Question about Apple iPhone 3GS Black (16 GB)
First, Can your 3GS connect on ant other Wi-Fi? If so the issue is specific to configuration on either iPhone or BT Home Hub.
Second, Does BT Home Hub configured for any kind of mac-address security? Check that, if it does either remove it or add the iphone mac-address, you can find the iphone mac address under network setting.
Third, Does Home Hub have limit on number of devices that can connect to it, some do. check that and make sure that you increase the limit or just remove the restriction altogether.
Fourth, IS BT Home Hub Wep enabled? If so the password/key you are entring on your iPhone must be exactlythe same. Or just remove the wep encryption to see if your iphone 3GS can connect.
Fifth, If your old 3G is able to connect to your BT Home Hub, then just make sure you are not FAT fingering the keys and entering a different key.
Posted on Oct 25, 2009
Instead of typing in your log in password ie roger945 type in the wap encryiption security key code off the back of home hub when it asks for password wifi comes on your phone straight away
Posted on Oct 02, 2011
Apr 03, 2016 | Computers & Internet
Oct 09, 2014 | AccessData Password Recovery Tool Kit (ftk...
Sep 05, 2014 | Apple iPhone 5S
Jan 29, 2014 | Motorola Mobility GOOGLE 8GB MOTO G XT1032...
Sep 30, 2012 | Computers & Internet
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Iām happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 18, 2011 | Apple iPhone 3G
Jul 26, 2010 | Apple iPhone Smartphone
Jul 01, 2010 | Apple iPhone 3G
Mar 19, 2010 | Apple iPhone 3G
Jan 03, 2015 | Apple iPhone 3GS Black (16 GB)
Jun 16, 2014 | Apple iPhone 3GS Black (16 GB)
1,535 people viewed this question
Yes it accurately describes it but "cannot connect" despite correct password
old iphone 3g conected OK
Well to start with have you enabled the WEP secure connection side of the Home Hub? Eg. Does it require a password to connect to? If so make sure you have entered this into your iPhone correctly. Try forgetting the iPhone WIFI connection if its not working and then try reconnecting. Can other devices connect to the Home Hub via Wifi?
Will your Iphone see the BT Home Hub?
