Question about Samsung Dishwashers
Samsung dishwasher model DW80K7050US won’t start and there is a flashing red light on the motherboard located behind the kick plate. Tried powering off and flipping breaker without success. Do I need to make a service call?
5 Related Answers
Anonymous
SOURCE: no power,red power lights keeps flashing.
Just my coment THis tv has a complex system that include a digital signal porcessing in a high levle technology to show a good performance, i myself work on the development of that model, we was thinking we are best, for improve that many eng. dedicates almost all life to have that technology in our rooms, I offer my apologize for that but many eng dedicates all year 18 hours a day to fix that, thanks
Posted on May 13, 2007
Anonymous
  • 49 Answers
SOURCE: Power Light Flashing - Machine wont Start - Whirlpool ADP5966
this is a fault code. it will flash so many times and then pause.
let me no how many flashes before the pause and i will tell you what fault code it is
Posted on Feb 21, 2008
Anonymous
SOURCE: GE Max dishwasher no lights on panel
I have the same problem and actually found a workaround by mistake you may try as a temporary solution (if that works for you):
- press and hold the lock button for a couple of seconds
(the delay timer would increase by 1 hour)
- press and hold the lock button again
- repeat until it reaches 9hrs
- repeat one more time: the control panel should be functionnal again.
Let me know if that worked for you!
Posted on Mar 22, 2008
Anonymous
SOURCE: FDB1050REC2
Follow up to my Jun 02, 2008 post. We had a service tech come out today, and it turned out that the door switch was bad. The neutral side had continuity with the door shut, but the hot side was sporadic. A new switch has been ordered.
According to the Frigidaire tech sheet attached to the door, which is located beneath the control panel and behind the door skin, the problem could potentially be a bad control panel also.
Hope this helps someone in the future!
Posted on Jun 03, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Kitchen Aid dishwasher Child lock light on and dishwasher will not start.
if your unable to unlock the "childlock" by holding down the button, then it woud seem that theres a problem with the user interface itself
Posted on Oct 19, 2008
My Samsung Dishwasher, model DMR78AH5 will not run. The heavy, delicate, quick and smart lights are permanently on. I cut off the breaker for one minute but that did nothing.
How to Fix a Dishwasher That Won't Start ' Dishwasher Repair
www.partselect.com/Repair/Dishwasher/Will-Not-Start/
If your dishwasher won't start the problem could be the door latch or door latch ... On manual timer models the timer is used to supply power to the pump motor, ...Missing: samsung ‎dmr78ah5
Samsung Dishwasher Won't Start - Model DMR57LFS ...
www.repairclinic.com/...Dishwasher/...-/Samsung-Dishwasher-won-t-start...
The door latch ensures that the dishwasher door latches shut. If the door does notlatch properly, the door switch might prevent the dishwasher from running.
What to Do When the Dishwasher Won't Start - YouTube
? 5:43
https://www.youtube.com/watch?v=L-bMqVb9kX0
Aug 15, 2013 - Uploaded by doityourselfstan
The problem could simply be a blown thermal fuse inside the control panel. ... Maytag Dishwasher Repair ...
Dec 16, 2015 | Samsung Dishwashers
Flashing clean light
check behind kick plate for service manual. To clear 7 blinking lights go into diagnostic by doing a finger dance, touch hi temp scour then air dry till it goes into diagnostic this will check all systems .Once finished you will most likely need to change the chopper and junk in or around the sump Cheers
Dec 08, 2013 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool dishwasher model Gu2548XTPS7, clean light flashes 7 times and won't start.
Check, if you have water in the machine, if yes, your control board could at fault
Mar 20, 2013 | Dishwashers
Lights flashing and dishwasher will not start
Take the kick plate off the bottom. It should tell you on a display on the bottom what is wrong. Resort to manual.
Jan 25, 2012 | Electrolux Dishwashers
My Kenmore Ultra Wash Quiet Guard
take kick plate off get book out how to reset board
Apr 24, 2010 | Kenmore 15899 Built-in Dishwasher
My whirlpool dishwasher is flashing 8 times - I pressed and held the start button to reset and then pressed start again, it kicked in and started to fill with water and stopped again - any ideas.
Hello, I have a Whirlpool DWF A10. The machine starts then stops after a short while and the indecator light flashes 7 times. What does this mean? Any body come across this?
Jan 11, 2010 | Whirlpool 24 in. ADP5966 Free-standing...
Dishwasher FDB1050REMO - built in, no power and no lights. Tried the breaker and nothing, is there a reset function on this model? Any ideas?
no reset on unit but items to check is have a voltage meter remove the lowest kick plate open the wire connection box it may just be a bad wire nut. Do you have voltage if so then the problem is the thermal fuse located on the pcb controller between the outter door panel and the inner door panel
Sep 09, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Dec 23, 2008 | Maytag MDB7100AWB Dishwasher
Dishwasher does not start
I have the same problem. I've tried everything;even took apart the control panel and checked for corosion. I ended up changing the control board-$130 down the drain- The only other thing I can figure is the button panel has some sort of short- also ~$130-. good luck. Now I use the sink (wife's not happy) Tech sheet is behind kick plate.
Dec 13, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Clicking control knob
try checking the filter, its normally located behind the kick plate on the bottom of the machine, best to tip machine back when you unscrew filter though as there will be quite a bit of water in the pipes more often than not.
hope this helps.
ps if the dial is just clicking the red light will flash as well, count the flashes as this indicates a fault code. there will be about a second gap between flashes.
Oct 22, 2007 | Indesit W 123 Front Load Washer
Dishwashers Logo
205 people viewed this question
Top Samsung Dishwashers Experts
gbob59
Marvin
Marvin
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
