Question about Canon PIXMA Office Equipment & Supplies
I have Canon Pixma IP2770. The magenta suddenly stop printing. I tried cleaning and deep cleaning multiple times but there were no improvement.
Posted by Butter Aldea on
inhaliertet
    Welcome Back:
    Visited the website for 2 consecutive days.
Hello.
For Canon Pixma IP2770 printer drivers, please visit: https://www.my-canondrivers.com/canon-pixma-ip2770-driver/
hopefully can help
Posted on Jun 29, 2020
5 Related Answers
Anonymous
  • 7 Answers
SOURCE: Canon Pixma IP5000 wont print cyan or magenta
Think you need to clean the sponge that the ink cartridges sit on in the head tray they are probably blocked with dry ink. You can remove the print head and tray by lifting the lever and gently lifting it out..... go here http://www.inkjethelper.com/
to see how to carefully clean it with compressed air. I had to do this too.
Posted on May 02, 2009
Douw
Douw Coetzee
  • 91 Answers
SOURCE: canon Pixma IP4200 started printing regular
Hello first of all are you technical
I have taken the printer head out
boil some water and pour in a cup
take off the 2 screws at the bottom
gentley open the head from the casing**** note if you not gentley it wil brake and U can through the hole head away
then let the white block lie in in the water until the water is cold the trough that out and repeat this step.Boil water again....Wait for 4 to 5 minutes to pass..... then use high copressed air and blow from the underneth so that the presure will force the **** out on the white block side also force some hot water from the litle sifes at the top down and make sure that holes are open
replace the ruber perfectley and the head pease an make sure every thing is propeley dry.Replase the scews .and put it back in the printer.Remember it is also a very filthey and inkey job.Good luck
Posted on Feb 15, 2010
Anonymous
SOURCE: Canon Pixma MP170 Magenta ink has
Change new color catridge
Posted on Dec 01, 2010
Grant Meier
  • 352 Answers
SOURCE: I have a canon pixma ip2770. I just had an ink
Sometimes after a refiling they cover a small air holes on the top of the cartridge when replacing the label. remove the label completely and try again.
Also the magenta might have been to empty for a refill to work correctly. There is a lower chamber in the cartridge that air can get into and stop the flow from the top section. This link below can help in that case. http://www.fixya.com/support/r3986425-unblock_print_heads
I hope this helps Regards GM
Posted on Apr 21, 2011
Clive Hunt
  • 9 Answers
SOURCE: canon pixma mp780 printing problem
If deep cleansing via software doesn't work then you've got to manually clean your print head unit. Sometimes you'll have to bite the bullet and get a replacement print-head unit ($$). If you're at the stage that you're considering replacement, then you've got nothing to lose by cleaning the print-head unit yourself. It's simple. Remove all ink cartridges first then remove the print head itself. Place the print head unit in a saucepan of warm (NOT boiling hot) water and leave to soak for an hour. (Protect your clothes - it gets messy) After an hour, flush the printhead unit under a running tap. Don't run the water too fast or you may damage the unit) You should flush until the water runs clear. Do not attempt to clear the nozzles with anything other than water - they are very fine needle jets and you will damage them!! If needs be, return to saucepan and leave to soak in warm water again and repeat process. When you are satisfied that the printhead is clean, you need to dry the unit thoroughly. Shake as much water from it as you can then pat it gently dry. Next place it on some absorbant kitchen paper and put the unit in a warm place to thoroughly dry (Overnight in a warm airing cupboard would be good). Once dry, refit the unit put in (Preferably new - but I've used existing one's without problem) cartridges and run a cleaning cycle. Your printer should now work as if new!!! - In Most cases!! - sometimes though, you'll either have to replace the print head unit - which sometimes can be more expensive that simply replacing the printer. What have you got to lose though eh? CLIVUSS
Posted on Jan 27, 2012
Ip2770 black ink doesn't apperar on paper although there is no nitification of cartidge damage
you most proberbly have a clogged black catridge. try cleaning from the printer's maintenace tab. if it doesnt improve after a few cleans, do a deep clean. if it still doesnt work and you dnt feel like buying a new catridge yet, steam the nozzle of the catridge. these steps almost always do it, if not, just get a new catridge and voila!
Jan 19, 2013 | Canon Pixma iP2700 InkJet Photo Printer
I have a canon pixma ip2770. I just had an ink refill for the first time but magenta ink won't work. I tried cleaning, deep cleaning, etc. but the other ink worked just fine except magenta. what should I...
Apr 21, 2011 | Canon PIXMA iP2200 InkJet Photo Printer
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Canon pixma ip4300 - magenta ink is recognized but not printing
Take the print head out of the machine and sit it in a saucer of very hot ( just off boil) water about 10mm deep for a minute. Take it out and sit in on a pad of paper towel to dry briefly before returning it and the cartridges into the machine. Give it a deep clean and try again. If still no good, the print head has probably had it.
Oct 24, 2017 | Canon PIXMA iP4300 InkJet Photo Printer
MAGENTA NOT PRINTING
The other week I had the black print head clog up, requiring daily nozzle deep cleaning [a normal 'ocassional' maintenance function]. Thought I needed a new Print head, so anything worth a try.
I loaded up an old black cartridge [I load all my own......always have] with Isopropyl Alcohol and ran deep clean on that cartridge a couple of times, then repeat printed [6 times] a page full of the number 8 in about half inch character size, to get the alcohol through the nozzles. then Deep cleaned again 3 times, to wash it through the print head.
I reloaded the normal ink filled cartridge and ran the '8' page again till I got good black output. It has now been working without problem, daily, for over a week. Clearly if it's a Magenta only problem, the cleaning as described above would be a bit different, as the magenta is one of 4 colour cartridges.
My printer does quite a lot of work, and was bought at least a couple of years ago, being used daily for alpha numeric and photo printing work. This was the first difficulty I experienced with it.
Hope the above might help.Ken
May 21, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Apr 09, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
47 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
