Question about RCA Televison & Video
Can anyone help me I either need to enable hdcp 2.0 or 2.2 or how to just enable 4k picture on an RCA RTU4300 can't even get a answer for this model from RCA technical support they are a joke and don't even know their products this TV has no information about it anywhere and it sucks that I paid for a 4k TV and got lies instead lol
Posted by Kyle Keith on
  • Alexander Lonewolf Dec 19, 2019
    I have one and was thinking the same thing. Until I changed the picture settings from smart saver to standard. And also enhanced the 4k through the other settings link in the set up tab. Now I can watch 4k but only through hdmi 1 or arc input.
Raj Patel
    Genius:
  • 1,041 Answers
The TV will automatically display 4k content as long it receives a 4k signal through HDMI input or you play a 4k video on a USB device.
Posted on Mar 28, 2019
  • Kyle Keith
    Kyle Keith Mar 28, 2019
    Not always some TV's you have to manually set the HDMI port or allow certain protocols such as hdcp 2.0 of 2.2
  • Raj Patel Mar 29, 2019
    HDCP is an encryption method and the TV will have hardware to handshake with the sending device to authenticate the 4k signal. This authentication needs to occur within 7ms of the signal being received so a bad/cheap and/or excessively long HDMI cable can prevent authentication.
  • RCA Master
  • 18,397 Answers
First of all we cannot tell how you got to that screen. Was it an error that made that screen appear? How do you have it connected and what is it connected to? There are many devices out there that dont send out 4K to the televisions. You have to have 4K DVD players, cable boxes and channels! Etc.
  • 1 more comment
  • Kyle Keith
    It's the TV details screen on the Xbox one it has 4 HDMI port one is arc but can't find out which is hdcp 2 or 2.2 or even the factory menu there's no 4k option and no way to access hdcp settings
  • Kyle Keith
    The TV is an RCA AND THE MODEL NUMBER IS RTU4300 it's a 43 inch 4k UHD TV
  • Brad Brown Mar 29, 2019
    XBOX one X is 4K and XBOX one s is upscaled to 4 k. IF you are using a 4k game on the one x then it is true 4k, if it is on a one S then it is upscaled, if you are using a non 4 k game then the unit on both those xboxes upscales to psuedo 4k. IF you are using a straight xbox one then it is not 4K. There is no settings you can access in the television to affect that.
5 Related Answers
Anonymous
  • 277 Answers
SOURCE: "Input" button doesn't work
hi first of all it is not OUR Product this sites purpose is to Find a solution to a Product with problems we wish to help with your problem! there are some products wich the remote cannot work with you havent signed wuch model you want to control so this is my guess try this remote control code finder: http://remotefinder.rca.com/ enter the unit you need and hopefully it will work if the problem is in the "input" button itself then: 1) open the remote - screws 2) clean the surfaces and check for good connection 3) close good luck
Posted on Mar 21, 2006
Vista Electronics
  • 1694 Answers
SOURCE: RCA remote control model # CRK74BA3 specific information Magnavox T.V.
Try www.remotecodelist.com Hope that helps ........T.
Posted on Jan 02, 2008
Anonymous
SOURCE: Unable to use Sky HD Due to an HDCP
Try calling samsung they might have a firmware update they can send you
Posted on Dec 31, 2008
Anonymous
  • 6 Answers
SOURCE: "I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help""I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help"
Code For Model RCR311S Code 1003 for Panasonic TV Code 1054 for Panasonic TV Code 1062 for Panasonic TV Code 1109 for Panasonic TV Code 1170 for Panasonic TV Code 1248 for Panasonic TV GOOD LUCK THESE ARE THE CODES LISTED FOR YOUR REMOTE/
Posted on Jun 03, 2009
3764alan
Alan Spicer
  • 127 Answers
SOURCE: MY RCA DRC 8320n DVD Recorder/VCR Combo will not
Yah, you're going to be taking that in for repair. I worked for couple of years at RCA / Sony / Panasonic / ... and 60 more names - service center. When a VHS Cassette loading mechanism doesn't work - it probably needs loading motor or loading gear, something repaired. At the cost of DVD and VHS combos these days I'd call it Not Worth Repair (NWR) out of the starting gate. At least $50 an hour, at least 2 hours ... that's beyond the cost of a new one.
Posted on Nov 28, 2009
I bought a blueray player that only has HDMI out put but the older TV I have only has component input (red, white & Yellow RCA plugs) and an S-video input plug. Is there a cable that will connect
There are no cables that will do this. You will need a digital HDMI to analog (composite or S-video) converter box. The video output will drop from 1080p to 480i. Here's one option: http://www.gefen.com/kvm/gtv-hdmi-2-compsvidsn.jsp?prod_id=11402 . You will need the HDMI and RCA composite video cables separately. A cheaper version is here: http://www.amazon.com/Portta-Composite-Toslink-Converter-Blue-Ray/dp/B00GH92V8C . This one may need a power adapter purchased separately.
However, HDCP (high definition copy protection) will prevent you from watching some videos with the either of boxes. Most commercial Blue-ray movies have this Digital Rights management feature added to them. Some DVDs may be also have this enabled.
I hope this helps.
(unfortunately, the HDCP is written to block any viewing of content with analog monitors. You may be better off looking for a new TV or a PC monitor with an HDMI input. The lower end of these do not have speakers so you'd need PC speakers connected to the audio out on the monitor.)
Oct 15, 2014 | Televison & Video
Cannot connect my pc via hdmi to an RCA L26HD31. TV registers unusable signal. Is the set bad, or did this model not support hdmi from a pc?
If your trying to use a computer with a video card that is not HDCP capable it will not work.You'll need to replace the video card that has hdcp .You can thank Hollywood for that.Hope that helps
Apr 27, 2011 | RCA L26HD31 26 in. LCD HDTV
How do I connect this unit to HDMI.
HI,
for connecting HDMI input to ur tv you need a HDNI to DVI- HDCP converter. if u connect the the component video also u can enjoy a good picture.
ok
Dec 21, 2010 | RCA D61W20 61" Rear Projection Television
No video at all!
I recommend you switch from using HDMI cables to using component (R/G/B RCA-style) cables. HD picture is superior through component cabling, and solves several HD picture issues, including HDCP (High Def Copy Protection) through HDMI issue. Component cabling should eliminate this problem.
I hope that helps.
___________________________________________
Download Bose LifeStyle V30 User Manual
May 31, 2010 | Bose Lifestyle V30 Home Theater System -...
I recently purchased a blu-ray player and when hooking it up through the hdmi outputs, i cannot get a signal. hooking it up with regular rca cables works, but that's not what having hi-def is about....
That shouldn't make too much of a difference (or maybe im just being ignorant). If the bluray player was cheap, you may need to plug in via rca and then adjust the settings on your player to output to HDMI.
Hope this helps
Nick
Sep 02, 2009 | iLO Televison & Video
RCA model R61WH76 Chasis itc222 has 3 color curved band lines on
Your model doesnt have convergence ICs. You can get the replacement parts and free instructions on how to do the repair at the following link, just click on the contact us link on the lower left hand side of the website and tell them the model number and chassis they respond quickly.
http://servicemanuals.vstore.ca/
Apr 11, 2009 | RCA R61WH76 61" HDTV
Processing Board
go to the following link and leave them a email with the model number and what the problem is they have the parts youy need.
Jan 29, 2009 | RCA HD52W59 HDTV Projection Television
Screen dont work
proabably it,s because you left it on for long time , or the image power saver is wrecked and damaged after a storng lightinning , and if you have cleaned ther tv screen with a wet wiper it causes that to happen
May 11, 2008 | RCA P52937 52" Rear Projection Television
Dell w3000 & PS3
This may not be DVI issue.
I connected DVD player HDMI ----> DVI ( Dell W3000) LCD TV.
Later I found that Dell TV version of DVI does not support HDCP protocol ( High Definition Content Protection protocol). So I could not play HDMI to DVI movies from my DVD player instead I use Y Pb Pr -- this works ok.
Hope this helps... I am not use PS3 enforces HDCP - I assume Sony linked with Sony Pictures would enforce HDCP on HDMI cable.
Dec 27, 2007 | Dell W3000 30 in. HD-Ready LCD Television
Televison & Video Logo
96 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
