open the access to the pump and make sure thats its clear and that there are no foreign objects blocking the impellar from spinning. Unit will not start if drain pump is clogged
turning it off at the power source then back on again after 15 minutes Should be plugged in, possibly under your sink, or if you know what breaker it's on you can turn it off there.
Hi Error F2 in asko dishwashers indicate high water level.
This may happen due to plugged drain pump or due to faulty water inlet valve.
To resolve the issue remove the back plate and check the drain pump. Disconnect
the hoses from the drain pump and clear the lint from the hose and the pump
area. Lot of water would be there when you'll
remove the hose from the pump, be ready to collect it. Let it dry and now the
dishwasher will work perfectly now. Hope it helps... Daniel
Hi Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be ther when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now. Hope it helps... Daniel
I believe the washer has had a flood type situation.there is normally a flood switch in the very bottom of the dishwasher right at the very floor,if water get into the bottom tray it floats a piece polystyrene foam wich triggers a little micro switch wich will run the pump continually & show Overfilling fault at the same time..The water in the tray needs to be mopped out with a rag or spunge so that the styrene foam can drop back down.The blockage you had may have caused this flood situation some how.The overfill fault was probably due to the washer not pumping out,So that may be ok now that you have cleared the blockage.hope this helped.
If water gets onto the pan under the dishwasher, there is a styrofoam float that rises and hits a microswitch that causes the dishwasher to drain constantly so that you don't get a flood in your kitchen. Mine has done this when I splashed out water from a bowl that had overturned during the wash and was full of water and when I had some water deposits built up on the door seal that let water through. Sometimes the foat will hang up and I have to wiggle it around to get it to fall back down.
