Question about LG Refrigerators
How to get cover off of replacement fixture to replace lightbulb in LG refrigerator LFD22860Sw
Original refrigetator light assembly caught fire & burned, so new one was installed. One of 2 bulbs burned out
Posted by gloria simon on
Michael Youngman
    Sergeant:
  • 296 Answers
Here is a video to help you.
https://www.google.com/search?q=lg+LFD22860Sw+light+cover+removal&oq=lg+LFD22860Sw+light+cover+removal&aqs=chrome..69i57.14878j0j4&client=ms-android-verizon&sourceid=chrome-mobile&ie=UTF-8#kpvalbx=1
Posted on Mar 28, 2019
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: 2004 Civic dome light bulb replacement
Honda Civic 2004 engine tempreture gauge in car not working, the rear windows screen water, and the bottom set of lights on the auto gear stick, 3D 3 2 1 not workin. I checked the fuses and they seemed ok. Any ideas
Posted on Jun 15, 2008
Anonymous
  • 203 Answers
SOURCE: 2006 V70 low beam bulb replacement
can be fiddly but if you get the old 1 out you should be able to get the new 1 in. tip use a small mirror. joe
Posted on Nov 23, 2008
Marc Podeszek
  • 840 Answers
SOURCE: 2004 Maxima driving / fog light bulb replacement
if they are near the bottom of the bumper the only way is take the lower shield off and drop the lt and rt splash shields
Posted on Jan 25, 2009
ghost4548
Paul McGrath
  • 776 Answers
SOURCE: Fog Light Bulb 2008 Elantra
Simple to do.
Posted on Jun 20, 2009
morse008
Duane Morse
  • 1111 Answers
SOURCE: how to replace the right rear tail lightbulb rx330
can you not see the bulb itself i believe they come out through the back
Posted on Sep 07, 2009
LIGHTS STAY ON IN FRIDGE
LG had a problem with the control board going bad allowing the interior lights to stay on even when doors are closed. you need to get in touch with LG concerning repair MY UNDERSTANDING is there is a safety recall and it will be repaired for free. in the mean time unsrew the light bulbs so they dont melt down your liner...
Oct 03, 2012 | LG Refrigerators
G6 dome light assembly replacement
This is for the Pontiac G6, 2006 Model year. Remove the Dome Light cover and Lens using a flat screwdriver or fingers, (fingers are best to avoid damage to the plastic). The lighting fixture uses a magnet to attach to the roof. Pull down and detach the fixture, gently as not to damage the roof's fabric. The switch's wiring harness attaches to the fixture by a 4 pin plugged connector. Use a small flat screwdriver to pry the tab up, off of the clip to release the wiring plug from the fixture. Use the reverse order to reinstall after repair. Good luck
Jul 06, 2012 | 2006 Pontiac G6
Fresh food section lights work intermittantly. either door switch can make light flick on and off. could both switches be bad?
I had the same thing happen to my LG LFX25950SB French door style. It is out of warranty but when I called 1-800-243-0000 LG customer service, they were very helpful. The CSR instructed me to take the lightbulbs out and he scheduled a service tech out within 5 days. No charge for parts or labor. I must admit I am impressed.
Jan 28, 2011 | LG LFX25960ST Stainless Steel French Door...
LG LRFD22850SW light won't go out!
if you stay on the line and dont take no for an answer
they just might cover it for you
make sure you mention several times its a fire hazard
and just dont take no for an answer
Oct 08, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
The refrigerator light will not turn off when the door is closed. How do I fix that?
THIS PROBLEM IS A SERIOUS FIRE HAZARD!!! And, apparently, it's a common issue -- one we had as well. Remove the bulbs immediately and call LG, stressing the fact that it is getting hot in there.
For us, they sent out a replacement circuit board and cover for the lights because the original one had MELTED.
Oct 04, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Overheated melted light cover could this have caught fire?
This is not a recall but the manufacturer will most likely cover the repair. The relay for the lights is stuck closed on the control board. The repair should include all cosmetic parts that were damaged plus a new improved control board and a new socket assembly with a thermostat built-in. Contact your local certified service depot for the repair.
Apr 18, 2009 | LG LRFC22750ST French Door 22.4 Cu. Ft....
Refrigerator caught on fire
you have to check the socket of the bulb on plug the unit before checking
Mar 31, 2009 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
59 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
