Question about Freezers
I have a upright haier freezing not freezing - Freezers
Posted by Ronald Hatchett on
  • Michael Youngman
    Michael Youngman Mar 28, 2019
    Look to see if you have ice build up on the back panel of your freezer on the inside. If you do, chances are something in defrost cycle has failed. If you don't, you'll need to see if the compressor is running. Either way, you'll probably need someone to come out and look at it.
Michael Youngman
    Sergeant:
  • 296 Answers
Posted on Mar 28, 2019
I have to push on my freezer door to keep the blower running
there is a loose connection at the rear of the freezer near or around the compressor unit , i strongly advise you to get a professional to look it.
Regards
Dec 16, 2012 | Haier Freezer HUF168PA 16.8 Cu. Ft....
Have a Haier 5.3 cu.ft. about 1.5 yrs. old. It freezes ok and cycles off ok, but it doesn't cycle back on unless I tap it near the control. If it doesn't call for more cooling it won't cycle on...
The thermostat is bad....
You will need to replace that t-stat..
That is not that hard to fix and you can easilybuy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
May 17, 2011 | Haier Freezer HUF168PA 16.8 Cu. Ft....
Deep freeze compressor not kicking on.
Sounds like the relay contacts are staying open.
Jul 29, 2010 | Haier Freezers
Haier freezer and it wont freeze what should i do?
dear sir/madam
please make sure your freezer,s tempreture sensore is right location .if it,s alredy is in right location then reset the selectore swith to turn off and again turn possition.
hope answer the question.
thank you
Jul 03, 2010 | Haier 3.5 cu. ft. Chest Freezer HNCM035E
Freezer not cold enough
check to see if the coilf has a full frost pattern
May 24, 2010 | Haier 13.6 cu. ft. / 385 liter Upright...
MAKING A LOUD CLICKING SOUNDS
Hi, I am not familiar with this model but the noise sounds like a relay clicking at the compressor. Is the sound coming from the outside in the back?
Please let me know if I can assist you further.
Thanks
Vic
May 24, 2009 | Haier 9.1 cu. ft. / 258 liter Upright...
Haier HUF138PA-Freezer not freezing
just bought one that a repair man had already been through with similar issues. i wanted it as a fridge so this was no problem. took me about 5 minutes to figure out the reason it wasn't freezing though...the switch at the top that turns the light on when you open it also turns on the fan when you close the door. the door however sits just a tad too low to fully engage the switch. put a piece of tape over the switch and let it cool for 24 hours. chances are this will solve your problem!
Jan 10, 2009 | Haier 20.5 cu. ft. / 580 liter Upright...
New freezer has bad door seal
it often works to warm the seal with a hairdryer and reshape it
Nov 29, 2008 | Haier Freezer HUF168PA 16.8 Cu. Ft....
Freezers Logo
148 people viewed this question
Top Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
