SOURCE: Dehumidifier tripping the breaker
be very careful - with the unit unplugged - try shorting the capacitor with an insulated screwdriver. if you get a healthy spark - the cap is probably ok. if you don't replace the cap. the cap is used in the motor's start winding.
SOURCE: trips the circuit breaker on start up
I would try to find an outlet on another circuit to see if maybe the problem is definately your dehumidifier, if it trips again then you know it is...If not then call an electrician..
SOURCE: Humidifier is freezing up
I have the same dehumidifier and it does the same thing. but I was able to fix mine. It was not low on refridgerant. There is a temp. sensor clamped to the evaporater coil with a thin metal clip. The clip rusted out and the sensor fell out of position. I used a small stainless steel hose clamp and clamped the sensor back into position. It now works fine
SOURCE: Dehumidifier problem
First, make sure the rectangular filter on the back side is clean so air can flow over the coils freely. Try to place the dehumidifier on a table or something to get it off the floor. (floor level is cooler than head level) If you still have icing issues, replace sensor. (part # WK23X10011 )
SOURCE: Dehumidifier is tripping circuit breaker.
The compressor is bad and is causing the circuits to trip....
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
