Question about Coby Televison & Video
I've got a Coby dvd-244 that is saying that the disc is not readable on several different dvds.
Posted by Travis Smith on
5 Related Answers
snakehead
Henry Thomas
  • 1074 Answers
SOURCE: Devise reads no disc when disc is inserted
there is a flat white strip that is connected to the body of the lens replace it if that does not remedy the problem replace the lens.good luck
Posted on Apr 19, 2007
Anonymous
  • 9 Answers
SOURCE: RCA 20" TV/DVD Combo - DVD Player says discs not compatible?
Does it work on store bought DVD's?If it does it means it's not compatable with homemade dvd's on pc's or other recorders.If it dose not you have a dirty lens.If a lens cleaning cd doesn't work,the dvd deck has to be replaced,probably exspensive.
Posted on Jan 03, 2009
Anonymous
  • 563 Answers
SOURCE: No disc message on my coby 224 dvd player
Thanks for using FixYa.
If the unit is showing "no disk" on every disk that you try to play, unfortunately, the unit has developed a defect and needs to be replaced. It can not be repaired. Our warranty is 90 days from the date of purchase. If you received the unit as a Xmas present, please call 1-800-727-3592 for instructions on getting the unit exchanged.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Posted on Feb 07, 2009
localwonder
Michael Masters
  • 6784 Answers
SOURCE: WRONG DISC ERROR WHEN PLAYING A DVD
HI,. this is a lens assembly fault. the lens is malfunctioning or, it may have stopped reading. this wrong disc code is just a universal warning that is concerning a fault if the main board doesn't receive any data(audio,video) when the disc is inserted.
Due to the integrated status of your unit, this will be a costly repair because, the entire assembly is combined together with the vcr section as well.
You will need to replace the entire assembly to fix this issue. the lens has burned out.
you can confirm my diagnosis by preforming a cleaning of the lens with a cleaning disc. if the unit continues to not read or play a CD after the cleaning, this will confirm my diagnosis.
Please rate and have a great day:)
Posted on May 23, 2009
Anonymous
  • 255 Answers
SOURCE: Suddendly my dvd player --TruTech TT320 started saying "no disc" for all the DVDs I want to play. I tried 4 different discs. What can be done?
try to clean the lens with a lens cleaner.if the problem is still there, then your lens is defective.you should have it repaired.
Posted on May 31, 2009
"Loading" error. RCA DCR69702 DVD can't read discs anymore.
Replace unit - the laser assembly has lost the ability to focus on surface of disk.
May 04, 2017 | RCA Televison & Video
Luxor tv with dvd player was bought for me from Asda I've had problems with playback of dvds pretty much since I've had it it has a tendency to freeze and not play and on very several occasions it...
Hi Danny.
this could be a couple off things wrong here.
1,could be a faulty dvd player.
2,could do with having a lens cleaning disc put through it.
3,could be a faulty lens reader.
if i was you before i do anything big to it i would run a lens cleaning disc through it and see if it cleans the lens that reads the discs.
if this does not work i would take it back,or get someone to have a look at it for you.
Nov 04, 2017 | Televison & Video
My coby dvd player will not load dvds. After trying to load, I get a message that says "Wrong Disc". I have tried to put in other dvds, but get the same response. These dvds work in our other dvd...
its probably the laser is misaligned. somtimes you can maually reset it by takeing the disc out and sliding the "eye" toward the center. this will possibly break it, but a misaligned laser is not going to work so you;ve got nothing to lose. put in a disc you know is good, no scratches, and turn it on again.
good luck!
Jan 31, 2011 | Coby TF-DVD1021
Says loading disk and then says wrong disk everytime. tried several different dvds. always the same answer!
The DVD portable player and the DVD disc came from the same countries?Ur DVD portable player and DVD disc u are using might have the wrong region DVD disc format frequencies.Like PAL frequencies only play Euroupean,Asia,Middle East,Austriala and Africa products.NTSC frequencise play only USA,Canada and Mexico DVD Disc products.
Dec 13, 2010 | Coby 7" Widescreen TFT Portable DVD Player...
Player won't read the DVDs
some players won't play burnt discs. If you are using a factory made disc and you still get this, then you can try and clean laser lens with rubbing alcohol and cotton swab.
If the cleaning doesn't work, then the laser lens circuit will need to be replaced.
Aug 05, 2009 | Televison & Video
Nov 27, 2007 | Coby DVD-224 DVD Player
Apr 17, 2007 | Coby DVD-224 DVD Player
Televison & Video Logo
Top Coby Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
