Question about HP Televison & Video
I try to start a HP iq775. When I press the power button I heard one short beep and I see a red light red and then blue, and turn off inmediately. The PC won't start. The power supply works fine. Help
The power supply was checked separately and works fine.
Raj Patel
    Genius:
  • 1,041 Answers
All HP iq77x all-in-one PCs suffer from the same problem of a faulty motherboard. This is primarily a soldering issue on the graphics chip,which develops cracks in the solder balls. The PCs contained a separate graphics card, which goes faulty first. This can be removed and the display connector can be moved on the motherboard to use the on-board graphics. This will eventually show the same issue. A short term fix was to heat the graphics chip with a hot air gun or other means (plenty of suggestions can be found on-line) which sometimes works for a few weeks at most. The only 'permanent' fix is to have the chip professionally removed and re-soldered; an expensive option.
If you are lucky, your PC is still wired to use the add-on graphics card, in which case you might be able to remove this and rewire for the motherboard graphics.
Posted on Mar 21, 2019
Testimonial: "Thank you for your explanation and recommendation..!!!"
5 Related Answers
Anonymous
  • 239 Answers
SOURCE: PC won't Boot Up
Here is what is says in the owners manual in what to do in this case, Hope this is a Help, Happy Holidays
Red Power LED
flashes five times,
once every second,
followed by a two
second pause.
5 Pre-video memory
error.
1. Reseat DIMMs. Power on the
system.
2. Replace DIMMs one at a time to
isolate the faulty module.
3. Replace third-party memory with
HP memory.
4. Replace the system board.
Red Power LED
flashes six times,
once every second,
followed by a two
second pause.
6 Pre-video graphics
error.
For systems with a graphics card:
1. Reseat the graphics card. Power on
If you need anymore let me know and I will post them for you.
Posted on Dec 15, 2007
Anonymous
  • 101 Answers
SOURCE: atx12v1 cable
The repeating single beep with a small pause (actually 3 Beeps a Pause) clearly indicates problems with RAM .Replace it ,your problem will be solved . As for connecting the 12 volt 4 pin connector all mobos are designed to sense the presence of this 12 volts and ONLY THEN TURN ON.
Posted on May 06, 2008
leecom72
Lee Hodgson
  • 4810 Answers
SOURCE: hp xw6200, 6 beeps, and red power button...failed start up.
6 long beeps indicates that there is a problem with the memory, take them out, clean the contacts and the DIMM slots and reseat them.
Hopefully this will resolve the problem, if not new memory may be required
kind regards
Posted on Dec 14, 2008
Anonymous
  • 12 Answers
SOURCE: HP dx5150 Microtower PC won't start up just beeps
That's what's called a POST beep code. The HP DX5150 beep code info can be found at http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=447468&prodTypeId=12454&objectID=c00868914,
but for your benefit: 5 beeps means you have a memory problem. Take out the DIMMS (memory sticks) and reseat them. Try to boot. If you get the POST code again, you have bad memory (unlikely, but could also be a bad FSB on the motherboard). If you have more than one memory stick, remove one, try to boot, if you get the error, put it to the other memory slot, try to boot...then do the same procedure with the other stick. If you can get it to boot on one stick, you know the other is bad.
Posted on Mar 14, 2009
efs_perpends
efs_perpends
  • 1997 Answers
SOURCE: 1 short beep and 1 long beep when power button is pressed.
These sounds are known as BIOS beep codes. They indicate an error with your system. Traditionally, 1 long and 1 short indicates a system board problem.
If you google bios beep codes, you will be able to find the codes that relate to your Bios, or motherboard.
Backup your files. Your computer is trying to tell you something.
Posted on Apr 10, 2009
HP Pavilion not turning on, orange light and alarm sound.
Try a Hard reset!
1. Remove all connections from the computer including the power cable
2. Press and hold the power button for 20-30 seconds and then release
3. Only hook up the mouse, keyboard, monitor and power cable
4. Turn the computer
let me know what happens!
Oct 15, 2014 | HP Pavilion Computers & Internet
Tip
Fix the 80010514 error on your PS3
If your Play Station 3 (PS3) gets the 80010514 error somewhere, you can try this to resolve the problem:
1. Make sure that the power indicator on the Play Station 3 system is solid red. To do this, press and hold the power button until the PS3 beeps and the light blinks. Once the light has turned solid red, turn the power switch in the back off.
2. Turn the switch back on, then press and hold the power button.
3. Keep holding the power button even after you hear a short beep after 5 seconds.
4. After 10 seconds, you will hear another short beep and the system will shut down (release the button at this point).
5. Press and hold the power button again.
6. Continue holding the power button even after you hear a short beep after 5 seconds.
7. Release the button when two short beeps are emitted after 7 seconds.
8. As instructed by the on-screen message, plug in the controller and press the PS button
9. Select restore Play Station 3 system.
This should not affect any of your save games, demos, etc. but just to be safe you might want to back up to an external USB hard drive.
To backup saves, go to the Play Station 3 Save Data Utility, select the save you wish to copy and hit the Triangle button. Copy should come up as one of the options. If it does not then the save game is copyright protected and can’t be copied. If you can copy it, make sure you have a USB drive attached and copy it to that.
on Feb 02, 2010 | Video Game Consoles & Games
Afterglow Wireless Headset Blue Flashing mic light
i have the same problem. i am worried. i was playing counter strike and we finished. everybody was congratulating. shortly after a loud beep a bit lower pitch than the turning of and on noise that the headset makes. i turned it on and off. the only thing that stopped the beep was to mute the mic. fiddles with the 2 buttons, the light dimmed greatly and the mic started blinking blue. if you are able to find any way to fix it please contact me on skype : Sassy_Sasquach. Thanks!
Jan 23, 2014 | Radio Communications
Hp xw6200 orange blinking power light
See the following manual:
http://h50146.www5.hp.com/lib/doc/manual/workstation/hp_workstation/c00213035.pdf
Jan 25, 2013 | HP CTO HP Workstation XW6200 Base...
I see dark, black and blue stripes when start my hp iq775 desktop
Memory problem. A page fault occurs when you don't have enough memory so it writes a page fault to disk. It could be bad RAM or driver could need an update.
Oct 20, 2017 | HP iQ775 19" TouchSmart Desktop PC
Play station is hooked up on turned on (blue light) tv is on and on the right input but nothing shows up on the screen. Please help
Please try these easy steps to sort your problem out :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Hope this helps and thank you for using FixYa
Aug 23, 2010 | Sony Playstation 3 (PS3) Console
It comes on but I can't get anything on the screen. if I put a game in it gives me the blue and green light but nothing happens
  • Have your ps3 in standby mode (red light).
  • Now, press and hold the power button in the front down. Your ps3 will beep twice. Let it go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all!
try this
Jan 13, 2010 | Sony Playstation 3 (PS3) Console
Hi- we are having a problem with our ps3....it just started overheating....we forgot to open the door...I heard the fan kick in...so we turned off the ps3 to let it cool down....now the ps3 is running...we...
try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
then try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 20, 2009 | Sony Playstation 3 (PS3) Console
Supertooth one user manual
Charge your Supertooth one via the car charger or by attaching a usb/mini usb cable to your computer usb port. Need to charge for 4-10 hrs. Indicator light glows red (needs charging), orange (charging) or green (charged)
Power on: Press green button for 1 second. Indicator light blinks blue. A beep will be heard
Power off: Press green button for 1 second. Indicator light turns red. A beep will be heard
To pair with your mobile phone:
1. Press green button on Supertooth for 5 secs until indicator light blinks red/blue 2. Access bluetooth menu on your phone. Turn bluetooth on. Execute a bluetooth search. 3. Select ST ONE from list 4. When phone requests password enter 0000 and press OK 5. The handsfree kit is now ready for use 6. Clip Supertooth on sun visor of your car so that the microphone and control buttons are directed towards you.
To make a call: Dial number on phone. Supertooth will automatically connect. Indicator light is steady blue during call
To end a call: Press red button for 1 second
To answer a call: Press green button for 1 second. The bluetooth indicator will turn a steady blue.
To increase/decrease volume. Press volume buttons repeatedly up or down. They are situated between red and green buttons.
Hope this helps.
Nov 22, 2008 | Cell Phones
It doesn't start up, only beeps and red light flashes
pls try to use another compatible memory stick.
then confirm the status of your micro processor
Apr 21, 2008 | HP Compaq dc7100 Ultra-slim PC Desktop
Televison & Video Logo
41 people viewed this question
Top HP Televison & Video Experts
Edward Easley
Edward Easley
Bernie Scott
Level 1 Expert
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
