it once or twice a day....what could be wrong??
Contact Jasco and tell them what you said here.
http://www.jascoproducts.com/contactus/index.asp
Although GE has made high-quality timers for many years, the 15000 series box timers have been on the mass market for a year or so, and there are no replacement parts like available for Intermatic timers.
http://waterheatertimer.org/GE-timers-and-manuals.html
I tested the GE series and found them to be cheaply made with moveable plastic parts and lightweight overall.
http://waterheatertimer.org/GE-15207-clock.html
Jun 24, 2011 | General Electric GE 56941 24-Hour Outdoor...
I have a ge timer 15132 and it is wired up properly feed to screw 1 and 2 , jumper from hot to com, load to no contact and the neutral tied with the other from the feed, all the time are set proper and the...
I have tested this timer.
GE 15132 timer can be wired muliple ways to accommodate different voltages and many different timing needs.
1) First thing is you must set dip switches BEFORE applying power.
Timer arrives pre-set for 277Volts.
For 120V, set all 4 dip switches to the left, or ON.
2) Otherwise your wiring sounds correct.
Hot black wire to far left 'clock' terminal.
Neutral white wire to next 'clock' terminal.
Jumper from Hot terminal to COM terminal.
Black Load wire on NO terminal.
White Load wire to same 'clock' terminal as Neutral
3) Possible solution:
Move wires to COM2 and NO2 and see if that relay is working.
4) Make sure your programming does not have conflicts.
See if manual override is working.
Test for voltage across 'clock' terminals
Move manual override and watch if relay clicks open-closed.
Check that Load is operable by moving NO wire to COM terminal.
5) If timer is not functioning, exchange at Home Depot.
You can switch out mechanism without replacing box.
Mechanism is held with hex screws.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 22, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
Quisiera saber biem como se conerta ,en 120 v el digital interruptor horario ge 15132
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/15132-Manual-spn.pdf
Estoy usando traductor Google.
http://translate.google.com/
Por encima se enlazan con 15.132 manuales en espa?ol.
Me escribi? una p?gina web sobre el temporizador de GE 15132.
Las p?ginas se muestra el cableado.
Sin embargo, las instrucciones est?n en Ingl?s.
Utilice traductor Google para ayudarle a entender las instrucciones de p?gina web.
A?ade un comentario en el fondo, si puedo ayudar m?s.
Nov 07, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Jan 04, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Hardware & Accessories Logo
153 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
