Question about Hotpoint Dryers
I have a Hotpoint Gas Dryer DLL1550RALWN The motor will not start?
I need to know how to get to the motor and remove it
Posted by Nelson Collar on
Chris Huff
    Top Expert:
  • Hotpoint Master
  • 6,289 Answers
Check door switch and thermal fuse first.
Posted on Mar 28, 2019
poizniv
    Problem Solver:
  • 13 Answers
"The appliances that are being made now are only made to last around 5 years." That's quoted from a top name brand appliance dealer. The parts if you can find them are so high priced that it's better to just get a new one especially if you have to have a service call. I'm sorry I'm not help... It's just how they're profiting off of people now, by not making parts available and making them so flimsy that you have no choice.
Good luck... Sorry
jws1013
  • 1,708 Answers
Best to contact the manufacturer or an appliance repair service. This is a car forum and we wouldn't have knowledge on you gas dryer.
Remove hoover vacuum fan
I don't know what model you have but on most vacuums you need to remove the nozzle housing from the vacuum, remove the cover over the motor to gain access to the motor. Remove any screws holding the motor in. Remove the motor and take the screws out to allow access to the fan. Remove the fan, replace and put back together exactly as it was before.
Nov 09, 2015 | Hoover Vacuums
How to change2003 dodgecaravanheater motor front
You need to remove the heater unit. Then remove the top of the heater motor and then the motor is held in by 3 screws.Remove these 3 screws to remove the motor.
Let me know if you need more information.
Thanks
Jason
Oct 24, 2011 | 2003 Dodge Caravan
Need to know how to replace front wiper motor
Go to auto zone an ask them to print it out for you i know they got it in the computer
Sep 03, 2011 | 1996 Mitsubishi Eclipse
Hi, i need to remove and replace the blower motor for the a.c./ heater, and dont know where it is located. can you please help?
Blower Motor Removal & Installation To Remove:
  1. Remove the insulator from under the right side of the dash.
  2. Disconnect the electrical connector from the blower motor.
  3. Remove the blower motor retaining screws.
  4. Remove the blower motor.
To Install:
  1. Install the blower motor.
  2. Install the blower motor mounting screws.
  3. Connect the electrical connector to the blower motor.
  4. Install the under dash insulator.
Dec 10, 2010 | 1999 Pontiac Grand Prix
My brushes on my aquarius wma54 need replacing,where is the motor and how do i change the brushes.what type of motor is it
The motor is located at the bottom rear of the washer.
Remove lower rear panel, unplug lead into motor,, remove earth wire.
Remove 2 bolts holding motor to drum, lever motor away from you to remove.
Brushes are located at the end furthest away from the pulley.
There has been more than 1 type of motor fitted to this model, so until you remove the motor, you will not know which brushes you need.
Nov 09, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Need to know how to replace the windshield wiper motor
First remove the wiper arms.Then remove the screws that hold the black plastic grill, you will see the motor.You will need then to disconnect the wiper arm transmission linkage from the motor, then remove the three bolts holding the motor on, dont't forget to disconnect the electrical connector from the motor.Install in reverse order.Good luck.
Jul 20, 2009 | 1999 Chevrolet Silverado 1500
How do I remove and replace Corolla 2006 blower motor?
Well the blower motor is underneath the dash on the passenger footwell, you have to remove the glove compartment to gainaccess to the blower, it ahas 3 or 4 bolts holding the motor, remove and replace with new unit, it is a good idea to replace the filter once the motor is removed.
Jul 16, 2009 | 2006 Toyota Corolla
Need to replace the blower motor on my 2002 silverado
2002 silverado as follows :
1. if equipped , remove the sound insulator panel , remove the blower motor insulating cover screws , disconnect the electrical connector from the blower motor , remover the blower motor insulating cover , pull the retaining tab down while turning the blower motor counter clockwise in order to disengage the blower motor from the HVAC module , remove the blower motor .
2. to install blower motor , reverse the steps .
thanks for voting.
Dec 28, 2008 | 2001 Chevrolet Suburban
Motor removal and replacement on a kenmore electric dryer 90 series model# 110.86984110
remove screw at each end of console. pull & flip back out of way. remove top, remove bottom panel, slide putty knife to release both retainer clips. remove screws to remove door panel assy. remove belt, remove drum. remove motor clamps & remove wires from motor conector.good luck.
Aug 07, 2008 | Dryers
Sewng machine motor housing
DISASSEMBLY TO INSPECT OR CHANGE BERNINA 830 MOTOR BRUSHES:
Remove the big plastic cover piece on the bottom of the machine with the single screw in the center.
Remove the machine's end panel by removing the single silver screw from underneath the bottom middle of the side panel. Pull the bottom of the side panel out and down to remove it. It comes off easily.
Remove the two screws under the motor assembly (silver screws with black washers).
Swivel the motor assembly enough to remove the belt.
There is a another plastic panel on the motor assembly over the motor itself. Remove the two phillips head screws to remove this panel.
At this point you can see the commutator and inspect the "business" ends of the brushes. (In our case, one brush was almost gone and there was nothing left of the second brush except the spring!)
You can then slide the motor out of the housing. I pushed on the motor pulley and pulled on the other end of the motor with pliers. The motor comes out rather easily, but be careful not to disturb the wires any more than necessary.
With the motor exposed, unscrew the caps over the brushes and remove the brushes.
Our motor's commutator looks significantly worn and the motor may need to be replaced. If you find a source for the brushes or a replacment motor, please let me know! Thanks, John [email protected]
Jan 27, 2008 | Bernina Activa 130
Dryers Logo
64 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
peter gittos
peter gittos
Marvin
Marvin
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
