Question about LG Microwave Ovens
My LG Inverter Microwave LMC1575ST is tripping after 20 seconds with error code F-17. It can be restarted immediately but again trips after 20 seconds. Heating function is working. It is one year old.
Posted by Ashok Kumar Mandal on
ray gallant
    Top Expert:
  • LG Master
  • 68,260 Answers
Ask Google what the error code means
Posted on Apr 02, 2019
5 Related Answers
Anonymous
SOURCE: PANASONIC INVERTER MICROWAVE, 1300 WATTS
  1. Same exact problem
  2. I've noted 3 different ones with the same problem
  3. Panasonic has produced a lemon, north fixing
Posted on Apr 11, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Panasonic NN- A712 combination Microwave 1000w - Switches off after 20 seconds
The 22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Will run for about 18 seconds,then gives an F7 error code
>No, the service guy did none of the things you suggested.
Just as I suspected...
The "element" as it is so inaptly misnamed in the case of this warranty document, is actually the "magnetron", which should normally have an extended warranty beyond the normal 1-year (I assume) parts and labor warranty anyway.
The magnetron may be the culprit here, but a thorough check of the points on my previously posted list is in order to determine the actual cause of the problem.
Since your husband is an engineer, I would suggest that he invite a colleague over to help and to provide some backup for any heavy lifting if it should need to be removed from the wall.
Safety first after all!
You can download Kitchenaid Whirlpool owner's manuals and installation instructions here in case it needs to be taken down during troubleshooting.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 15, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: panasonic nn-s255 wont turn on
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly for more help.
William E. Miller
[email protected]
Posted on Sep 12, 2009
Michael V
  • 72 Answers
SOURCE: Panasonic NNH965BF microwave starts but immediately shuts off
your mag has gone bad and possible that the inverter board as well, not really worth the hassel
Posted on Feb 06, 2010
Trip Circuit Breaker
The circuit breakers may both be functioning properly. What might be happening is that both circuits have other current drawing appliances on them. The circuit breakers react to the sum of all of the currents drawn by all of the devices on that circuit. So, if you have a 15 amp microwave and an 8 amp refrigerator on the same circuit, you would overload a 20 amp circuit by 3 amps.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Apr 14, 2014 | LG LMV1813ST Microwave Oven
Keeps tripping circuit breaker
There must be a fairly major issue with your microwave to trip a 20 amp breaker. I would recommend taking it to your local repair shop or replacing it.
Mar 19, 2014 | Oster OGB81101 1.1-Cubic Foot Microwave...
Mcd 1311st blowing circuit breaker
Generally microwaves should be on their own breaker. Hard wired ones are required to be by code.
If yours has a plug - make sure the plug is original with the unit, not added later or spliced onto hard-wired power leads.
Plug into and outlet rated 15A as the only thing on a 15A branch circuit and try again. If it still trips, try a 20A line and circuit. If it trips that, trash the microwave and buy a new one. Nothing is meant to be repaired inside.
Nov 03, 2017 | Microwave Ovens
Whirlpool GH5184XPS Microwave Oven F7 error, trips circuit breaker
Check the high voltage capacitor, it normally shorts, "discharge with screwdriver" unhook one side and set meter to ohms. Check high voltage diode tied into one side of the capacitor, "unhook from chassis ground" set meter to ohms and check for short, sometimes cracks, "must be replaced" If the diode is open meter does not have enough forward bias to check.
Apr 01, 2012 | Whirlpool Microwave Ovens
Lg microwave oven trips circuit breaker
The magnetron probably has a partial short pulling more current than normal as it runs, the other two items that give trouble is the high voltage diode, "sometimes cracks" to the high voltage capacitor, "usually shorts"
Mar 29, 2012 | LG Microwave Ovens
Oven got hot started smell and tripped out. will restart but only run for 20 seconds
magnetron that makes the microwaves or the power module tha supplies it. Definately a job for the serviceman.
Oct 27, 2010 | Neff H5642 Convection / Microwave Oven
Microwave / Frigidare PLMV
Chek the high voltage capacitor and the diode . If one of them are short there is a chance for tripping the breaker
May 25, 2009 | Frigidaire PLMV168 Microwave Oven
LG LRM2060ST trips circuit breaker sometimes
needs to have circuit of its own rated @ 20 amps powered by # 12-2-wg wire , also very good idea to plug into a good surge protector to protect its control board, as any computer the boards are very susceptible to spike voltage caused by lightning and power problems , as to how it worked before , breakers vary a little in the amount of current it takes to trip them with age , the number of time they have to be reset and heat they have been subjected to over a period of time so it is not unusual for say one 20 amp breaker to trip @ 16 and another @19 for example also the length of wire between the breaker and the appliance can effect the trip range
Jan 13, 2009 | LG Microwave Ovens
Circuit breaker continually trips immediately when used
check for a shorted hi voltage capacieor ,transistor or shorted multiplier diode
Nov 09, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven blows breaker after 2-3 secs
make sure that your microwave is on its own circut breaker meaning nothing shares the plug
Mar 25, 2008 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
184 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Nick Olsen
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
