Car Audio & Video Logo
Question about Alpine Car Audio & Video
I have an alpine 6 disc cd auto changer fitted to my 2005 Jaguar XJ6 and the cassette will not eject.
Posted by michael hooper on
1helpful
I just recently purchased a 2002 Toyota Avalon and the built in 6 disc CD changer won't eject or load CD's and the cassette tape player will play for a bit and then eject the tape
The equipment (front end unit and the CD changer) are too old. Cassette tape players life isn't usually any longer than this. I would replace the front end unit (receiver) by shopping for one that fits (the dash). Bypass or forget about the CD changer in the trunk because a new CD player is on all new front end units. I would recommend a shop like Best buy to select one and especially to install it; unless you know how to install one.
1helpful
Jaguar 6 disc player not working
If you are getting power to the unit and you hear it clicking and making a sound when you hit the eject button, the this means that a CD is jammed in the track and while it was changing it got stuck and now causes you to see an ERROR message.
What you do is while hitting the eject button, wiggle the CD MAGAZINE up and down and side ways. This will cause the CD to fall into place and your magazine will pop out.
KennyV
6 disc, will not eject or play cd's
Try tapping on the changer. Sometimes a gear gets stuck inside the changer and tapping on the changer frees the gear.
Hello i have a bmw with a 6 cd auto changer fitted in the boot i think its a factory installed alpine , but it skips when the car goes over a small bump . ive been told the laser has been damaged by...
Copied cd's can't damage this part. The pick-up of this changer can't be repaired, it should be replaced as a whole part. Also please check a position anti-shock system (two mechanical parts on sides of the unit). It must be set in the same position as the changer is installed.
CHM-S630 6-Disc CD Changer: what is the best 6 disk cd player to connect to an...
hi how are you , my cd changer s630 recently just started to eject the whole cartreidge i push it back and its makes some nosies and then the same ejects it
5helpful
Cd changer magazine does not eject
good day, you may want to do it manually if its jammed, you may find a pinhole on it and u can use a paperclip, insert it in the hole and it will open. hopefully it wont jam again. hope this helps, have a nice day
2helpful
Manual retrieval of a CD from an Alpine S620 CD Changer
Sorry but no. With the units power lead fused, you can hold the red wire to the + terminal of the battery and the black lead to the chassis of the car and power up and eject. good luck
1helpful
''CDDJ ERROR'' WHEN ATTEMPTING TO PLAY VIA ALPINE CHANGER
My local Lincoln Dealership wanted to dismount the actual Clarion CD changer (I thought, and unfortunately reported to you, that the CD changer manufacturer was the same as the radio/cassettee unit that is installed in my dash, Alpine) from my 99 Town Car and ship the unit out for repair for a minimum of $130.00. Instead, I went to a local Radio Shack franchise who installs/repairs car electronic audio/video systems and they: dismounted the unit from the trunk; took the dismounted unit to their workbench; removed all the housing, etc. and finally were able to manually extract the fully populated 6 CD magazine stuck within the CD changer. Additional efforts (including inserting my spare magazine into the CD changer while it was on the tech's work bench) to determine exactly why the magazine would not eject while the unit was connected via the cabling to the car's power, etc. were not productive. So I now have a totally unassembled non-functioning CD changer on my hands. The "CDEJ Error" on the LED area in the dash when the eject buttoon on the CD changer is pushed.still persists. The technician said that it would be a waste of his time and my money to re-assemble the parts of the CD changer. He believes that the motor on the unit has been burned up.
So I am now checking with all the local auto parts salvage yards (we used to call them junk yards) to see if anyone has a usable Clarion CD changer for a 1999 Lincoln Town Car available that would be plug compatible with my existing Alpine factory installed Premium CD/Cassette audio system and the former factory installed trunk mounted Clarion CD changer. The Radio Shack franchise technician has already checked with the Clarion factory people and they iindicated that they no longer have my Town Car installed CD changer model available, new, used, refurbished or otherwise.
For what it's worth, here are the part numbers and other potentially important data that appear on the "cage"/sheet metal/housing that surrounds the working parts of the CD changer itself:
Assembly Part Number: F8VF-18C849-AE
Part Number (presumably the "cage"?): F8VF-18C830-AE
Date Code: 0998
Serial Number: 0201832
Mounting Orientation: Vertical
System Revision Level: 9.2
So it looks like I may have a potentially very expensive replacement of my whole audio system on my hands. I have been quite happy with my somewhat "obsolete" audio system and I have a very large collection of CDs which I migrate between my Sony 300 CD CDP-CX350 Mega Changer installed in my entertainment center, my car Cd changer and my Sony CD/Cassette player boom box in my master bedroom.
It was suggested to me that if I have to replace the radio/cd/cassette unit installed in the dash of my Town Car that I should consider a replacement model that offers a port to receive Ipod programming as a source of music.
So things have gotten somewhat complicated since the first instance of the Cd magazine not ejecting from the Clarion CD change mounted in the trunk of my car.
Maybe someone out there on your knowledge base knows where I can acquire a used Clarion model CD changer compatible with my car's setup at a reasonable price.
Thanks,
Tom
2answers
Changer won't acknowledge discs
hi make sure that you cart is inserted all the way in, push the eject button why hitting the mag with the handle of ascrew driver. this may dislodge the jammed arm/lever. otherwise its down to your repair agent.
regards
Mark
www.carradiospares.co.uk
Open Questions:
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Marvin
Marvin
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
