Question about HP Officejet 5610 All-In-One InkJet Printer
Shared printer printing blurry
I have a shared computer that is hooked up to a printer through my network. The desktop runs XP and the laptop runs Vista. I can print with my laptop but it is all blurry. The desktop prints fine. Can you help?
Posted by astrojetson1 on
Anonymous
    Problem Solver:
  • 19 Answers
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
abdsf29
Posted on Sep 06, 2009
I want to share an HP 7760 on an XP with Win 7
To get ahead of myself and answer your question first, your Win 7 machine may automatically load a driver for your shared printer.
Please have a look at the procedure below: (these instructions assume that your XP machine is sharing the HP printer and that your Win 7 laptop can "see" your network and the shared printer connected to your XP desktop computer)
On the Win7 machine, follow these steps:
1) In "Control Panel" click "Add local printer"
2) Create New Port > Local port
3) Port Name is "\\xpcomputername\printername" - without the quotes
(insert the XP's real network name and your printer's real name in the above location)
4) Click <OK>
5) Windows 7 should automatically load a driver allowing you to print on the HP connected to the XP from the Win7 laptop.
I hope this helps!
Mar 07, 2010 | HP PhotoSmart 7760 InkJet Printer
Just bought win 7 laptops wont connect to my lexmark x1180 printer connected to my desktop running xp any ideas?
Enable File and Print Sharing on your XP system.
Click Start
Click Control Panel
Click Printers
Enable "sharing' for the printer.
Click Start
Right-mouse click My Computer
Click Properties
Click Computer Name
to show the current "workgroup" name on your XP system.
On the Windows 7 system:
Configure it into the same workgroup.
Then, "Add Network Printer", connecting to your XP system, and pointing at the shared printer.
Dec 10, 2009 | Lexmark X1150 All-In-One InkJet Printer
I have a Dell desktop running Vista 64 Home Premium with a Lexmark P6250 all in one hooked to it via usb cable and shared on my home network. I also have one dell laptop and one HP laptop connected to the...
The printer drivers must be installed on each computer. If computer A runs XP, you must install driver for XP on computert A; If machine B runs Vista, then you must install printer drivers for Vista on machine B.
Hope it helps.
Sep 11, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Laptop wont print to remote printer
just bound your both computers in valid ip range and attach your printer with you desk. or lap. & just share it.
Mar 15, 2009 | HP Pavilion dv6000z Notebook
Wireless printing
I assume you have a wireless network set up with a wireless router, since you said you have a wireless laptop.
You need to share the printer on the desktop. You also need to set up both computers to be on the same network (for example, WORKGROUP or MSHOME, or a name of your choosing).Once shared and on the same network, you can go to the laptop and add a printer--just tell it that it is a network printer.
A caution--to work without further hassle, both computers need to be running the same version of Windows. If not, you'll need the driver disk for the system on your laptop.
Jan 16, 2009 | Computers & Internet
Can't connect network printer to Windows XP laptop
Does this computer see the other two computers and do they see this computer?
Sep 18, 2008 | Microsoft Windows XP Professional With...
Trying to connect share printer w/Vista
If you connect the printer to the desktop computer and enable file and printer sharing on that computer. You will then need to go into printers and faxes and share your printer. Then go to the laptop and browse the network so you are looking at the desktop computer. You should see a folder that says printers. Open the printers folder and you should see the printer you just shared. Double click on it to install the shared printer on your laptop.
Now when you print from the laptop, you will print to the shared printer that you just installed (you may have to select it from the printer list). That will send the print job through the network to the desktop and the desktop will send it to the printer (the desktop will need to be turned on for you to be able to print).
If you don't want to have to leave your destop turned on just so you can print, you should look at a print server for your printer. That will connect the printer straight to the network. Then both computers will print to the printer over the network.
May 28, 2008 | Linksys 4-Port CPU Switch 843734000836
Wireless printing
If the printer is set up as shared and is attached to a host computer on the network (like mine).
  1. start
  2. network
  3. click on the computer that has the printer that is shared
  4. click on the printer and select connect.
  5. the printer will be displayed on the bottom of the page when it is connected.
Apr 18, 2008 | Computers & Internet
Network printe on vista
Accessing a Shared Printer To access a shared printer from a computer running Windows Vista, do the following:
  1. Click Start, and then click Network. The Network window displays a list of computers in the workgroup of the computer.
  2. Double-click the name of the computer containing the shared printer that you want to access.
  3. Right-click the shared printer that you want to access, and then click Connect. Alternately, you can double-click on Printers to see just the list of shared printers, and then right-click the shared printer that you want to access, and then click Connect.
After you have connected to the shared printer, you will be able to print to this shared printer as long as the printer and the computer sharing the printer are turned on.
please note that in network the computer that has the network printer if it is running XP may take as long as 15minutes to be recognized.
Apr 09, 2008 | Samsung ML 1610 Laser Printer
I am trying to share a printer.
Are they both under the same network? Can the pc find the laptop under network connections and vice versa? If not, then right-click my computer, go to properties, go to the tab 'Computer Name' click on the button change, and make it part of a workgroup of your choice of name. Do this for both making them part of the SAME workgroup.
Then, make your printer shared under that workgroup.
Mar 30, 2008 | Linksys Wireless-G Broadband Router
HP Officejet 5610 All-In-One InkJet Printer Logo
205 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
