How do i access factory menu on skyworth 55G6 tv with the standard yk-6600 remote ? Thanks.
Posted by Mike S on
    Top Expert:
  • Televison & ... Master
  • 76,321 Answers
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Search the site by type in the "brand name" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/ http://homenol.blogspot.com/
Posted on Mar 24, 2019
5 Related Answers
Anonymous
  • 206 Answers
SOURCE: Magnavox TV accessing menu without remote
There may be away but need the model number to narrow it down, most remotes can be found at www.vancebaldwin.com and for usaly under $20.00
Posted on Feb 13, 2008
Anonymous
SOURCE: Accessing Menu Sharp TV
I have a Sharp TV model 27F-S40 and also do not have the remote. I need to access the menu to change color, sound, etc.
Can I access the menu thru the channel or volume buttons on the face of the tv?
Bob
Posted on Nov 08, 2008
Mark Egan
  • 1214 Answers
SOURCE: How to acess set-up menu without factory remote
The manual can be found near the bottom of the Product page for this TV.
From the manual, pg 11 -
If you misplaced your Remote Control you can still access most settings via the MAIN MENU screen when you press both CH UP (8) and DOWN (9) on the TV set. Some features of your TV Set will not be accessible without the Remote Control. If you lost your Remote Control, contact a Sharp Authorized Servicer by calling 1-800-BE-SHARP for a replacement.
Let us know if this fixes it for you.
Posted on Feb 11, 2009
Anonymous
  • 790 Answers
SOURCE: TOSHIBA MODEL MV13M2 NO MANUAL, NO FACTORY REMOTE
HI
Yes you can set the menu function if have menu button is there!
Thanks!
Posted on Mar 11, 2009
thodges1
SOURCE: Need codes for Skyworth TV using RCA universal remote
http://www.marmitek.com/codelists/mt017.pdf
Posted on May 13, 2010
I have a rca rcr314wz universal remote I need right code for my Skyworth tv
Skyworth TV 3 Digit Remote Control Codes
531
753
817
Skyworth TV 4 Digit Remote Control Codes
0696
0698
0727
0748
0753
0817
0037
0556
0009
0264
Skyworth TV 5 Digit Remote Control Codes
00753
00817
00037
00556
00009
00264
Feb 07, 2018 | RCA Televison & Video
I can't turn off the demo mode on my sony bravia tv
Press Menu on tv remote, go to Settings and select Factory Reset and press enter button on remote, tv will reset to factory default settings and turn Off and On again itself, now select HOME mode instead of Shop mode to avoid demo mode and go by initial setup screen instructions.
Above are generic info about Sony bravia tv, let me know model number of your tv if you do not see factory reset option in settings menu.
Thanks.
Nov 08, 2010 | Sony Televison & Video
Need 1992 Remote Control For RCA ColorTrak TV Set
Tries 1-800-Factory remotes originals Website.
U get same as the original remote.
Aug 17, 2009 | RCA F27450 27" TV
Feb 11, 2009 | Sharp 25N-M100 25" TV
TV screen shows 'SKYWORTH' when turned on. Activated this by mistake and can not get back to previous mode. This caused channel reception to be bad and all channels are either not showing well or showing...
HI I have the same problem There are things you can do... For the tuning problem I suspect changing the "RF AGC" will fix that. You need to go into service mode. Turn off TV then hold Vol + and - on front panel and turn on. The TV will come up with extra service menu. Just keep pushing menu till you see "RF AGC" and dont change any values untill you write down what they are or take photo etc. Then just change the "RF AGC" value and see how you go with the tuning. ALL THE BUTTONS ABOVE ARE ON FRONT OF TV. NOT ON REMOTE....Hope this helps....
Jun 10, 2008 | Televison & Video
How do I access program menu on a Orion TV Model # TV1319A
On later orion tv's the menu may be accessed by holding both volume buttons down at the same time.
May 12, 2008 | Televison & Video
Lg television du-27fb32c reset to factory settings
mute on the remote and menu on tv
service mode and go to factory reset
Dec 09, 2007 | LG DU-27FB32C TV
Mitsubishi cs 27401
I CAN NOT PROGRAM MY MITSUBISHI TV MODEL CS 27401. I HAVE THE REMOTE BUY IT HAS TOO MANY CODES THAT I CAN NOT HANDLE.
THANKS,
CLAYTON77
Dec 06, 2007 | Mitsubishi WS-65515 65" TV
No remote
You have to order the original factory remote in order to access the menus of this model of TV set. Contact the manufacture service rep for your area to order a remote.
Jerry G.
Oct 26, 2007 | JVC AV-27D302 27" TV
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
