Question about Sony Televison & Video
How to set Remote control ( Yamaha RAV367 ) with Sony TV ?
Posted by Michel Robitaille on
    Top Expert:
  • Sony Master
  • 76,352 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
{View the site in web view by Mobile or a desktop to see the search box. Mobile view has no search box.}
Posted on May 17, 2019
5 Related Answers
IrishDruid
Swilin Sampson
  • 2712 Answers
SOURCE: REMOTE CONTROL SET UP CODE
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
Anonymous
  • 29 Answers
SOURCE: UNIVERSAL REMOTE Needed for TV, Home Theatre System & DVD Player
Try maplin...there are a number of 'ONE FOR ALL' remote controls which will do your tv, radio, sky box, cable what you will have to do is program it with the codes for the particular item. the codes are usually supplied in the user manual with the remote.
Posted on Nov 28, 2008
dvinnedge
Dale Vinnedge
  • 35 Answers
SOURCE: Remote Control codes to control other brand devices
i have sony receiver codes 31759, 30158, 31758,
or 4 digit codes 0158 and 1758
Posted on Dec 04, 2008
Anonymous
SOURCE: NEED CODE FOR SETTING GE UNIVERSAL REMOTE FOR SONY TV
I HAVE A GE UNIVERSAL REMOTE AND I NEED THE CODE TO PROGRAM A SONY TV
Posted on Jun 15, 2009
hoodpeter
hoodpeter
SOURCE: YSP: Need remote code for TV Sony Bravia KDL-46W4500
I have the sony KDL 46 EX720 and got the code 2751 to work.
Posted on May 03, 2012
How program yamaha rav 300 remote , for sony tv ?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls.If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
Aug 04, 2014 | Yamaha Audio Players & Recorders
How do i program my Yamaha RAV341 Remote Control with my philips tv????
If you wish to get more details, check the sites linked here. Set-up code list, and Set-up procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name of your TV / Device, in the search box at the top right of the display window.
Nov 10, 2013 | Sony Remote Control RMT-D301 p/n:148907111
How to remote control Yamaha RAV341 set up for philips tv???
If your Yamaha RAV341 remote is programmable, you can search for a code that will control your Philips TV.
Rav174 codes for Sony tv
Four digit setup codes to check with Sony Brand TVs are: 0128 0013 0002 0071 0380
Dec 26, 2012 | Yamaha RAV174 Remote Control V3836401
I need the program codes for my yamaha rav 331 remote control to program it to my sony tv
I uploaded the list of remote codes here: RAV331 Remote Codes. I hope this helps- it took me an hour to find the stupid CD that came with my receiver and remote!! As for steps to program: Press the CODE SET button, the LED will blink twice. Then press the input button you want to control (HDMI1, 2, etc...) or the power button down in the TV section at the bottom of the remote. The LED will blink at you again. Then enter the 4 digit code you find in the list of devices and the LED will blink several times to let you know you've set the code. Try powering on/off your device; if it doesn't work, try another code using the same steps!
Sep 23, 2011 | Televison & Video
Jan 19, 2009 | Yamaha YSP-1 System
What's NEC PF68S33 TV's remote control code for YAMAHA HTR-6130
I had similar problem when setting up the YAMAHA remote control for my NEC LCD TV. At the end I found I did not follow the YAMAHA manual properly. Did you hold down the DTV/CBL button, and AT THE SAME TIME press the AV POWER for 3+ seconds? You should be able to "REMOTE SETUP OK" displayed in the front panel of the YAMAHA AV receiver. Hope this helps. BTW, only the TV POWER, TV MUTE and the numeric buttons work in my case.
Dec 30, 2008 | Yamaha HTR-6130 Receiver
I have a sony tv and a yamaha receiver htr8580 and...
I found this site maybe it will help you! Pass it on!http://www.remotecodelist.com/remotes/
Dec 11, 2008 | Directed 434MHZ Remote Control
Dec 01, 2008 | Yamaha Televison & Video
Nov 28, 2008 | Televison & Video
Televison & Video Logo
76 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
