Question about Kenwood Food Mixers
HI there, I cant remove my beater blade from my Kenwood mx 260. I have tried with brute force but the whole mechanism turns
Posted by Sarah Fleet on
Priscilla McDaniel
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 70 Answers
Need to take a 2x4 balance it between the outlet for the grass and maybe a pair of vise scrips and then try to take it off.
Posted on Mar 31, 2019
4 Related Answers
jeff6262
SOURCE: New Kenwood chef km 001 - I can't get the beaters out!
Try turning the beater in the reverse direction to the direction it normally turns - clockwise looking at the beater (I think), this should make the shaft pins ride up on some cams which should release the beater.
Posted on Oct 12, 2008
hslincoln
Howard Lincoln
  • 235 Answers
SOURCE: I cannot get the beater to lock in place. The
Hi VBPROSANDY, When you say beater, I assume you mean your flat beater. Are you having the same problem with your Wire Whip beater and dough hook? If you are not, then the first thing I’d do is look inside the flat beater’s attachment well, to see that there is nothing; i.e. hardened food, dough or batter, in the bottom of it that would prevent the agitator shaft and groove pin from seating properly. The flat beater has two drain holes at the bottom for drainage, but if these get plugged it may prevent accumulated ‘gunk’ at the bottom from escaping, and over time the buildup may prevent the beater from seating properly.
If you find the beater attachment well is clean, then from the KA Instruction manual, to attach the flat beater...
1. Slide speed control to OFF and unplug.
2. Slip flat beater on beater shaft.
3. Turn beater to left, hooking beater over the pin on shaft.
Finally, check the groove pin on the agitator shaft to make sure it hasn’t become bent so that it doesn’t fit the beater properly. Pins shouldn’t bend, but sometimes they do.
The beater attachment process should not require any effort as the agitator shaft should easily fit into the beater’s attachment well and easily turn to the left. Your planetary should not move during this process and if it does move it will take some effort on your part to turn it. The fact that you’re turning the planetary means you’ve turned the beater as far to the left as it should go to ‘lock’ it. When you get this far, let go and the beater should fall into place on the groove pin.
Good luck. I hope this helps. Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! - hslincoln
Posted on Dec 06, 2009
Testimonial: "I don't know what the problem was last night but it is working perfectly this morning. Maybe it was something built up inside that was cleaned off."
Chris Trim
SOURCE: K-beater is stuck on our Kenwood Chef and we can't remove it
I couldn't remove the K-Beater as when I tried to turn it the whole mechanism turned with it. I couldn't even remove the splashguard! I was going to take it to the Kenwood factory (a few miles from home) but then I thought I'd give it one more go and this is what I did...
  1. Next to where the K-Beater attaches in the middle of the circular plate is a lug with a pointed-shape bolt on the end. Remove this with a spanner and the beater plus gear cog can be removed.
  2. Place some mole grips or wide pliers on a worktop and sit the cogged gear in to it and grip so that it won't turn.
  3. Now you should be able to remove the K-Beater!
Perhaps someone can suggest how to stop it happening again. I haven't attached anything since but will update this post if I have any other helpful tips.
Posted on Oct 31, 2011
DonC
SOURCE: can't remove beater kmix from machine. it's stuck!kenwood
Here's how to fix the stuck implement problem:
The implements each have adjustable heights. to adjust the height you need to loosen the bolt at the top with a 14mm spanner. If the bolt was loose when it was being used then it can get too short and not leave enough clearance between the bolt and the machine in order to push up and turn to release the implement. If this happens take the open ended spanner, grasp the implement and rotate the spanner clockwise (when looking up at the machine from below. Once the nut is loose rotate the implement until there is enough clearance to remove it normally.
Posted on Nov 18, 2011
How can I remove K beater from my Kenwood patissier which is jammed
Only a bit of CRC and some brute force is going to work. Unplug the machine. Remove the bowl, lock the head down, squirt some CRC around the top of the paddle where the shaft goes in. Get someone to hold the mixer from moving about then grip the paddle firmly with 2 hands and turn it left and right. Gradually you will begin to get increasing movement until in the end you will be able to unlock it from the shaft. Once it is off you will need to thoroughly clean the shaft then you will need to scrape out the inside of the hole in the paddle. I carefully use a small round file, I am trying to clean the hole out, not increase the size of it beyond what originally was. The hole size has become smaller over time because of flour or similar entering around the shaft during use.
Mar 01, 2015 | Kenwood Food Mixers
Cannot remove the flexi beater
I have read on other posts that it is the nut at the top of the beater that is causing the problem. You need to rotate it downwards toward the beater in order to have sufficient room to push and rotate the beater out. This didn't work for me, nor did attempting to remove the whole plate by undoing the lug beside the beater insert. Now that I have worn the lug and the nut I cannot get it repaired at a Kenwood service specialist as I have attempted the repair myself.
My advice is to go straight to a professional. Whatever they charge it will be cheaper than being stuck with a machine you can only use some of the time and have to replace!
Dec 31, 2012 | Kenwood KM400 / KM410 Chef Classic Stand...
One of my blades is stuck and I can't engage the release
Make sure your Beater can slip in and out of the Beater Shaft
easily. Do not force the beater onto the Shaft if the shaft is bent.
If it cannot be removed easily by hand, use a soft rubber mallet
(not a steel hammer) to slightly tap the beater so it can be moved
up and down the shaft or from side to side. Then you can easily
turn the beater left and remove it from the shaft.
From Kitchenaid Manual:
To Attach Flat Beater, Wire Whip, or Dough Hook
1. Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Slip beater onto beater shaft and press upward
as far as possible.
5. Turn beater to right, hooking beater over pin on shaft.
6. Plug into a grounded 3 prong outlet.
To Remove Flat Beater, Wire Whip or Dough Hook
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft
Jul 19, 2011 | KitchenAid KSM150PS Artisan Series Stand...
First time using bread dough beater It was hard to put on and am unable to remove
as far as possible.
5. Pull beater from beater shaft.
Jul 17, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Bread dough beater will not come off
as far as possible.
My detachable draft shaft burned by my stove where can i buy a other one
I think your talking about the beater shaft. I can not relate to the draft shaft and I have been around a long time. This site has loads of KM800 parts in the UK. FYI Delonghi bought out Kenwood and getting parts in the US is through Delonghi. Their phone service takes forever!!!!
Try browsing this site:
http://www.4kenwood.co.uk/cgi-bin/catalogue.pl?pg=17&section=345619&path=345550,345619
There are 260 items for the Kenwood KM800 there
Thanks for choosing FixYa.
Kelly
p.s. Watch as your looking through the items. Many of them are no longer available.
Aug 20, 2010 | Kenwood KM800 Major Classic Stand Mixer
Hi,we have an old kenwood chefette hand mixer with worn parts.
does anyone know how I could get the whisk beaters for a Kenwood A375? Was given mixer but no whisks!!
Jul 29, 2009 | Kenwood Food Mixers
Feb 15, 2009 | Kenwood KM400 / KM410 Chef Classic Stand...
Blade won't release from mixer
Try to push up while you turn the blade. Don't be afraiid to turn hard.
Dec 30, 2008 | KitchenAid K5SS Heavy Duty Commercial...
Sep 23, 2008 | Kenwood KM800 Major Classic Stand Mixer
Food Mixers Logo
190 people viewed this question
Top Kenwood Food Mixers Experts
Marvin
Marvin
Lawrence Oravetz
Ross Keen
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
