Question about Car Audio & Video
What capacitor is recommend for use with this amp?
Posted by Joe Barr on
  • Joe Barr Mar 31, 2019
    Kenwood KAC-7204
    Kenwood KAC-7204
Hammond e100 Organ amplifier is their a recommended substitute solid stae amp available
Because there are other functions located in the amp chassis in the e100, there really isn't an aftermarket substitute. I think you're on the right track by rebuilding and retuning the current amp. Due to age, I'd just do it all at one time and be done with it.
Jul 10, 2016 | AMP Music
When i turn on my unit it says hello. and will not do nothing , even if i turn it on & off what can i do thank you model liteon lvw 5006 dvd recorder
There is a capacitor on the power supply board that needs to be changed, if memory serves me it is a small 220uf capacitor, the recommended replacement is 470uf capacitor with a higher voltage rating.
Mar 17, 2011 | Lite On Televison & Video
Hello Our Thompson Speedtouch modem (which we've had for a couple of years) is not working properly, it keeps losing the connection to the internet. There are five green lights on the front of the...
Appreciate you asking, Terry.
Without directly having your modem in front of me, I'll have to surmise that Electrolytic Capacitors inside the modem have gone bad.
These capacitors are used as Filters.
After a given time they break down. In fact the designer knows this, and uses capacitors that are 50 percent better than what is required.
One wouldn't think that within a two year span the unit would breakdown, but there are many variables that can add to their demise.
1) Power outages
2) Dirty inside, (Use a can of compressed air in the vent holes occasionally. There is no fan inside, and air is used to cool the components inside. Unit UNPLUGGED from power)
3) Low quality components used inside the modem. Especially Electrolytic Capacitors.
My recommendation would be along the same as yours.
Buy a new modem.
You didn't state the Model Number, so I don't know if it is a wireless unit, or not, nor do I know if it is a cable unit.
Wireless, of course will be more expensive.
A couple of recommendations from a quick search.
Not advertising for said website, nor manufacturer,
1) http://www.newegg.com/Product/Product.aspx?Item=N82E16833122316
2) http://www.newegg.com/Product/Product.aspx?Item=N82E16825112006
A visual guide to bad 'caps',
http://www.capacitorlab.com/visible-failures/index.htm
Should you have any further questions please do not hesitate to ask. Post in a Comment.
Regards,
joecoolvette
Mar 07, 2011 | Computers & Internet
My AL1717 monitor shows a flickering power signal (blinks off & on) but shows black screen and nothing else. Thank You
Most likely a problem with internal capacitors either blown or swelling or leaking. Can be repaired by replacing the faulty capacitors but recommended that this be carried out be a qualifed technician
Dec 30, 2010 | Acer AL1717 17" LCD Monitor
Factory radio and sub woofer installation
installing any system is tricky... subwoofers are even more so... it all depends on what kind of amps and changeovers you have and if you have a capacitor (recommended). amps are a deciding factor in gauges of wire as well. so my question is is what you have and how you are trying to set it up?
Nov 22, 2010 | 2002 Dodge Dakota Club Cab
Mi lights dim everytime mi speakers beat
simple issue means your alternator is not able to supply enough amps to keep the system running properly, recommendation get a capacitor to handle the extra load, it acts like a second battery, when the alternator charges the cap it takes the load off the cap rather then the battery, so the lights and system all run with sufficient power i recommend a 1 to 2 farad capacitor for your system if it is about 800+ watts, you will notice the difference immediately
http://www.bestbuy.com/site/olspage.jsp?skuId=8286482&type=product&id=1172880157454&ref=06&loc=01&ci_src=14110944&ci_sku=8286482
very good cap
Aug 20, 2009 | Rockford Fosgate Car Audio & Video
Power wire keep blowing fuses
you need to go tho a block fuse which will be able to handle more load but will still give way before the amp its self would get fried i recommend a 75 fuse or higher
Feb 21, 2009 | Orion HCCA 275G4 Car Audio Amplifier
Battery
First off, are you trying to stop lights from dimming? Because a capacitor is only a band aid to solving that issue. If you are using a capacitor for its intended purpose (to smooth out the voltage input to the amp, thus providing a more consistent voltage level), the general rule is 1 farad per 1000 watts rms. I hate to tell you caps aren't worth it, but this amp is a good amp. There are built in capacitors already. If you really want to see an improvement in your system, you will want a quality cap along side a quality amp. Look for an Alumapro capacitor. They go all the way up to 50 farads. High in price, very high in quality. Perfect compliment to an amp such as yours.
May 09, 2008 | Jl Audio 1000/1 Car Audio Amplifier
2.0 Farad Capacitor
The answer is yes, any amount of amplifiers can be hooked up to a cap. Obviously the more amps you hook up to it the less you are going to nodice the difference with the same amout of farads. The only thing that I am worried about is the wiring from your battery to your cap. As long as you have a decent gauge wire running back you should have no problem. And for this instance I would recommend 0 guage, you might be able to get away with 4 but I would highly recommend 0. Over all I would recommend 0 guage on all installs unless you are going small and don't plan on upgrading. I hope I could help
-Andrew Hawkins
Apr 23, 2008 | Car Audio & Video
Vertical section problem? Part of screen is blank
replace cap. 2465, cap. 2561, cap. 2460, and d6460
Feb 23, 2008 | Philips 27MT3305 27" TV
Car Audio & Video Logo
Top Car Audio & Video Experts
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
