Question about Saws
Our greedy table short and long straights have stop working. how do we fix it
Posted by Pap Fish Jackson on
Craftsman saw stopped working i bypassed the switch and the blade turns for a second then blows the breaker does the switch increase/decrease the pow er is there a wat to fix this
The switch does not control power but only turns it on/off. You most likely have a short in the motor and it should be taken to a shop or replaced.
Nov 11, 2016 | Craftsman Saws
How do I stop my Juki DDL-8700 machine from skipping stitches?
set up on quilting table? wheres the oil pan?? if your machine sews fine straight and skips on curves i think you are lifting the presser ft as you make the turn. theres nothing wrong with the machine. you could always change the needle which is always the first thing when you encounter a sewing problem.
Oct 08, 2014 | Juki DDL-8700 Industrial Straight Stitch...
I was recently given and older Craftsman 10" table sawa. It worked great for cuttin some 2x4 and now all of a sudden it will only cut part way7 and than stops, and it smokes--Help!!
The problem could be one of the following:
1) dull blade, in which case replace with a carbide-toothed blade
2) underpowered or old/faulty electric motor
3) faulty/worn belt, in which case replace with new belt
4) The pulley on either the motor or the saw arbor (where the pulley attaches underneath the saw near blade) could be loose. Tighten down set screw.
5) The saw fence isn't set straight causing the wood to jam as you push it into the blade. Check this with a framing square and readjust so it is at a 90-degree angle to the front of the saw table.
Sep 13, 2011 | Craftsman 10" Table Saw
I need to know how to aling the the out feet table heighth to that of the blade heighth. In moving, the out feet table is higher than the blade on a Delta wood jointer 37-196.
I assume you want to know how to get it adjusted just right, not how to move the outfeed table up and down. The easiest way I have found is to lay a metal ruler on edge on the outfeed table so that it extends over the blades. Slowly turn the blade forward by hand while you lower the outfeed table. Do that until the blade snags the metal ruler. Then raise the table until the blades just stop snagging the straight-edge.
Mar 13, 2010 | Delta Masonry Tools
Our bose remote stopped working after a fall from a table
hey....normally with remotes there are only so many things that can go wrong....normally when it is dropped either the battery terminals can short each other out..or the IR LED breaks off the PCB or you get a dry joint somewhere i would suggest that you pull it apart...do this by using a small flat bladed screwdriver and gently pri the case apart remebering to remove any screws that it might have on the back panel and just inspect for any of the faults listed above its normally nothing a soldering iron and some solder will fix...if it has sustained quite a hard fall (and i mean really hard) the pcb can sometimes break straight across it and then the remote is useless but it is worth opening up and having a look first hope this helps,ben
Jan 09, 2010 | Bose Cinemate Digital Home Theater System...
Need to adjust Miter gauge for Delta tablesaw 36-977. The 90 degree stop is off
1) Before setting the Miter gauge, check that the blade is straight (parallel) with the slide grooves. Lock a board in the miter gauge and place against the front of the blade, and then the back of the blade. Is the distance EXACTLY the same (it won't matter if the miter gauge isn't straight and square). If not, you'll need to loosen the table and rotate the blade holder to square it up.
2) Now Cut a board in half the flip one side over and place the cut back together. If it isn't straight, the resulting board will have a "dog-leg".
3) Adjust the miter-set-screw until the cuts on the trial board yield a board that comes out straight (or use a Framing square to check).
Dec 31, 2009 | Delta 36 977 Left Tilt Contractors Saw
I have a 10'' table saw
If it cuts straight it's fine. It's likely just some play in the bearings. I wouldn't worry about it unless it starts to cut not so straight...
Oct 06, 2009 | Craftsman 10" Table Saw
Tapering
First, unplug the jointer, then, insure that all the cutters are set to the same height. Raise the outfeed table with a straight piece of wood or a framing square sitting on it and extending over the cutters. Each cutter should just touch the board without raising it. The infeed table is lowered by how deep you want to cut.
Always look at the grain of the board you are cutting. Never allow the cutters to strike grain that is running down into the cutters. It will chip out chunks of wood. The grain should be tapering down away from the cutters, back toward you, never toward them.
The tapering you mentioned usually happens when the outfeed table is lower than the cutter tops.
May 25, 2009 | Delta Machinery Masonry Tools
Table Saw Blade Won't Cut Straight
Inside the saw, on the end of the trunnion is a stop that is adjustable to zero the saw in to exactly 90 degrees. Either there is sawdust or something accumulated there or it needs to be adjusted. You say you cleaned it out, So you'll need to unplug it an have a look up in there. See how there's a geared piece of steel that moves when you crank the saw over to 45 degrees. Usually there's a bolt or stud with a locking nut on it, either on the trunnion itself or the lower surface of the table top. You need to break the nut loose and screw the bolt in or out to adjust, then crank the saw over to hit it, check for square with a known square, crank it all the way out of the way and readjust, etc. Until you get it right. Make sure to tighten that lock nut when you're done.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 02, 2009 | Craftsman 10" Table Saw
Adjusting the outfeed table on the Delta Model: JT-160
Sometimes you just have to shim them. If you've worked the gibs and can't get any more adjustment out of them, you might try buying some thin brass or copper metal stock (you can get it in rolls at Hobby Lobby) and use it as a shim to hold the table in the appropriate position.
It sounds crude, but that was the only way I managed to get my industrial 6" powermatic to true up.
Also bring the infeed table up to zero, aligned exactly with the outfeed table and check with a known true straightedge. This will help you to keep a clear idea in mind of which direction to move things when you're making adjustments.
If you can get the edges and diagonals straight, you're well on your way to straight cuts.
Make sure beforehand that the surface you're fixing to is flat and you're not clamping the machine down in a way that's torqueing the base.
Castings just aren't rested long enough these days before the surfaces are ground, and things twist a bit sometimes. You may be working with a surface not flat, and unable to get it perfect.
Good luck. I hope that helps a little.
You may need to use an auxiliary roller stand to support the outfeed of long boards to keep the weight from causing a droop that lifts the tail off the tables and prevents a straight cut.
Mar 12, 2009 | Delta JT160 Shopmaster 10 Amp 6 Inch...
Saws Logo
126 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
