Question about Vivitar Cameras
What would cause a Vivatar 283 to not power up? See details below for additional info.
My Vivatar 283 flash was left in the on position for years. I've cleaned the battery contacts and put in fresh batteries, but the unit does not power up. Do you have any suggestions on what the problem is? Update: There are contacts on the outside of the battery holder also. I overlooked them. After cleaning them the unit works great. Thanks for all of the suggestions.
Posted by David Shanks on
5 Related Answers
Anonymous
SOURCE: No Sound/No Power
I used your site to research the problem further. I found an answer which recommended rubbing the suspect terminal lightly with a pencil eraser. It worked! I now have battery power and my headset works fine.
Posted on Nov 30, 2008
Anonymous
SOURCE: Won't turn on.
Soak the internal contacts of the battery holder with WD40 electrical spray and leave for a while say an hour it will not harm the electronics but wipe suplus off after giving further cleaning with fibre tipped pen available from most electronic firms the contacts have to be very clean as I found with my flash gun Vivitar 283 and I nearly give it up for lost after the above it is now working fine
Posted on Feb 01, 2009
Anonymous
  • 8 Answers
SOURCE: Flash on Nikon SB600 won't turn on
there are tabs in the battery wells you may have to put something in there to bend it back up so it will make both contacts on top and the bottom
Posted on Mar 20, 2009
SOURCE: won't start after cleaning battery terminals
Sounds like you have an aftermarket alarm with starter disable. By disconnecting the battery the alarm reset and the defualt setting is usually to set the alarm automatically (active arming). You have three options..
A. If you have the key fob that went with the alarm you can disarm the alarm.
B. If no key fob is available you can disconnect the battery again, turn the ignition key to the on position and reconnect the battery. This usually doesn't allow the alarm to set and allows the car to start.
C. Remove the aftermarket alarm system. This is usually the long term fix i recommend if the fob isn't available. Option B should get you going though.
Posted on May 09, 2009
Anonymous
  • 14 Answers
SOURCE: Canon A720IS flash problem/low battery indicator
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Posted on Aug 21, 2009
Where can I purchase a new or used battery holder for a Vivitar 283 flash attachment? Mine was left in too long and the batteries destroyed the contacts.
Best place for finding Vivitar 283 anything is on e-Bay, I use a gang of them doing my location photography and have several holders preloaded with batteries so when the cycle time starts to get more then I can bare I just switch out the holders.
All my stuff came off e-Bay.
Feb 21, 2011 | Vivitar 283 Flash
Can the Vivitar 283 be used safely on Nikon Digital SLR Cameras?
I assume you're asking about the 283, not the DF-283 which is compatible with digital cameras.
As for the 283, yes, if you put an adapter such as the Wein Safe-Sync between the camera and the flash. Under no circumstances should the flash be mounted directly on the camera.
Nov 29, 2009 | Vivitar 283 Flash
Is it compatible to use with a Nikon D-50?
No, the Vivitar 283 does not have TTL (Through The Lens metering capability) and the voltage in the flash may be much higher than that in the camera. Some of the old 283 flashes had a very high operating current that, when the flash is left one and removed from the camera can damage the camera operating circuts. Find a Nikon SB 400, 600, 800 or 900 speedlite, or a Promaster 7200 or 7500 for a great less expensive flash for this camera.
Nov 20, 2009 | Vivitar 283 Flash
Hi my name is Curtis can you tell me IF my Vivitar 283 flash will work on my c-750 Olympus, TTL camera it have an hot shoe,but flash don,t fire. I have talked to Olympus about it(on answer). I took it to a...
No the 283 is not compatible with your camera. The 283 is manual only and not TTl. The canon flash is also not compatible with your Olympus. You need an olympus compatible flash.
Nov 16, 2009 | Vivitar 283 Flash
Ready lamp on 283
When the flash goes into battery saver mode, which it does automatically, the light will blink.
If you are using the external power source, the light should remain steady.
Jeff
Oct 30, 2008 | Vivitar 283 Flash
850 Diesel intermitant throttle
be very sure you have a good fuel filter and no air in the lines.diesels hate air lol
Jul 09, 2008 | 1996 Volvo 850
I need a wiring harness for my deh-p730
Most Pioneer units follow the below detailed color codes for the wiring.
Yellow - +12V Constant Power
Red - +12V Switched (accessory) Power
Blue - Power Antenna
Blue/White - Amp Turn-on
White - Left Front Positive Speaker Wire (LF+)
White/Black - (LF-)
Gray - Right Front Positive Speaker Wire (RF+)
Gray/Black - (RF-)
Green - Right Rear Positive Speaker Wire (RR+)
Green/Black - (RR-)
Purple - Left Rear Positive Speaker Wire (LR+)
Purple/Black - (LR-)
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 16, 2008 | Pioneer Car Audio & Video
Vivatar 283 and Nikon D70s
The Vivitar 283 was manufactured in China & Japan over a number of years & the specifications did change over this period.
The older Vivitar flashes had a voltage on the shoe which could reach 150 volts whilst the later ones had voltages of only 5 to 9 volts.
If you have, or can get hold of, a small voltmeter then you can measure this voltage.
Turn on your flash & let the unit charge up to 'ready' & connect the meter between the contact in the centre of the shoe & the little contact tucked away in the lip of the shoe. (DC volts not AC) There is no danger to you in doing this!
This should tell the voltage on the shoe of your unit & if it is 15 volts or less, it will be fine with your digital Nikon camera. If more than 15 volts than best not to use it.
Hope this is of some help!
Mar 10, 2008 | Vivitar 283 Flash
Vivitar 283 charges but fails to flash
I had the same problem with my early Vivitar 283 flash.  I discovered that the thyristor on the trigger board tested as an open circuit.
Trying to find a replacement for a 30 year old thyristor semi-conductor proved to be fruitless.
My solution was to purchase a broken, late model Japanese 283 flash off of ebay and transfer the trigger board to my early Japanese model. The late model thyristors could handle more heat.
Problem solved.
Mar 15, 2007 | Vivitar 283 Flash
What can I do to upgrade my FD91?
The most useful upgrade to a Mavica 91 would be the addition of an external flash with a slave trigger. You would get a standard flash bracket at any camera store to hold the flash. I use a Vivtar 283 flash with a Vivitar SL-2 trigger. It completely eliminates any problems with the 91's flash power. Because of the Mavica 91's 52mm lens threads the entire range of available filters that film photographers have been using for years becomes open to you. This includes telextenders and wide-angle addons.
Sep 11, 2005 | Sony Mavica MVC-FD91 Digital Camera
Cameras Logo
Top Vivitar Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
