Berennis 16 Gb Mp3 player is plugged into USB on my computer, frozen with message on screen "Do not disconnect." What do I do?
Posted by Kathleen Krantz on
Steve Pack
  • Audio Player... Master
  • 4,331 Answers
Remove from from computer
Posted on Mar 23, 2019
5 Related Answers
Anonymous
SOURCE: Disconnected
I had this problem with my YP-U3JZB, and this worked:
Control panel > System > Hardware tab > Device manager > Portable devices (look for "Samsung YP-U3") – right-click and select “Update driver”, follow prompts.
Posted on Jan 08, 2008
Anonymous
SOURCE: Insignia Mp3 player frozen
If you hold the power button for 20 seconds it will shut off. I had the similar problem where I unplugged my Insignia NS4V17B frozed on the bluetooth initializing screen. I turned it off then back on and it is now working fine.
Posted on Jan 18, 2008
Anonymous
  • 12 Answers
SOURCE: creative zen v problems-frozen
I Recently bought a Zen, and it works great. The only problem I found was that it freezes itself from time to time, and the best solution to this problem is on the bottom of your Zen, there is a very small Reset hole. With a needle or a toothpick, gently stick it in, and push lightly. This will allow the Zen to unfreeze, and return back into it's regular mode. All your files will be saved, and kept on to the Zen, so you don't need to worry about losing any of your files.
Any additional help, I'll be glad to answer!
-bananaboy101
Posted on Mar 25, 2008
Anonymous
SOURCE: disconnected samsung mp3 player
Gday...the most likely issue concerning the "USB Disconnected" message on the U3 is that the device has installed itself with incorrect drivers. If this is the case then following these steps should rectify your problem...
1) Plug the MP3 player into the USB port
2) Open up Device Manager (Start, Settings, Control Panel, System, Hardware, Device Manager)
3) Find Samsung UP-Y3 in the list (should be under "Other" or "Portable devices" with a ? next to it)
4) Right click on this and select Uninstall
5) Remove the player from the USB port and plug it back in
Windows should automatically detect the device and install it's own drivers. If not, and you have a driver disk, then just install the Samsung drivers. You should now be abe able to drag and drop files onto the player using Windows Explorer. Hope this solves the issue.
Cheers,
Scott
Posted on Jan 02, 2009
frank_crab
  • 233 Answers
SOURCE: my mp3 doesnt connect into my usb it just disconnects and starts to charge can you help me
I assume from your description that either you are running a version of Windows older than XP/2000 or you need a special driver. Here is a link for the driver(s) you will need. Just enter your model number and select your version of Windows. Download and run the file and you should be up and running shortly.
Posted on May 30, 2009
My nano 4 ipod is frozen, show only apple sign
plug into computer, start itunes,
select 'restore this ipod' or try to update it to latest firmware.
Oct 16, 2013 | Apple iPod Nano MA489LL/A 4 GB 2...
How do you take music off your mp3 player
The Sansa c140 can be operated in MSC and MTP mode for transferring and deleting music files.
See also setting USB mode for autodetect or MSC mode on page 16 of the manual: link to the Sansa c100 series manual.
  • For deleting files a connection to a computer has to be made in either MSC or MTP mode, see page 10 of the manual.
MSC mode means that a computer will see the player as a removable disk when connected.
It's like exploring the computer detecting the player as an external memory, showing up as a drive letter with about 1 GB of memory.
Before disconnecting the player, always safely remove hardware, the icon in the bottom taskbar on the right.
MTP mode means that a computer has software installed like Windows Media Player 10 and in this software, when started, the player is being recognized as Sansa c140.
Before disconnecting the player, wait for the message that it is allowed to disconnect the device.
How to use Windows Media Player 10 ? See the site of Microsoft:
http://www.microsoft.com/windows/windowsmedia/player/10/using.aspx
Need more help ? Just post a comment.
Dec 27, 2009 | SanDisk Sansa c140 MP3 Player
Becomes frozen on 'Refresh Database' screen- help?
The only solution I found to work with the SAME problem was to 1. turn the player off (if you can't press the power button, then hold the power and menu button at the same time and it will turn off) 2. turn the hold switch to the right. 3. press the on and rec buttons simultaneously 4. connect to the computer 5. when the 16 MB folder comes up, create a folder called 'sansa.fmt' and disconnect the usb cable. *warning! this will erase everything, but it's seriously the only solution i've found that works!
Oct 30, 2009 | SanDisk Sansa e250 MP3 Player
My Philips GoGear MP3 Player is stuck
Been using this for a few months. Froze up on same song while on vacation last month, and continued to play same song on repeat until battery went down. Now is frozen with "Do Not Disconnect" as it was being charged on my laptop. Attempted to unplug and plug back in and Windows gives DO NOT DISCONNECT!!!!!
I am having the exact same problem!!!!!
Aug 02, 2009 | Philips GOGEAR SA6045 MP3 Player
16 gig ipod nano screen has frozen screen
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Jul 08, 2009 | Apple iPod nano MP3 Player
Help with my Ipod Nano!!
shut down you PC and unplug all the power outlet... without removing yet your IPOD
Jun 18, 2009 | Apple iPod MA446LL/A MP3 Player
Sansa Fuze MP3
Disconnect the player, press and hold the power button till the player resets. Change the USB mode to MTP, then turn the player off and reconnect to computer. The computer should now recognize the player.
http://www.sansaworld.com/
http://www.sansaworldmp3.com/
Apr 05, 2009 | SanDisk Sansa e250 MP3 Player
Creative zen v problems-frozen
If a reset does not work using the reset hole, then try this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
Aug 25, 2008 | Creative Labs ZEN V Plus MP3 Player
367 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
