Question about Rowenta Irons
Rowenta pro master The automatic shutoff light is on and I can't get the iron to heat.
Posted by Janet Hastings on
5 Related Answers
Anonymous
SOURCE: Rowenta iron manual needed
does not heat but indicator light is on.
Rowenta steam Iron Model DE-871
Posted on Dec 26, 2008
Anonymous
  • 18 Answers
SOURCE: My Rowenta iron will not heat up. The yellow light
Inside the iron is a piece of thermal metal the is supposed to make contact with a small ceramic pin with a metal cap on it. I think this was intended to be a safety device but they fail and the iron will not heat up. The part does not seem to be available so easiest way to fix is to put a small bead of glue on the housing that forces this to make contact.
Posted on Mar 06, 2009
David Shaub
  • 2976 Answers
SOURCE: Iron spits out rusty water. The iron is a Rowenta
Fill it with a mix of 50% white vinegar and 50% water. Let it set for 30 minutes and steam it out for about 2 minutes. Unplug it and dump it. After it cools colpletely, fill it with water and steam it out. The rust is coming from your water supply, not the iron.
Posted on Oct 06, 2009
Zlobomir
Zlobomir
  • 225 Answers
SOURCE: the automatic shutoff won't let the iron heat up
you either need to press a small button on the protection to reactivate it, or buy a new one and replace it. But first check the thermostat, since there is a reason for all this. Check also the heating element with an ohmmeter.
Posted on Nov 08, 2009
tbreeze47
Tom Carson
  • 3083 Answers
SOURCE: Rowenta iron will heat up and then shut down. Have
Irons use a potentiometer and thermister to control the heat on the element. One of these components is bad and needs replacing. If the iron's still under warranty, get another one. The cost of service would probably be as much as a new iron, but you could call an appliance repair shop to check.
Posted on Mar 12, 2010
ROWENTA DW1050 STEAM IRON
it may be okay when it cools down.
Reviews on Rowenta are not good. :>(
https://www.consumeraffairs.com/homeowners/rowenta.html
Mar 15, 2017 | Rowenta Irons
I need a schematic for a Rowenta DW-8080 steam iron
They do not publish such diagrams for this type of product.
Oct 03, 2016 | Rowenta DW8080 Pro Master 1700W Steam Iron...
Rowenta microsteam 400
You need to follow the instructions for the iron. Rowenta make a excellent iron but it's water tank and steam chamber need to be cleaned and rinsed out, say every third use depending on how much you use it. Also, allow the iron to reach FULL TEMPRATURE before you use it.
Jul 29, 2014 | Rowenta DW-8090 Pro Master SEWERS Iron...
Rowenta Pro Steamer only works 5 minutes then shuts off!
temp limit switch bad... replace iron(sorry)
Jul 04, 2012 | Rowenta Irons
Red light keeps blinking and iron shuts off
Sounds as if the cable may be damaged or a loose connection. May be cheaper to buy a new one from wallmart or similar store.
Jul 31, 2009 | Rowenta Effective DX1900 Iron with Auto...
I have a Rowenta Pro. Iron, model DE-86.1A with auto shut-off. It sticks on auto shut-off. I have to move it around for it to heat up, as indicated by the sensor light on the top.
I believe that is how the safety feature works.
Once the iron detects no movement for a certain period of time (the iron assumes you have finished ironing) the iron will shut of the heating element.
One you have moved it around, the timer should prevent it from auto shutting down for a period of time.
Jul 22, 2009 | Rowenta Irons
Iron won't heat up!!!
A lot of rowenta irons have a safety or auto shutoff built in them that fails. The only way I have found to fix them is to disassemble it and permanently connect the switch then it works fine, just does not auto shut off.
Jan 14, 2009 | Rowenta Power Duo Iron
Rowenta DM880 Auto shutoff - Shuts off too frequently
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Jan 06, 2009 | Rowenta Professional Luxe DM880 Iron
My rowenta effective will not heat up.
Dec 15, 2008 | Rowenta DG5030 Iron
Irons Logo
189 people viewed this question
Top Rowenta Irons Experts
Ekse
Bruce Showalter
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
