Question about Locks & Locksmithing
My batteries died and my key is locked inside. How do I get inside the safe??
Posted by don little on
STEVE yes that one
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 35,540 Answers
You probably dont
Posted on Mar 30, 2019
5 Related Answers
Anonymous
  • 113 Answers
SOURCE: small floor safe Sentry Model 3877 electronic lock and key
This manual will answer both of your questions.
http://www.sentrysafe.com/pdfs/OwnersManuals/501664.pdf
Posted on Mar 05, 2008
Anonymous
SOURCE: Cannot get my Bunker Hill Safe open.
get the key number that is listed above the key hole and then call 888-299-3427 for a replacement
Posted on May 19, 2009
Anonymous
  • 384 Answers
SOURCE: LOCKED KEYS INSIDE A HARDLINE SAFE
Do you expect us to read minds?
Posted on Jul 16, 2009
Anonymous
  • 77 Answers
SOURCE: locked out of my cs2 safe
If you registered your safe with the manufacturer they will normally let you know your combination if you have registered the safe.
If not you will need the serial number on the side of the safe and you will need a notary stamped paper explaining you are the rightful owner of the safe.
Costs will apply to the Notary and possibly from the manufacturer.
Posted on Aug 23, 2009
Testimonial: "thank you very much your help was excelent "
YaBaPortugal
Filipe Polido
  • 123 Answers
SOURCE: My Bunker hill safe Batteries died and the keys are inside.
Check this out:
http://www.fixya.com/support/t1062111-bunker_hill_safe
(no need to re-invent the wheel, other experts have given solutions first)
Posted on Sep 17, 2009
My safe, a Cathedral EA15 Will not lock. Any suggestions people?
Instructions
  1. 1
    Enter your code on the keypad located on the front of the safe. Some electronic digital safes require you to input a special character like "#" before and after your code. The safe should either beep, have a LED turn green, or display "OPEN" if you have correctly entered the code.
  2. 2
    Turn the handle to the right within five seconds of correctly entering the code. If you wait too long, the safe will lock and you will have to enter your code ag
Open the safe with a key. Use your emergency key that came with the safe to open it if you forgot the code or if the batteries have died. Remove the key cover from either the handle or the control panel to reveal the lock.
  1. 1
    Enter your code to open the safe.
  2. 2
    Place the electronic digital safe into code reset mode. On some models you need to hold the last digit of the code or press the "*" button to get into code reset mode. Other safes require you to open them and press a small red button on the inside of the door.
  3. 3
    Enter your new code on the keypad and press "#" to finish. Some safes may require you to press "*" or a letter to finish the code. If the safe requires it, enter the new code again to confirm that you entered it correctly.
  1. 1
    Use your code to open the electronic digital safe's door.
  2. 2
    Locate and remove the battery cover on the inside of the door.
  3. 3
    Replace the used batteries with new ones. For most safes, this will require two or four AA batteries.
  4. 4
    Test the batteries. Use your code while the door is open to test the batteries before closing the safe.
Feb 08, 2015 | Locks & Locksmithing
Battery is removed and the keys are inside
Is it a safe with an electronic lock? The safe usually comes with a key that you should keep outside the safe not in it exactly for this flat battery scenario that you're in. The battery box for your electric lock is usually on the inside of the safe so you need the key to open the lock. You can force it open, check this video https://www.youtube.com/watch?v=aqC9V7SDKdQ
Jan 13, 2015 | Locks & Locksmithing
Where can I get replacement keys for GX B0709 digital safe
There might be a code on the key lock. Manufacturers can sometimes furnish replacement keys by the code or serial number of the safe. A locksmith could also pick the lock and make a key. Keys are really essential if the electronic lock fails. If the safe needs to be opened without keys, a pro can do this with minimal damage.
Aug 06, 2014 | Safe International Digital Electronic Safe...
Docugem g0816f gun safe. The battery seemed to die, yet with new batteries the code pad isn't working. The safe has the key pad and addition key. The electronics of safe are not working; How would i reset...
Looking for information on resetting a Docugem safe - believe it is a PS200. We have changed the battery and now the programmed code is no longer working.
May 16, 2014 | Locks & Locksmithing
I MISTAKENLY LOCKED UP MY SAFE KEY INSIDE THE LOCK AND THE BATTERY IS TOTALLY DEAD ,PLEASE I NEED HELP
you would need to hot wire the batteries for the code to work but if the batteries have gone flat then it needs to be re-programmed again ,only one soloution here and thats to open it with a radial cutter
Nov 20, 2011 | Locks & Locksmithing
Safewell safe EX2007316659 batteries dying and can't open
I have had zero success in finding out any information about various models of electronic safes--no manufacturers' website, no online manuals, etc. Many of these safes are imported from overseas manufacturers.
Dead or dying batteries is a common problem, and I gather that many models of safes come with an override key.
It is incredible how many people have found the best place to keep their override keys and/or instruction manuals is INSIDE their safe!
I ask that anyone with owner's manuals or instruction sheets please publish them on this website for the benefit of others, but that is unlikely as they aren't the ones seeking information--they already have it!
Sorry I can't be of more help!
Nov 10, 2011 | Locks & Locksmithing
I need a replacement key EX2005138875 for my Safewell electronic safe. The batteries have failed and I cannot open the door.
I was locked out of my Honeywell safe after battery died. I ordered a replacement key from firstalert.I was required to photocopy the receipt and type out an witnessed affidavit stating I own the safe. About 3 weeks later I found my spare key,4 days after that the replacement key arrived in the mail ($10.95 money order for that key). The other two spare keys were in the safe, I did not think the batteries would die so soon. Crappy factory batteries that came with the safe.
Mar 15, 2011 | Locks & Locksmithing
CANT UNLOCK BUNKER HILL BOOK SAFE
Battery died and i can't find the key or the instructions to open the safe
Sep 22, 2009 | Locks & Locksmithing
Check this out:
Sep 17, 2009 | Check Point Network Adapter
Small floor safe Sentry Model 3877 electronic lock and key
Feb 21, 2008 | Sentry Fireproof Safe
Locks & Locksmithing Logo
172 people viewed this question
Top Locks & Locksmithing Experts
john h
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
