Question about Saws
SOURCE: finding the lock button..changing a
older model of circular saw dont have a spindle lock.wedge the blade on a bench vise & make sure ur not clamping the teeth of the blade & then turn the blade screw clock wise.
Posted on Aug 09, 2008
SOURCE: where is the lock button for the skill saw
I can't seem to access the parts view for your model, because of its age.
But I'm thinking skil probably hasn't changed things all that much.
Take a look at the 5450 and see if this doesn't help any...click here ...and scroll to page 7.
Posted on Apr 10, 2009
SOURCE: Just bought Skill Saw 5150 with no blade and
hello I can help you. Look carefully around the housing that surrounds the blade and you will find a small lock button. Push it in and rotate the blade until it locks. Then apply the wrench.
here is the link to the free manual from skil
http://www.skiltools.com/en/CustomerService/PartsListsOwnerManuals/
Posted on Jun 17, 2009
SOURCE: I have a skill table saw model 3400 type 2. The
I would check to see that ID of the blade arbor matches the OD of the motor arbor, and you are not missing an adapter ring. Then I would get some acetone and a wire brush clean all surfaces where the blade seats. This is also good practice for Jacobs chucks on drills, that allow the drill bits to spin.
Jim
Posted on Aug 04, 2009
SOURCE: Have an old Black and Decker 7321 Skill Saw.
With the saw UNPLUGGED, check around the base of the motor shaft, there should be some kind of button that you can depress to lock the blade from turning. Then with the appropriate sized wrench, turn the blade locking bolt clockwise (it is a backward thread) to loosen it. Then simply remove the washers, etc carefully and replace them the same way they came off. If there is no locking button, you can use a scrap piece of wood on the saw table and push down on the blade to lock it in place.
Posted on Aug 10, 2009
Oct 17, 2014 | Saws
Jun 28, 2010 | Saws
Dec 12, 2009 | Saws
Oct 24, 2009 | Saws
Aug 08, 2009 | Bosch 12" Dual - Bevel Compound Miter Saw...
Aug 04, 2009 | Skil 10" Table Saw 3400
Mar 18, 2009 | Husky Wet Tile/Stone Saw with with Laser...
Mar 11, 2009 | Hand Tools
Oct 28, 2008 | Saws
Jul 03, 2008 | Bosch 12" Dual - Bevel Compound Miter Saw...
Feb 19, 2021 | Saws
Jan 31, 2021 | Saws
141 people viewed this question
