Question about Stanley Measuring Tools & Sensors
Will my stanley fatmax led spotlight work while charging
Posted by Josh Feger on
ray gallant
    Top Expert:
  • Stanley Master
  • 69,326 Answers
WHY HAVE YOU NOT TRIED IT TO FIND OUT FOR YOURSELF .
Posted on Mar 26, 2019
5 Related Answers
K W
  • 509 Answers
SOURCE: I cannot open the Stanley FatMax Retractable
Try this website and scroll down to product description...
http://www.amazon.com/Stanley-10-777-Locking-Retractable-Utility/dp/B00009OYFP
Posted on Feb 01, 2010
Anonymous
SOURCE: Just purchased a Stanley FatMax 10-778 retractable
1. Make sure the side lock is unlocked.
2. Push the thumb tab all the way to the front of the blade handle.
3. Insert the blade in the opening, you may notice two notches on the top side of the blade.
4. Press the small blade release button as you slide the blade into the knife. You may have to jiggle up and down to get the two notches on the blade fully into the handle.
If properly inserted, the exposed area of the blade should look very close to an equilateral triangle.
make sure both notches of the blade are inside the handle. They notch into the thumb lever.
good luck
Posted on Apr 11, 2010
Testimonial: "Thanks so much!"
Boneebone
  • 973 Answers
SOURCE: cyclops spotlight wont charge
It is indicating that your battery needs to be replaced, it will not hold a charge.
Posted on Jun 05, 2010
puertobori
  • 7733 Answers
SOURCE: Just purchased a Stanley fatMax
Some models has 2 screws on the knife case.unscrew them and you can access to the blade.
Posted on Nov 08, 2010
jason_duchak
Javva
  • 7 Answers
SOURCE: Loading instruction to change blade on Stanley
Hmmmmm.... that sounds really confusing.
Better yet... just watch this video! http://www.youtube.com/watch?v=B8Q1p-8jkyE
It's actually pretty easy! :)
Posted on Jul 31, 2012
How do i recharge Stanley fatmax 700
You will have to buy charger for Stanley fatmax 700 it will cost you around 12$ to15$. You can buy it from any online shopping website like eBay or any other.
Jun 17, 2018 | Stanley Measuring Tools & Sensors
How do I open a stanley fatmax 5watt waterproof rechargeable spotlight without ruining the watertight seal ?????
It may not be possible if seal is stuck to either surface. Best just open it first. If seal breaks, then either replace the seal if one available or replace the unit
Dec 11, 2017 | Stanley 5 Watt Led Waterproof Rechargeable...
Stanley fatmax powerit backlight will not turn off
stanley fatmax jumpstarter 1000A light wont turn off?
Nov 26, 2017 | Stanley Measuring Tools & Sensors
Stanley Fatmax 450 Amp (Model J45TK)compressor starts and then stops right away. The charge is full showing the green LED light on.
You will likely have to open up the case to look inside.
The main components will be a circuit board, a 12v power supply, a 12v air pump and a 12v rechargeable battery. It sounds like a loose connection on the air compressor pump. When you turn it on it normally vibrates and is loud. This may be enough to shake loose a wire connection. If so it should be an easy fix to crimp or solder.
Aug 29, 2017 | Stanley Vehicle Parts & Accessories
How can I calibrate a FatMax digital level?
Mark, Automatic calibration, check the little pockets on case instructions inside, the instructions show how.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Stanley FatMax Digital level mp4
Stanley fatmax digital level instructions Measuring Tools Measuring Tools
STANLEY HAND TOOLS Measuring Leveling Layout Levels Stanley FatMax Digital...
http://www.microprecision.com/equipment/STANLEY-CALIBRATION.html
Mar 04, 2016 | Measuring Tools & Sensors
Stanley fatmax instructions
Leave it on the charges as much time you can. Even though the charger indicates that is charged after 1 - 2 hours allow it to be on it as much time as you can (even 2 days). This procedures maintains the battery to be used more times.
Nov 23, 2013 | Stanley Fat Max 10 Watt Lithium Ion LED...
Measuring Tools & Sensors Logo
163 people viewed this question
Top Stanley Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Vernon Taylor
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
