My spooler service is not running
Lexmark 5150 printer
Posted by lynn barnes on
nik parelos
  • 54 Answers
RUN SERVICES.MSC
LOOK FOR SPOOLER SERVICE AND START IT
Posted on Nov 27, 2007
  • nik parelos
    nik parelos Nov 27, 2007
    OTHERWISE YOU HAVE A VIRUS
    PANDA 2008
When i try to uninstall my lexmark x1190 it comes up printing not finished
Try to clear the Lexmark print queue from pending/stuck print jobs so you can successfully uninstall the Lexmark software/ printer driver. Here's how:
  1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
  2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
After successfully clearing the print queue, uninstall the printer software by going to Start menu > Programs > Lexmark 1100 Series folder > Tools > Uninstall. Reboot your pc when prompted.
Hope this helps.
Apr 30, 2012 | Lexmark X1190 All-In-One InkJet Printer
Lexmark X4690 printing status stuck at 50%
It could be that the Print Spooler service on your computer has stopped. Please follow the steps below to fix the problem:
1. On your computer, browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Aug 24, 2011 | Lexmark X4690 Wireless InkJet Printer
Printer won't delete job
First goto Start>run>type services.msc then find print spooler then stop it ...
Goto Start>run>type spool > goto printer and delete all files ...
at last goto Start>run>type services.msc then find print spooler then start it ...
Aug 30, 2009 | Lexmark X6675 Pro Colour Wireless...
Document won't delete from printer queue after printed
Have you tried to stop the spooler service in services?
Option 1)
Click on start orb
Type in search window:
services.msc
click ok
Scroll down to Print spooler service and click on it in the right side window.
On the left side click stop the service and wait forthe process to stop .Do not close the window yet. You will have to restart it here later.
next delete the print job in the printer queue then restart the spooler service
Resubmit your new print job.
Option 2)
If that doesn't clear it, the next step would be to stop the spooler
service as stated above
Go into windows explorer
(Print job data is collected and stored in a spool file in the spooler folder.)
It is located in:
C:\WINDOWS\system32\spool\PRINTERS
Your print job will show 2 files there Example below:
00002.SHD
00002.SPL
Delete the files located in there. There may be several of them depending apon how many print jobs you submitted. You will have to resubmit your print jobs all over again.
Next go back to services window and restart the spooler service
That will definitely fix it.
Aug 19, 2009 | Lexmark Office Equipment & Supplies
Can't install printer (lexmark 5150) because spooler isn't started
Right click on the "My computer" icon then select "Manage".
When the computer management window opens, click on the + sign next to services and applications to view the full list then highlight "services".
The list of services will appear on the right side. Scroll down until you see "print spooler" then double click on it to open the print spooler properties and click on the start button.
While you're there, make sure the startup type is set to automatic.
Aug 04, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X1180 won`t install on new vista laptop
Okay this is a easy problem, the printer spooler service is turned off, just turn it on, and try to install it again, should work if not let me know.
press start and then run
OR
hold down windows key and press r
in run menu type in: services.msc
and press ok or enter
in services, you need to find printer spooler or spooler, right click on it and select properties.
make sure start up type is automatic, then press on start. Apply ok, close window , make sure the service status is running, press F5 to refresh the page.
try installing it now.
May 21, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
I have a lexmark x3550 and it says there is no spooler, and now it says there is no printer.
Verify that that the Print Spooler service, and all the services that it depends on, are correctly installed and running.
  • Open the Services Management Console (click Start, Run and enter services.msc).
  • Double-click the Print Spooler service to open its Properties window.
  • On the General tab, check that Startup type is Automatic.
  • Select the Dependencies tab.
  • Note all of the dependent services listed, then close the Print Spooler Properties window.
  • Repeat the above steps for the dependent services noted.
If any of the dependent services are missing or cannot be started, try uninstalling all installed printer drivers and then reinstalling them.
If this method cannot be completed or does not resolve the problem, try Method 2.
Method 2
Remove all Print Spooler service dependencies other than the Remote Procedure Call service.
  • Click Start, Run and enter sc config spooler depend= RPCSS (there must be a space after "=" but not before it.)
By removing the other dependencies the Print Spooler service should be able to run, but the printer functionality may be affected, and it may be necessary to reinstall the printer drivers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 29, 2008 | Lexmark X75 All-In-One InkJet Printer
Spooler not running after Lexmark x83 installation on windows XP laptop
From what you're saying the windows print spooler service is not starting following the installation of your printer (and thereby you cannot print i'm assuming)
try the following to start the print spooler service if it is not already running.
Click Start
Right Click My Computer
Click Manage
Click "Services and Applications"
Click Services
Scroll down to "Print Spooler" and double click on it to open up the properties page
where it says "startup type" select automatic from the combo box list
Apply
If the service is NOT running, start it by clicking "start"
click OK
The print spooler service is started now, and **should** work properly. If the spooler is still not starting properly, then you may have a driver issue and i reccommend uninstalling and reinstalling the drivers for your printer.
Jul 01, 2008 | Lexmark X4270 All-In-One InkJet Printer
Printer Spooler service!
click on start ..RUN.....type cmd......type sc config spooler depend= RPCSS......click on start ..RUN......type services.msc.......look for ptrint spooler......it will be started if not then double click on print spooler and click on start.
Now try installing the printer.
May 31, 2008 | Lexmark X4270 All-In-One InkJet Printer
Computers & Internet Logo
322 people viewed this question
Ekse
Marvin
Marvin
