Question about Jensen Car Audio & Video
How to adjust speakers on jensen 8800bt - Jensen Car Audio & Video
Posted by Bokkie Grobler on
Jack Reacher
    Habit-Forming:
    Scholar:
  • 33 Answers
The writing was on the wall (pardon the pun) in 2008 when our founder designed and released the first In-Wall speaker. 5 Ranges and 9 years later, In-Wall and In-Ceiling Speakers have evolved and morphed into Hi-Powered In-Wall systems with Glass fronts never seen anywhere in the world before. Beauty and Grunt! Front speakers (some with inbuilt Centre Speakers) have been designed mainly for high powered Hi Fi and Stereo application providing clean, accurate balanced performance with deep, strong Bass.
You need of any our Technical Support agent. Please call Technical Support team at +44 203 880 7918 our experts are available 24/7 by phone.
https://www.customersupportcare.com/dell-printer-support.html
Posted on Mar 28, 2019
Testimonial: "Why must I telephone when the answer can surely be posted on the net?"
How do I turn off the outside speakers on the Jensen JCD2010 installed in my travel trailer?
Press the volume control to access the audio menu. Navigate through the audio menu by pressing the volume control button repeatedlly until you get to Fader. Then adjust the Fader to by turning the volume button to either 9R or 9F. In my trailer, 9R is for inside listening, only.
Jun 15, 2014 | Jensen JCD2010 AM/FM/CD Stereo
I don't know how to set the clock on the jensen jbr550 radio in my bus
To set the clock, turn the radio on in tuner
mode (or any other mode).
Press D. The time appears on the display.
Press and hold D until the time display
begins flashing.
While the display is flashing, press the Up
Tuning button to adjust hours and the
“A” (AM) or “P” (PM) indication. Press the
Down Tuning button to adjust
minutes.
After five seconds, the time will set and the
display will return to tuner or CD display.
Aug 18, 2010 | Jensen Car Audio & Video
I have a Jensen DVD media pro 5000 hooked up to a ViewSonic TV in my Camper Trailer. Camper Trailer was purchased with DVD Player and TV in it. At night, due to child sleeping, I would like to be able to...
hi yes you can do this press AUD button near the on/off/volume control momentarily to step through the following audio adjustment options volume, bass,treble, balance (left to right) and fader (front to back). when the desired option appears in the display, rotate the volume control knob to adjust that audio feature. When no adjustments have been made for three seconds, the unit will resume normal operation. so you can fade the speakers to however you want them...hope this helps
Aug 03, 2010 | Audio Players & Recorders
I have a jensen cd6112 radio vol control is not working also will not change bass/tre/ or speakers.Tried reset button but no change .Vol knob won't do anything.
I was installing a speaker and while drilling a spark flew. Didn't think anything of it and finished instalation. When finished the audio didn't work on any of my speakers. I have a jensen cd6112 and the unit seemed to be fine. Tuned in, the lights came on and everything. I hooked a radio straight to the speakers to see if they were blown and they worked fine. Is there a fuse in line with the speaker wires? I would hat to buy another jensen unit and the same problem exist. Any help? Is the jensen unit bad?
Jan 05, 2010 | Jensen Car Audio & Video
Is the Jensen car speaker model cv 650 a 4 OHM spreaker? I'm trying to match a 4 OHM subwoofer.
It should be a 4 ohm speaker as this is the standard impedence for car audio speakers. Jensen does not produce car audio speakers with any other impedences.
Jun 21, 2009 | Car Audio & Video
Left front and rear speakers sound muffled when playing cd's
after you play a cd while the cd is playing go into your audio settings and adjust theres settings foe each part on a stereo if u set the audio for AM//FM then play a cd the stereo changes to the cd settings
Jun 01, 2009 | Jensen Car Audio & Video
Jensen JMP 50 sounds like I am in a tunnel or well.
Have you powered up the speakers have you checked the sound drivers?? but remember the sound of the Jensen JMP-50s is a bit hollow and lacking in bass, and the speakers do lack bass and treble controls, which can often be found in other speakers in the same price range.
Aug 18, 2008 | Jensen JMP-50 Computer Speakers
Jensen Bass Boost CR220x
white/black is speaker positive
white solid is speaker ground front and back ground
gray/black is speaker ground front and back
the solid black wire is battery ground
Apr 13, 2008 | Jensen SCR-60 Stereo Cassette Player with...
Jensen Subwoofer JPS-10
This sound is made by the automatic shutdown in the speaker. Jensen repaired my unit under warrantee.
Aug 27, 2007 | Jensen JPS10 Subwoofer
Car Audio & Video Logo
43 people viewed this question
Top Jensen Car Audio & Video Experts
Larry Tezekjian
Larry Tezekjian
Muntejaya Ginting
Muntejaya Ginting
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
