Question about Samsung Televison & Video
I have a samsung diamond drum 8kg washmashine (WA80G5.)Every thing works fine when setting it up, but the play button does not respond. nothing happens when it is pressed.
Posted by Casper du Plessis on
ray gallant
    Top Expert:
  • Samsung Master
  • 68,282 Answers
CALL A LOCAL REPAIR SERVICE WASHING MACHINES DO NOT HAVE A PLAY BUTTON
Posted on Mar 29, 2019
5 Related Answers
Anonymous
  • 38 Answers
SOURCE: Nothing happens when you press "Start"
PLEASE CHECK IF DOOR IS CLOSED PROPERLY THOSE HOOKS ON THE DOOR ACTIVATE SWITCHES ON THE INSIDE OF MWAVE OPEN COVER AND CHECK IF HOOKS ARE MAKING CONTACT WITH SWITCHES .COULD ALSO BE TOUCHPAD FAULT YOU WILNEED A TECH
Posted on May 09, 2007
Anonymous
  • 3 Answers
SOURCE: screen frozen calculator not responding to buttons pressed.
give it a factory reset, this works, you will lose any unarchived data : http://www.associatedcontent.com/video/265/how_to_reset_a_texas_instruments_ti89.html?cat=59
Posted on Sep 03, 2008
Anonymous
SOURCE: After pressing the button nothing happens
I had the middle button stick on my B60. I called Kuerig and they sent out a new unit to replace the defective one.
Posted on Nov 18, 2008
Anonymous
  • 25 Answers
SOURCE: wii rockband drums wont sync
the wii drums dont work on the xbox 360.
Posted on Jun 09, 2009
Anonymous
  • 10 Answers
SOURCE: drum set for xbox 360 rock band 2
to sync: hit the sync button on the drum set and the xbox at the same time, you may have to hold the one on the set.
other problem: make sure you have good batteries in it, make sure the set is synced with the television, go into the freeplay mode under the drum trainer and do a drum roll on your yellow pad- if it skips some notes you either have to deal with the bad pads or you can send it in or get a new set all in all
Posted on Jun 21, 2009
I think the maid dropped a small garment between the drum and the outer casing. Imposible to get my hand in there. When I tiltbthe drum I can feel it not moving all the way to the front wich suggest...
I would say, if there's something in there, the drum will have to be removed. Not an easy job.
You could try www.searsdirectparts.com
They have free diagrams and parts "blow-up diagrams.
They'll even fix it for you.
Mar 30, 2015 | Washing Machines
8.0 kg wa10f4 samsung diamond drum
I NEED TO KNOW WHAT SHOULD I DO WITH MY SAMSUNG 8.0KG WA10F4 DIAMOND DRUM IF THE WATER FROM THE TUB IS NOT DRAINING..AS IF THERE'S SOMETHING STOPING THE WATER TO FLOW
Jun 02, 2012 | Samsung Washing Machines
No signal from Diamond VC500 Capture Device
I have a similar problem. Sometimes it works fine, but it will often have sound but no picture in the box. Other times, there is no input signal showing when I click on the gear wheel to adjust settings. There is no rhyme or reason to the missing picture. Whe I play it back, I do have the picture - usually.
Jul 18, 2010 | Diamond Multimedia ( VC500) Video Capture
My Samsung Washing Machine (Diamond Drum model) problem
You probably did not save the mode you want. See the information booklet provided on how to set the mode.
May 25, 2010 | Samsung Washing Machines
2 synch lights on ALL music controllers after PSN v2.8 update
You have to manually sync the instruments. While playing press the PS button go to settings, accesory settings and assign each controller individually a number from 1-4.
Jul 04, 2009 | Nintendo Guitar Hero Wireless Guitar - Wii...
DVD will not play when the play button is pushed
call support from manufacturer on how to reset your player,
For instance, on Samsung players after it is powered on you hold in both channel buttons for 10 sec and the player restarts. that fixed mine that had the same problem
Apr 11, 2009 | Toshiba SD-2109 DVD Player
Help! I can't get my Diamond 923SD to work
have a Diamond MP3 player that I have not used for a while. After dusting it off and plugging it in my USB, it tells me that the device is not recognized.
Jul 20, 2008 | Nefertech Diamond MP3 Player
Televison & Video Logo
Muntejaya Ginting
Muntejaya Ginting
Ekse
