Question about Vizio Televison & Video
How do i fix my vizio tv the backlight must have gone out...i can shine a flashlight and see it working in there and audio works too and can operate it with remote but its dark without a flashlight. what do i need to replace? 55 inch vizio LED TV model E55Oi-B2E
Posted by Jimmy on
derekdorman1
    New Friend:
  • 11 Answers
Can't comment on the specific make but either the back lights gone. It's either tubes or LEDs. That or the driver has fault often a blown capacitor.
More info needed to be more specific.
Posted on Mar 28, 2019
Raj Patel
    Genius:
  • 1,041 Answers
marcelakis
    New Friend:
  • 35 Answers
Depends .. did you open the TV inside and found that the LEDs are burned?
Do not be the problem of the power supply, even if it burns a bar, it still remains the other light!
Maybe it's not all burned, and you only have one or two replaced, focus on their color, the most different in color or the dark even, the smoke etc. surely are the problem, easily break it off with a high temperature feeder applied behind it , or with a resistance that only gets warmed on a portion of 1 led.
I leave you a tutorial to see what and how.
https://www.youtube.com/watch?v=NI9wOZKHOVE
https://www.youtube.com/watch?v=4pK6o2DMLWQ
Vizio e65x-c2 led tv has no backlight but has sound and display works when shining a flashlight on it. What board should I replace?
Chances are its not a board issue but bad LED lamps in the panel, you can measure the voltage at the LED output from the power supply and see what you have there to get a better idea whats going on
Dec 14, 2017 | Vizio Televison & Video
Tip
Diagnosing a LCD blank screen problem.
Recently a 3 year old VIzio TV I bought started having problems. The set would turn on normally for a few seconds then the picture would go dark with everything else operating normally including sound. Remembering a similar laptop computer problem I diagnosed previously, I immediately suspected a defective TV screen backlight. To verify this in your own TV, get a very bright flashlight and with the TV operating in the failed blank screen mode, shine the flash light into the blank screen from various angles and distance (including touching the screen). If the LCD is still operating, you'll see a dim motion in the flashlight's reflection, thus proving it is indeed a failed backlight.
on Jan 27, 2015 | Televison & Video
I have a vizio 42 inch model VO420E serial# LUKECAK1409419. when i turn it on i get a black screen but i have audio. it does this in every input. what can i do to fix this problem?
Most likely you have a backlight problem. To verify this, dim the lights in the room. Take a bright flashlight, turn on the set, and shine it on the screen. If you see a faint picture, you have a backlight fault. Your backlight inverter may be built into your power supply board. If this is the case, you will have to replace the inverter/power supply board
Sep 01, 2013 | Vizio Televison & Video
Vizio VP50 has sound no picture
If this is an LCD TV, show a flashlight on the screen from a safe distance and check whether you can see the picture. If you can, the backlights or its circuits have gone bad. If you cannot, the TV needs attention of a qualified service technician.
Aug 12, 2012 | Televison & Video
I have a Vizio model E421VO LCD TV. The picture has quit working. I have soung and the Vizio light comes on but no picture. Any thoughts on fixes or cost to repair.
I would first try the good ole flashlight test. Turn off the lights in the room, turn on the TV and shine a bright flashlight on the screen. Do you see a faint picture?? I'm willing to bet you will, this is most likely a backlight failure. I'm willing to bet either the inverter or the 24Vdc power supply circuit has a fault. Do you have any electronics repair skills??
Jun 07, 2012 | Televison & Video
Unit turns on, I have audio but no picture. the little VIZIO does not light up anymore as well. If I shine a flashlight on the screen you can see the picture ever so slightly.....Any ideas?
Sounds like the Backlight has burned out. I would contact a Vizio Service Center and see about getting it fixed or replaced. http://www.vizio.com/support/ check there for the information you need.
Nov 03, 2010 | Vizio VW32L 32 in. LCD HDTV
Philips 50pf9631d/10 Audio ok but no picture
Bad power supply or backlight inverter.
If the backlight is not turning on, you should be able to see the lcd image by shining a bright flashlight at the screen.
Backlight inverters are loud, so you can hear them operating (high pitched whine) and if the backlight is coming on, you can see white light leaking around the edge of the screen, and even a little inside the cabinet.
Philips are legendary for having power supplies that fail due to bad capacitors, so that could be the culprit as well.
Oct 22, 2009 | Televison & Video
Picture went out on p50hdm Vizio Plazma tv after loud POP
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 26, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Televison & Video Logo
50 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
