Question about The Audio Players & Recorders
Harmon Kardon HKTS200 Subwoofer quit working why?
Playing quite loud then the subwoofer quit could there be an internal fuse or is it my receiver?
Posted by KENNETH A SYLVESTER on
Lawrence Oravetz
  • The Master
  • 10,548 Answers
You have a powered sub. There will be fuses on the circuit board for 110 volts power and another to protect the speaker from overload
Posted on Mar 23, 2019
5 Related Answers
Anonymous
SOURCE: How do I disassemble + clean Harmon Kardon SoundStick subwoofer?
Check for a Fuse. Mine is an older model and has a Fuse right next to the power cord. It probably has a slot for a flathead screwdriver.
Posted on Jun 09, 2009
ShivaSai
  • 14 Answers
SOURCE: I have Harmon Kardon AVR 25 ii receivers and I
To locate the problem...a) Cable
Test if right cable is ok, by interchanging the rt/left cables.
b) Test Bose right speaker
Connect the Bose right speaker to HK's left channel. Works? Then Bose right speaker is ok.
c) Test HK's right output by connecting the left Bose speaker to HK's right output.
Does not work?
Posted on Jun 23, 2009
Anonymous
  • 119 Answers
SOURCE: need to replace ac cord on subwoofer
bring your ac cord to electronic or computer part sales so that you can buy same specifications
Posted on Oct 19, 2009
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: My receiver doesn't have a dedicated subwoofer
That would depend mostly on your subwoofer. There are some that slave off the front left and right speaker outputs and still pass the amp's power to the Front Speakers. That would be the only way that would ensure volume control.
Otherwise you have to feed a self-powered sub from the Tape Outs but that won't allow volume control from the H-K.
Posted on May 29, 2010
Anonymous
  • 93 Answers
SOURCE: how do i connect my boston acoustics pv800
You need to use the LINE LEVEL connection on the pv800 (usually a rca type connector cable) and run this cable into the back of the HK 520 Subwoofer PRE-OUT connector, be sure the HK Receiver menu speaker set-up option is set to SUBWOOFER "YES"
Posted on Jun 12, 2010
HTS14 subwoofer (Harmon Kardon)powers off after 10-15 minutes
Yeah, it sounds like it's over heating. Are you driving it way loud?
May 23, 2014 | Audio Players & Recorders
Can I connect a Harmon Kardon TS200 speaker system I bought an auction to my iMac or do I need some kind of amp/receiver?
Does the speaker system have its own Built in amp to the sub, If it has a built in amp, Then you can hook it up to thje computer with the proper patch cord,
Dec 02, 2012 | Harmon Kardon Harman/kardon Hkts 200 Bq...
How to connect the subwoofer to my Tv Samsung???
Most of the time there is a foldback of the left and right audio inputs of the subwoofer in that they use and sum the L and R audio and then filter the high end off. That means that the audio outs from your source be it the TV audio outs or a AV receiver that they can be Y corded to the sub woofer for that purpose.
Oct 01, 2012 | Harmon Kardon Harman Kardon Subwoofer Sub...
How do i connect my boston acoustics pv800 subwoofer to my Harmon Kardon AVR 520 reciever?
Jun 06, 2010 | Boston Acoustics PV800 Subwoofer
Harmon Kardon HP spkrs can't get subwoofer output
Just a thought is the output to the sub switched off on your computer?
May 30, 2010 | Electronics - Others
My receiver doesn't have a dedicated subwoofer output, can I still hook up a subwoofer? I have a harmon kardon avr 25
May 29, 2010 | Harman Kardon AVR 25 MKII
I have a bose v20 and a harmon kardon receiver. Should I be returning the bose system, buy just the speakers, and and outside subwoofer, or what is the best system for watching movies etc? What would be...
If you have the harmon kardon receiver, check out this reasonably priced system. You can actually find it cheaper than at this website but I have these speakers and, when paired with the Klipsch sub-woofer, it makes movie watching an unbelievable experience.
http://www.klipsch.com/na-en/products/quintet-sl-home-theater-system-overview/
Good Luck!
Oct 19, 2009 | Bose 901 VI Main / Stereo Speaker
Apr 24, 2009 | Harman Kardon Harmon Kardon SoundStick II...
Harmon Kardon receiver not compatable connection to subwoofer.
Most subwoofers with RCA type connections are powered subs. They are commonly sold in most hi-fi stores.
Unless your subwoofer has a separate mains lead it will be the wrong type I think.
Dec 07, 2017 | Harman Kardon HKSUB 12 Subwoofer
82 people viewed this question
Top The Audio Players & Recorders Experts
Don Walper
Level 1 Expert
Larry Stiles
Larry Stiles
Michael Roth
Level 1 Expert
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
