PN50B450B1DXZA screen has vertical lines Samsung 55 inch
Posted by Ann Smith on
    Top Expert:
  • Televison & ... Master
  • 76,352 Answers
If you wish to get some details; visit the sites linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
http://homenol.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
{View the site in web view by mobile or a desktop to see the search box. Mobile view has no search box.}
Posted on Mar 24, 2019
5 Related Answers
Anonymous
  • 163 Answers
SOURCE: Red line across top half of screen
Uh-Oh.. Sounds like the BGA RAM in the video circuit. (These units are Intel based and Core 2 duo if posted correct).. We can repair if you need help and its under warranty and sorry its not a home remedy situation..
ikenfixit.com
Posted on Jan 17, 2008
Anonymous
  • 9 Answers
SOURCE: dlp white vertical lines
YOU NEED CHECK THE 3 CRYSTALS ( RED, GREEN AND BLUE). CLEAN IT WHIT "DUST REMOVER" ( compressed gas duster) AND REPLACE THE COLOR WHEEL.
Posted on Jan 18, 2008
Priya darshan
  • 3422 Answers
SOURCE: Vertical Black Line
HI,
First thing to do is the reset and the whacking test. I give this a 50/50 chance of clearing it up.
ONE: Disconnect the power cord for 4 hours. Then when you power it back up the internal soft codes will automatically reset to factory defaults.
TWO: The whacking test is to just bang or smack the set with your hand on the back, side, top, etc., to see if there are loose connections or cold solder joints inside that are acting up. If so, the banging should knock them back to normal and the set should restore. You might have to use some creative banging and some have had to put a book or magazine under one corner to torque the chassis enough to get it to work reliably.
If these two procedures do nothing then:
The manual always knows the best.Go through the manual carefully and u will find the solution to ur problem..
Goodluck and Kind Regards
Please Don't forget to rate me as fixya..
Posted on Feb 02, 2008
roety
Eric Rotmil
  • 587 Answers
SOURCE: 42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Aug 19, 2009
Anonymous
SOURCE: Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Posted on Sep 21, 2009
Samsung UN55HU7200FXZA. Black screen. When turn on,Verticals white & black lines, and after 2 seconds goes black (no video).
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Feb 20, 2017 | Samsung UN55HU7250 Curved 55 Inch Ultra
Samsung UN55B7100WF has white haze on screen
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 30, 2016 | Samsung Televison & Video
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    https://www.youtube.com/watch?v=k2QpYJp6MU8
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    https://www.youtube.com/watch?v=8P_i-JIsrYA
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    https://www.youtube.com/watch?v=zE0eqB4Ppjw
    Nov 11, 2012 - Uploaded by LUFERQUINT
    HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
Jan 26, 2016 | Televison & Video
How can I fix vertical lines on my 3D HDTV? They developed from the outside of the screen in.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line fault to LCD TVs will be similar, irrespective of its brand and screen size.
Dec 13, 2015 | Samsung UN55D8000 55 Inch 3D 1080p LED LCD...
My screen shows vertical lines every inch I need help
Vertical lines like that mean that the display on your television has failed. You will either need to have the LCD wafer replaced, or just replace the entire television.
May 13, 2015 | Samsung PN50B450B1DXZA
My led samsung tv has a horizontal line and the upper right corner shows a white vertical lines
Not good. You may have a tab failure. A repair shop may be able to diagnose and repair this, but most likely the lcd panel is broken. The panel is the most expensive part of flat tv's. A new panel will cost more than a used tv.
Feb 02, 2015 | Samsung Televison & Video
Have a 50 Samsung plasma that has developed vertical white lines across the screen about 1 inch apart. Quality of picture is still great and unaffected. Lines have left once or twice but come back. Ca
Maybe it's time 4 a new t.v. Do you leave t.v. on a lot or play a lot games. Turn off your t.v. when not using. Is t.v. old, get a new new one. You will be you did. The newer sets have HD which make for better viewing. I suggest an LED and not a Plasma.
Jan 28, 2015 | Samsung PN50B450B1DXZA - 50in Ws Plasma Tv...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
