Question about Lands Phones
How do I change the Outgoing voice Message for not at home
Panasonic DECT 6.0 hand set KX-TG8051C
Posted by William Robert... on
ray gallant
    Top Expert:
  • Lands Phones Master
  • 68,329 Answers
Read your owners manual it took me several tries on my uniden system
Posted on Mar 28, 2019
5 Related Answers
Anonymous
  • 1463 Answers
SOURCE: reprograming my voice message for incoming calls
hi
you can get a downloaded manual from here
http://theusermanualsite.com/manuals/mfg/panasonic/panasonic_kx_tg2257_kxtg2257.html
hope it helps
riz.
Posted on Oct 25, 2007
Anonymous
  • 12 Answers
SOURCE: panasonic KX-TGA1018 DECT 6.0 cordless
see manual on website below
http://service.us.panasonic.com/OPERMANPDF/KXTG1032.PDF
Posted on Jul 15, 2008
Anonymous
  • 4 Answers
SOURCE: OGM (Outgoing Message) setting for KX-TA616
yes u can
Posted on Feb 26, 2009
Guru Guy
Ken Shepherd
  • 95 Answers
SOURCE: I HAVE PANASONIC MODEL NO. KX-FLB802. THE PROBLEM
In this order, press:
menu - # - 9000 - * - 550 - set - menu
then also:
menu - # - 459 - 1 - set - set - menu
Posted on Oct 14, 2009
Mike Meder
  • 259 Answers
SOURCE: Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Posted on Nov 23, 2011
    Setup with new phone m/n kx-tgf372/kx-tgf373
    Follow the instructions beginning on page 11 of the manual. If you need a manual, you may view/download it at Panasonic KX TGF372S DECT 6 0 Expandable Cordless Phone System with...
    Nov 02, 2016 | Panasonic KX-TGF372S DECT 6.0 Expandable...
    Change answering machine message
    Follow the instructions on page 37 of the manual. If you need a manual, you can get it from 2 Line DECT 6 0 Expandable Digital Cordless Answering System with 2...
    Aug 30, 2016 | Panasonic KX-TG9382T 3 KX-TGA939 2-Line...
    How do I leave a message for my answering machine
    Ask the service provider
    Panasonic KX-TG6531B Digital DECT 6.0 1X Handsets Dual
    www.fixya.com/.../p3148769-panasonic_kx_tg6531b_digital_dect_6_0...
    Recent Panasonic KX-TG6531B Digital DECT 6.0 1X Handsets Dual Voltage Cordless Phones Integrated Answering Machine 110-220 Volts questions, problems & answers. ... Model KX-TG4021 - How do I put in a new answering message? ... Why won't my answering machine, Panasonic Easa-Phone KX-T1460 allow the ...
    change amount rings panasonic kx tg7643 Answering ...
    Jan 12, 2016 | Panasonic KX-TG6531B Digital DECT 6.0 1X...
    Dect 6 cordless phone repair - repair panasonic KX-TGA106M
    We regret reading about your telephone handset. At this time we recommend you have the unit evaluated by an authorized service center.
    www.panasonic.com/repair
    Apr 30, 2014 | Panasonic Kx-tga106m Dect 6.0 Cordless...
    How do I register my cell phone KX-TG254 SK
    Try pressing [MENU] [6] [2] [4] [1] on your handset and then pair your phone to your cell phone's Bluetooth.
    Oct 22, 2013 | Panasonic KXTG254SK KX-TG254SK KX TG254SK...
    Let our Experts solve your "Panasonic tga101cs base will not play back messages The message is recoverable from the 3 hand sets" Problem
    I've just got a 2nd system of 3 handsets (KX-TG1033, DECT 6.0). I have also the same sytem in my house. Is it possible to expand 3 new hansets (number 4,5 and 6) to my existing base unit?
    Mar 23, 2009 | Panasonic KX-TG1033S Cordless Phone
    Need instructions for setting up phone MODEL KX-TG9343T. ESPECIALLY ANSWERING SYSTEM, SETTING CLOCK AND DELETING ANSWERING MACHINE CALLS.
    For the manual, go here =>
    http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/DECT-6-0-Phones/model.KX-TG9343T
    For the accessories, go to the same link above.
    Click on Parts and Accessories Tab.
    Then scroll to the bottom and Click on Parts Link labeled "See Parts Available For This Model"
    If the link does not work, start here =>
    http://www2.panasonic.com/consumer-electronics/support/Operating-Instructions
    Nov 07, 2008 | Panasonic Lands Phones
    Lands Phones Logo
    64 people viewed this question
    Top Lands Phones Experts
    Ekse
    Marvin
    Marvin
    Are you a Lands Phone Expert? Answer questions, earn points and help others
