Question about JVC Audio Players & Recorders
Model HA-EN10BT bluetooth earphones. Why can't I connect?
I've tried to connect, turn off and restart it, but nothing works, the light has been red for almost 4 hours.
Posted by Fake Emo Jace on
ray gallant
    Top Expert:
  • JVC Master
  • 72,099 Answers
RECHARGE IT
Posted on Apr 21, 2021
5 Related Answers
Anonymous
  • 138 Answers
SOURCE: JVC THM303 - No Sound
Its your wire connection problem. Plz check that all the wires are connected to specific location. If wiares are ok then it might be internal circuit error! that should be repaired at authorised service stations.
Posted on Dec 08, 2007
Anonymous
  • 57 Answers
SOURCE: RED BLINKING TIMER TV WONT TURN ON
Page 40 on the PDF link below may help - Ask me if you need further assistance.
Thanks
Len
http://resources.jvc.com/Resources/00/00/99/51798Cien.pdf
Posted on Feb 28, 2009
Anonymous
  • 47 Answers
SOURCE: Bluetooth is not working in Lenovo 3000 y500 notebook
Try restoring your computer to earlier time using System Restore,
on Explorer click Help menu - Help and Support Center and select Undo changes to your computer using System Restore.
Posted on Jun 06, 2009
Anonymous
SOURCE: I have a 52 inch
seems like the bulb has blown
Posted on Jan 10, 2011
youngdroop34
youngdroop34
  • 11 Answers
SOURCE: Motor won't engage. I turn the throttle and get a clicking sound, but nothing happens. We've charged the battery for about 4-6 hours, but the light stays red, never turns green. Help?!!
sounds like the battery is bad and not taking charge.replace battery attemp again if not then check for fuel, spark and compression.then c wat happens or wats not working any motor no matter how small or big has to hv those three things to run. hope this helps.
Posted on Jul 08, 2012
I have VIBE bluetooth keyboard for iPad mini ( VE 1089) and can't find ON switch
yes the red charge light will only stay lit for just a little bit... then turn it on by pressing down above the words written "charge". You should be pressing and holding down on a dial with three semi circles above it (as szuravic stated). Press and hold down until you get the bluetooth and power button lit on blue. Then go to your settings and bluetooth.... "bluetooth keyboard" should pop up. Click on it and then it will ask you to enter a 4 digit code on your keyboard followed by the return key. Soon after you should be "connected". If you are fully charged (first time plugged in should be 12 hours.. then after 4 hours) then you can unplug. Hope that's helpful!!
Feb 05, 2013 | Apple Ipad I-pad
I have a Sony Bravia LCD tv an it won't turn on at all the standby light is not even there I've tried turning on an off and leaving unplugged for an hour still nothing.? Help,
You either have a problem with your power supply board or main board. I would start with having the power supply fuse checked as well as the power supply board!
Jan 26, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Iphone stuck on itunes screen with usb
First power off your iphone and restart it does it start normally or not.
Secondly restart your iphone without connecting to computer. so remove usb cable and restart your iphone ipod or ipad. Even though iphone stuck all logo and itunes and usb symbol then it is a issue of original sim
Secondly when you connect iphone to computer and it detected as recovery mode then your ipod iphone is not properly restored. Here is how to restore ipod / iphone or ipad.
Jun 26, 2017 | Apple iPhone 3G
Jul 08, 2012 | Electric Razor Pocket Rocket Ride-on...
My Plaroid FLM-3201 LCD Television takes 4 hours to come on.
I agree with tom you need to replace all the electrolytic capacitors. It is not that difficult if you know what you are doing. If not take it to a tech savvy friend..
Aug 26, 2017 | Polaroid FLM-3201 Television
When i turn on my prs 300, the screen flickers and the light on top is yellow. when its done trying to turn on the light flashes a few times and thats it.. i've tryed several computers and they cant...
Hi jmjohnson198!
1. Connect the reader to the AC Adapter (If available). If not, then connect the Reader via USB to the computer
2. Hit the reset button for 3 seconds.
3. The red steady light should come on, if not, try the reset again while the unit is connected
4. Allow the reader to charge for 40 Minutes (on PC make sure the computer does not go into sleep mode.
5. Disconnect the reader and see if operational.
GoodLuck!
eBookBoy
http://digialreader.freeforums.org
Jul 16, 2011 | Sony Reader Pocket PRS-300
Red light turns on and off while charging e-reader 600
Okay Plug It In And Let The Red Light Turn Off By Itself Then Get A Tooth Pick Or Any Item That Will Go In The Reset Hole Then Pug it In Again. The Red Light Will Still Be On But After Five Minutes Unplug It Turn It On The Light Will Be Yellow Then Turn On .
Jun 07, 2010 | Sony E-reader Portable E-book MP3 Player
My flip video camera froze.it wont turn on....
Have you tried resetting the camera? Hold down the power button and the red button simultaneously until the camera shuts off (takes about 10 seconds). Then, just press the power button again and the camera should turn back on. I had the same problem; when I pressed the red button to stop recording, the camera froze, and the red light remained on. I tried resetting it like this, and it seemed to work.
Jan 19, 2009 | Pure Digital Flip Video Ultra Camcorder
My Blackberry 7290 won't turn on
Have you tried to remove the battery and then restart the phone?
I’m happy to assist further over the phone at https://www.6ya.com/expert/lou_afa492c634393790
Nov 11, 2008 | RIM BlackBerry 7290
Tv wont turn on
stephster, check to see if you have a reset button on the back of tv good luck-hope this works for you
Nov 05, 2007 | Panasonic CT-36HL43 36" TV
Top JVC Audio Players & Recorders Experts
xxxxxx xxx
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
