Measuring Tools & Sensors Logo
Question about Measuring Tools & Sensors
How do you change the "measurements" on a pair of Fuzion RT-1000 professional digital pocket scales from ct to g? That is a pic of them in ct. I cant get them off that...
Posted by Devon Turczyn on
Fuzion digital pocket scale manual please model number fz1000
I have a fuzion tank digital scale and need to recalibrate it and I don't have the weight what else can I do
SC-501 scale weight measures in Kilograms instead of centameters
Since centimeter is a measure of length, it would be difficult for any scale to measure weights in centimeters. It would be like asking a ruler to measure a length in kilograms.
1helpful
Fuzion RT500 professional digital mini scale user manual
Starting with the unit off. Press the power button and hold down until it starts to cycle through the weights.
How to fix an easy weigh digital scale
the 24c02 is a memory chip inside. Unless your a tech - you can't repair.
2answers
DigiWeigh pocket scale showing..UnSE code..what is UnSE code?
Remove the battery - this happens when the scale tries to use a dead battery instead of the wall power supply.
When i turn my scale on it reads, "24C02" for
Why would it do that after you change the batteries though? Im having the same issue
What to do
have you tried removing the battery then insert it again? if not please do try. thanks.
Top Measuring Tools & Sensors Experts
Tom Chichester
ADMIN Andrew
ADMIN Andrew
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
