Question about Watches
Where can I get an English language instruction manual for a TVG 2011 watch?
Posted by Diane Crisp on
Kardoc
    Top Expert:
  • 5,895 Answers
1 Related Answer
camoguy
  • 4 Answers
SOURCE: Wrong Manual Received for CASIO Pathfinder PAS 400B 2632
I was having the same problem, so I went to casio.com and looked for their manuals for watches. I ended up finding this page:
http://world.casio.com/wat/download/en/manual/
If you enter the number from the back case of the watch, (in this case, the PAS 400B is 2632) and it will allow you to download the manual from their archives in a pdf format.
Hope this helps!
Posted on Sep 29, 2009
Instruction manual on SGW-1ACR Tripe Sensor Display Quartz Black Watch, in english language
Hello, Errol -
What is the Module Number stamped on the back of the watch?
See:
http://mygshock.com/casio-manual/
Best wishes.
Mar 13, 2018 | Casio Watches
Change language back to english on polar heart rate monitor ft4
I had the same problem. So I will try to guide you by button push method (because I didn't understand anything in Dutch that said on the panel). If you look at the polar main wrist watch (easy to say) you will see 5 button. 2 of left and 3 on right. 2 left are top -backlight (21) bottom - back or exit from menu (22). The 3 right buttons are top - scroll up (31), middle - menu (32) and bottom -scroll down (33). Now we know the button number here we go.
Hold 22 for 3 sec. You will see current time showing up. Press 33 once -- Setting ---> press 32 once ---> watch time and date ---> press 33 three time ----> general setting shows up ----> press 32 once ----> button sound shows up ---> press 33 twice ---> language shows up --->press 32 once ----> language blinks ----> press 33 or 31 till you see english or your language of choice ---->press 32 once ----> language is set ---->press 22 for 3 sec and you are back to the watch menu. Hope that helps. This will guide you even if you don't understand anything from the language.
Apr 26, 2012 | Polar FT4 Watch
My DZ4067 functions in the non-English day of the week for 21 hours a day now. How do I change it back so the the day of the week is in English for 21 hours a day?
The "day of the week" wheel on your watch actually has 2 settings on it--one for English, one for another language (often French, but could also be Russian, Japanese, Korean, or any other language, depending on the intended distribution of the watch). You'll need to shift the day track over by "half a notch," so to speak, to get things back in alignment.
The crown you use to set your watch can be pulled out into 2 positions. If you pull it all the way out, you set the time. If you pull it half-way out, you can set the day and date. If you turn the crown clockwise, you advance the date. If you turn the crown counter-clockwise, you should be able to change the day of the week. However, instead of turning the day back a full day, stop when you get a day with the correct language on it. At this point, pull the crown out all the way and manually advance the time 12 or 24 hours until the day and date advance as they would when the watch is running. This is to check that you've correctly gotten the day track correctly oriented. You may have to repeat this process a second time to get it right.
Once you have the day back on track, adjust the date and time, and you should be good to go.
Diesel's own directions, which can be found here: http://store.dieseltimeframes.com/common/images/customercare/instructions/ENGLISH/Diesel_Core-Inst_ENG.pdf are pretty cryptic, but they do have a diagram that might help a little bit. You'll want to look at the section for "Day/Date Watch IS02, 507.2-3, 517.2, 2105, 2305, 2405"
May 26, 2011 | Diesel Watch Style # DZ4067
How to change the time
There is a set of instructions for KC watches but not by model name, only by dscription of appearance.
Go to http://www.genevawatchgroup.com/ and scroll down the page and you will see a list of instructions. Pick out the english one (if that is your first language) and then scroll down the download until you reach the watch that looks like yours and study the instructions.
Feb 12, 2011 | Kenneth Cole KC2315 watch
Need to change language on day display from French to english.
1)Rotate crown fast - to change into "date + day" mode
2)crown up
3)fast rotation or the crown = changing the language (en, spain, france, german)
(when rotate crown slowly = you'll change year).
Or read full manual where this procedure are written in exact form:
http://www.tagheuer.com/_documents/manuals/EI2254_en.pdf
Feb 10, 2011 | Tag Heuer 2000 Classic Multigraph...
I'm looking for a manuel instruction in french (first choice) or english. Thanks
Go to http://www.festina.com/descargas/manuales/IFMOS62.pdf and you will see the instruction manual for your watch.
It is issued in several languages (including French), so you need to scroll down until you find the French version.
Jan 20, 2011 | Festina F16351/1 Grande Tour Watch for Men
The day goes into another language and I would like to know how to make it return into English please.
You can get instructions from the Amitron web site.
Copy "www.armitron.com/watch_instructions.asp" into your search engine
and you will see a list of illustrations of watches and associated
instructions.
Choose the one that looks like yours and download the PDF file.
May 06, 2010 | Armitron Two Tone Sports Watch
Hope this helps!
Jun 10, 2008 | Watches
Watches Logo
572 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
