Question about Stihl Saws
All good answers here. If you have spark and it just quit running sounds more like water in system. The carb cleaners should help but you may need to run quite a bit through it. Remember to use care adding gasoline to avoid getting water into the tank. Also keep your tank full in storage to avoid condensation. In storing tong term add some sea foam and dump it out when you restart. Old gas turns yellow.
Posted on Apr 04, 2019
SOURCE: Stihl FS 110 brush cutter loop trimmer
Check the fuel filter, you are not getting fuel so therefore the spark is not getting anything. You can also take some carb cleaner and clean your carb. This is a common carb issue and it needs either a new filter(recommend) and also some carb cleaner shot through the system
Posted on May 18, 2009
SOURCE: makita DPC6400 stone cutter not starting. Seems to
saw just stopped running will not start seems easy to pull though
Posted on Nov 17, 2009
SOURCE: trying to start a stihl ts 400 disc cutter i
Try cleaning the plug and spray some starting fluid in the carb.Hope this helps and Thank You for asking!!!
Posted on Jul 19, 2010
SOURCE: not getting spark when starting
[email protected] HI GRYDERT your problem could be your on, off switch. This might sound funny, but switch the on off switch real fast several times, then see if you havee fire. If not check your spark plug. If you have a n
ew one try it. If that don't work check the connection at the plug to be sure it is makiong contact with the plug. If all this does't work you will have to go inside to the coil. They don't usually go ba d but it could. But first check to be sure it isn't grounded at the small wire from the switch. Good Luck.
Posted on Jul 01, 2011
if this machine ran ok before this problem,and no one has adjusted the carb,then i would check the crank seals.i have just had this problem.and it was the seal on the puller side,though i replaced both whilst i was at it.hope this helps my freind.
Posted on Jan 30, 2012
Jul 23, 2016 | Stihl Saws
Feb 16, 2016 | Stihl Saws
May 08, 2014 | Stihl Ts 410 420 Cut Off Saw...
Apr 23, 2014 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Apr 13, 2014 | Stihl Ts 410 420 Cut Off Saw...
Dec 31, 2013 | Stihl Ts 410 420 Cut Off Saw...
Apr 16, 2012 | Saws
Jul 19, 2010 | Stihl Ts 700 Cut Off Saw Model Name Plate...
Mar 24, 2010 | Oregon Scientific Complete Carburetor for...
Oct 16, 2009 | Makita DPC6410 64cc 12" Power Cutter
May 08, 2018 | Stihl Saws
278 people viewed this question
