Where do I get spares for my Aurora as1018cd shredder
Posted by D E Leggett on
5 Related Answers
Anonymous
SOURCE: Aurora paper shredder AS1200X Parts
blendervill,
If I am unsuccessful in locating the replacement gear for my AS1200X, I will joyfully sell you my unit-for parts.
Regards, MOTORRR
Posted on Feb 24, 2008
Anonymous
SOURCE: Aurora Electronics AS1018CD Shredder
Guys,
Here is an update of the problem:
Using the shredder for continuous extended periods causes the motor to overheat in which case the motor just shuts off automatically.
Leave it for a while to cool down and resume normal usage - this should make it work again.
There is a switch inside the shredder that needs to be activated by a notch in the waste basket. Take extra care to aligh the notch with the slot otherwise the shredder will not work.
No theres the fix!
Posted on Feb 27, 2008
Anonymous
  • 102 Answers
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc1.gif board, contact manufacturer for more info.
Posted on Mar 02, 2008
Anonymous
  • 58 Answers
SOURCE: i cant find parts for my aurora as1018cd papershredder
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
Anonymous
  • 42 Answers
SOURCE: I have a broken handle
Call Aurora customer service at 1-800-327-8508 they were very helpful when i NEED GEAR PARTS FOR MY SHREDDER!
Posted on Jul 25, 2011
Replace the switch
First, look for any screw holes if not then it has an interlocking clips... so be careful when removing it... use proper tools
My laminator has paper jammed
Try the Aurora troubleshooting page at
http://www.auroracorp.com/troubleshooting.html
The gear is stripped on our AS1018CD shredder. We want to buy a replacement one to install ourselves. Please let us know where we can order it. We did not get any satisfaction with FixYa that you had...
I was having the same problem with my shredder. I called customer service; I was informed it was the gears on the inside of my shredder. My shredder is no longer under warranty. However, she is mailing me out the part I need for a small fee. Their customer service number is 1-800-327-8508 in the USA and international only 1-310-793-5650. I do hope this help you!
My AS101bCD Aurora shredder will not shred paper, green light on paper in nothing, will happily go in reverse, what can i do
Sounds like a problem with the switch. Replacement is the most likely option, switches cannot normally be repaired.
1helpful
Does not stop after shredding
it could be that a paper or a staple is on the sensor and the machine wil not stop until it will be cleaned
its posible that a staple is on the electronic board and short the circuit
Hope it will help
Open Questions:
Marvin
Marvin
