Question about LG Refrigerators
What is the recommended temp for LG Refrigerators?
Posted by gg Gaines on
Andrew Taylor
    Top Expert:
  • LG Master
  • 33,014 Answers
Check to see that your refrigerator is set to its optimal setting. LG recommends 37 degrees for the refrigerator and 0 degrees for the freezer. If additional cooling is required, start by lowering the temperature a few degrees to achieve your desired temperature.Oct 26, 2018
LG Help Library: Not Cold Enough - Refrigerator ' LG U.S.A
https://www.lg.com/us/support/product.../CT10000021-1426094905942-not-cold-enou...
https://www.google.com/search?q=recommended+temp+for+LG+Refrigerators
Posted on Mar 21, 2019
How to set freezer on LG Bottom Freezer LRFD22850
Hello Fran Miller,
For OPENERS... (my opinion)
always start by setting you temperatures at mid range.
Owners manual... Page 16
Setting the controls 16 - 17 Adjusting control settings...
http://www.searspartsdirect.com/partsdirect/user-manuals/LRFD22850ST-LG-Parts-Refrigerator-Parts-manual
I get a little PUSHY about FOOD TEMERATURES...
(stored poorly there's no quicker way of poisoning ones self)...
I strongly recommend getting TAYLOR refrig/freezer
THERMOMETERS (like Amazon... cheap = $6 ea).
Let the refrigerator stabilize EMPTY 24 HOURS
Loaded with food (not recommended: 72 hours).
ADJUSTING CONTROL SETTINGS
Give the refrigerator time to cool down completely before adding food. It is best to wait 24 hours before you put food into the refrigerator. The mid-settings indicated in the previous section should be correct for normal household refrigerator usage. The controls are set correctly when milk or juice is as cold as you like and when ice cream is firm.
THERMOMETERS
Amazon com Taylor Refrigerator Thermometer 20 Deg To 80 Deg 3 1 4 3 3 4...
Hope I am helping
Carnac the Magnificent
Jul 11, 2017 | LG Refrigerators
My LG REFRIGRATOR MODEL GR642 ap won't stop beeping and I can't change any temp settings in the touch panel ? Please help ??
Turn off, unplug from wall, use surge protector and plug fridge back into the protector, turn power on, set operating temp etc. Cheers
Feb 23, 2015 | LG Refrigerators
What is the recommended temperature setting for the refrigerator and freezer?
Freezer Temp -10 degrees
Refrigerator - 35 degrees
Anything lower is overkill.
PLERASE RATE ME IF THIS WAS HELPFUL
Leo Ponder
imufo2
Jul 29, 2011 | LG LFX25960ST Stainless Steel French Door...
Bought a brand new LG bottom freezer fridge a couple of months ago. I like the refridgerator part to be cold, so we keep the fridge temp on 6 (1-7 are temp choices. 7 being the coldest). We had the freezer...
If designed as most combination units, one of the two controls influences the temperature directly, the other only determines how much of the generated cold air is allowed to enter the other compartment. The typical arrangement is that setting the freezer temperature determines how often often the compressor runs; the other diverts a portion of the cold air into the refrigerator side.
Using the common thermometer for cold temperatures (~$5 US), adjust the freezer temperature for 0 to -5 degrees F (the often recommended temp.), then the other control for the desired refrigerator temperature, suggested as 35-45 F. This is the most common practice.
If you cannot balance them the way you want, reverse the procedure, setting for refrigerator temp., then freezer.
Dec 13, 2010 | LG LBN22515 Bottom Freezer Refrigerator
LG LSC 26905SW control panel for temp, ice,
Replace the control pnl.
There is no way to fix the existing control.
Jan 12, 2010 | LG Refrigerators
Refrigerators Logo
87 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
