Bose 3 2 1 GSX System Logo
Posted on Aug 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
6 disc cd player
I also have the 6 disc cd player, but i also have nav. There is NO load button! The manual that came with my truck shows a totally different face than the one that i have. My paper work states that I paid extra for this 6 disc and I can't find a magazine anywhere! It also won't take another cd if there's one in there already. Help!
crispin melchor
Level 2:
Sergeant:
Champion:
  • Expert 231 Answers
  • Posted on Aug 06, 2009
crispin melchor
Expert
Level 2:
Sergeant:
Champion:
Answers
231
Questions
0
Helped
99367
Points
524
Try calling bose tech support for this..
The built in sat nav screen keeps going up and down without switching on and also the radio cd does not switch on. any advise would be appreciated
bmw navigation radio cd changer repair
www.hitechserv.com/electronics-repair/oem-navigation-dvd-cd.../67
We repair all models of BMW GPS CD Changer Stereo ... shows on the screen, no audio, display shows no navigation disc but there is a disc inside, do not play CD. ... If there is sound but your blue tooth or satellte tuner is not working "if your car is equipped with blue ..... The MK3, MK4 computers has a GPS module built in.
3 Series (E46) built-in Sat Navs - Gassing Station - PistonHeads
www.pistonheads.com/gassing/topic.asp?t=862860
PistonHeadsJun 9, 2010 - I don't know much about the OEM sat navs, other than that they cost no less than ... would need to be re-positioned and CD player becomes redundant. ... on forums, they do the job, just about and sometimes not too well at all.
2answers
2004 Ford F150 rear entertainment system will not eject dvd, will play the dvd and will run when eject button pushed but will not eject the dvd any ideas on how to get the unit to eject the dvd?
The unit is connected by small set of gears that push tray /disc out. As tray comes out it either pushes disc out of slot or pops open door (depending on which style of face you have). If you have kids I would not be surprised if something is caught in between disc and face or jamming edge of door. (know this from own experience). The face of player can usually be carefully popped off by gently prying at corners. If you get face off you may be able to see if something is stuck in unit that does not belong, or see if a piece is broken loose near face. If unit has door that opens you can try using a slim but stiff piece of plastic and keep tension on door with plastic while hitting eject button. On some units there is a small hole on face that is manual release that ejects disc - even if no power. Usually takes a long straight push in hole (straightened paper clip or dental pick) and it manually pushes gear set to go out. So many of these units are different but most do have a manual release. Check owners manual to see if it shows a picture of face and possible release hole. Have had kids fight over changing a disc and pushed in on it while it was ejecting so it stripped gears, and had kid hang on ceiling mount unit that tore screen totally off. I feel your pain....
2answers
"CDC MECH ERROR" on 2009 Honda CR-V EX-L with Nav
Either the unit's motor is bad or the mechanical parts are dirty not allowing the unit to change CD's or load them.
Hi i purchased the upgrade navigation disc, and i would like to know how to change the old disc to the new one? thank you
to access the nav dvd press the open button for a few seconds. then you should be able to eject the old disc and insert the new one.
1helpful
2answers
We can't get the factory 6 disc cd player to load more than 1 disc. What is the sequence for loading additional discs?
The following is the owner's manual for your 2004 Dodge Neon:
http://www.dodge.com/en/owners/manuals/index.html?year=2004&nameplate=Neon
P.99 describes how to load discs:
1. Select and press any numbered button without an illuminated light above it.
2. Insert the CD while the light above the chosen button is flashing and the two lights on either side of the slot are illuminated.
3. Upon insertion, the CD will begin to play, and both the button light and the lights in the corner of the loading slot will illuminate.
4. Repeat the process for loading any additional CDs. The CD playe rwill stop while additional CDs are loaded.
Playing Discs
The radio will show the CD number, the CD track number, and the Track Time Elapsed while the radio is in the CD mode. IF more than one CD is loaded in the changer, the changer will automatically play the next disc after playing the last track of the current disc.
Wow, that's a lot of typing.
I didn't know the 2004 Dodge Neon had such a nice changer.
Good luck.
My alpine iva-d300r will not even load any disc i
sounds like it.. try to find the small reset button usually on the face of the radio or sometimes behind the detatchable face. you can only push it with a pen this will reset the system and may reset the cd mechanism
A8 2004 Navigation system not active
NAV unit uses a DVD disc. If its a copy, it may or may not work. I suggest you remove the NAV disc, unplug the NAV unit from power for 4-5 minutes, reconnect the NAV and try inserting the disc again to see if it reads. If it still does not read, another NAV disc needs to be inserted to verify its not a "bad" NAV DVD disc issue. If it still cannot read the second disc, the NAV unit is bad. The handbook feature needs the disc inserted in the slot 1 of the CD changer unit.
2answers
Can't get navigation and cd player to work
You can purchase the manual from the dealer. You need the disc for the nav system to program it. Another is you may need to have a code to operate the nav. Did you press the mode button to go from radio to cd? Try to detach the negative battery or press the reset button to factory default, this will bring you back to the factory settings. It looks like a small hole on the radio face. You must use a fine point to push it in and reset it. Is a cd stuck inside of the cd slot? Do all your trouble shooting first and you will find your answer......runjoe
Toshiba dvd player - SD-1200
Its actually in the troubleshooting manual. Pg 126. Try putting in the disk with the label face up, that might work too,
regards
Jim
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
