Question about Homelite Garden
Need a diagram of the installation of the thorttle cable to the trigger on a homelite timberman 45
  • Homelite Master
  • 819 Answers
Need a diagram of the installation of the thorttle - 5078e6ba-cdc9-4178-bb00-77ec43974560-c5swlujwikltdnfhjbeihqyi-4-0.png
Posted on Mar 29, 2019
Anonymous
SOURCE:
Anonymous
SOURCE: fix bar brake on homelite timberman 45
It's a design flaw in timberman chain saws. After some hours of use, they develop a bad habit of not releasing the clutch drum completely. And that takes precious power away from the saw. If it becomes too tight, the clutch drum may over heat and cause the plastic enclosure to warp or melt down. After messing with this brake for months, I ended up completely removing it. Replacing it was not an option for me - there was nothing to replace - it is not the brake band that's bad, but the mechanism in the brake handle of this saw that is flawed. Overall, this chainsaw is very cheaply built - Homelite used waaaay too much plastic in it!
Posted on Jan 05, 2009
rwvanlue
Roland W VanLue
  • 486 Answers
SOURCE: old gas, will not start.
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Dec 01, 2009
dontbother10
dontbother10
  • 2220 Answers
SOURCE: homelite timberman only runs wide open
Start with "H" and "L" at 1.5 turns CCW from lightly seated then tune for performance as follows:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 01, 2010
tbone75862
  • 95 Answers
SOURCE: I was given a Homelite
Go to eparts.com You can look up part numbers and diagrams.
Posted on Mar 07, 2011
tbone75862
  • 95 Answers
SOURCE: I need a manual for
Go to eparts.com type in your model number.It will bring up parts list with pics.You should be able to see what you need.
Homelite Timberman 45 chainsaw runs fine but will not idle. Ideas?
dirty carb specifically in the idle jet turn it in till it bottoms . do not force more then return to the same place it was set if 3/4 turn in turn out 3/4 see if it works better .
Feb 16, 2015 | Homelite Garden
I have a homelite timberman 45 that starts and runs fine,but at high rpm it bogs down, like it's starving for fuel, what could it be?
You may adjust the High adjustment screw on the carbarater most of the time carbarater needs to be rebuilt.
Nov 22, 2014 | Cars & Trucks
Can you email the page on how to tighten the chain on timberman 45 model...lost my manual. thks Dennis [email protected];.com
This page will help. You may not find your exact model but just find one thats close
Good Luck and BE SAFE
Follow link below cut and paste in address bar
http://lawnandgarden.manualsonline.com/manuals/mfg/homelite/homelite_chainsaw_product_list.html
Feb 07, 2011 | Homelite Garden
Timberman 45 w/18 inch blade No owners manual Chain on in grooves and sprockets. Nuts tight Just a little loose. How do I Tighten chain?
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
You can request a new OM and while at it an IPL here:
https://register.homelite.com/contact_us/new
Please do.
Lou
Apr 14, 2010 | Homelite Garden
I have a Homelite timberman 45. It won't idle.
been out fighting 2 saws today,r+r lines filters one problem on 1 saw same went from 50/1 to 30/1 quit over heating and evaporating gas,, pulls easier fires an pulls chain well on big cuts//used 50on two cords cool day last year today 80+ over heated
Mar 21, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Fix bar brake on homelite timberman 45
Oct 12, 2008 | Homelite Consumer Products 9.0 Amp, 14 In....
Garden Logo
57 people viewed this question
Top Homelite Garden Experts
roeb
Randy Schumann
Randy Schumann
Joseph Mueller
Joseph Mueller
Are you a Homelite Garden Expert? Answer questions, earn points and help others
