Question about Midland Radio Communications
I have midland 13-892 just need pin out on the mic
Posted by BigB Maxson on
5 Related Answers
Mechanic688
Mechanic688
  • 204 Answers
SOURCE: look for schematics for a midland cb
daniel, first off, I need a complete model number for the radio info. Midland only made about 40-50 different models over the years. The header calls for a 75-822 and you are asking for a ** 833. The beginning should be a 13 or 75,76,77,78. Let me know the # and i'll be able to get you the proper pinout.
Thanks,,, Mechanic
Posted on Mar 08, 2008
Anonymous
  • 13 Answers
SOURCE: midland cb radio
NO. I SORRY. YOU COULD GET IT FROM THE MANUFACTUREE. THANK YOU
Posted on Sep 16, 2008
One Wire
Dean Pitts
  • 126 Answers
SOURCE: converting a different brand of mic for a midland CB
This should be a typical Midland pinout. If you are using a generic 4 pin mic that is wired to cobra/Uniden, all you have to do is switch pin 1 & 2, then 3 & 4.
Not all mics are color coded the same with their wires.
Posted on Oct 06, 2008
Michial Gueffroy
  • 1140 Answers
SOURCE: Does anybody know the wiring sequance that you
Its not in my area of expertise but maybe this link will have some info:http://www.dxzone.com/catalog/Technical_Reference/Mic_wiring/
Posted on Sep 01, 2009
JOHN BABA
  • 1274 Answers
SOURCE: NEED A MANUAL FOR A MIDLAND CB MODEL 77-805,AND A MIC
You can download it at www.cbtricks.com ....hope this was helpful...
Posted on May 15, 2010
Need manual for midland 76-858
here is the pin outs.. look at the switch in the mic handheld housing.. and attach as the one shown for midland 4 pin. this will work with any radio. and doesn't matter which color is what.. as long as the wire on the switch matches the wire on the pin correctly.
Aug 01, 2014 | Midland 1001Z 40-Channels Base CB Radio
I have a Midland CB Car with no mike or a car power pluge, the model # is 70 - 336B and the serial # is 760408
Your midland CB will use a standard 4 pin wired CB plug which is most common for most mics sold today. Your power cord will be a standard 3 pin CB power cord which again is most common with CB's today. You need not purchase a "radio specific" cord or mic. Cobra, Uniden, Midland all the same mic pin out and power cords. Good luck.
Feb 09, 2011 | Radio Communications
Need a mic for a midland 79-892 SSB Radio or at least the 6 pin mic plug
Because the radio has controls for the clarifier on the mic, there is an extra wire to have the control in the mic. This is why the radio uses a six pin mic but it is an offset pin spacing. This is an extremely tough mic connector to find and the radio is getting pretty old.
I have on several radios strapped the RF gain and used this knob as the clarifier and installed a five pin mic connector in the radio and it's mate on the mic. Not a job for those who are not used to doing this! But the radio is worth the repair as it is a good one! Email me at.... [email protected]
Feb 12, 2010 | Midland Radio Communications
Converting a different brand of mic for a midland CB
Oct 06, 2008 | Midland 1001Z 40-Channels Base CB Radio
"squeak" when transmitting
Make sure you have a good ground for the radio and antenna. How long is the antenna coax if a little to long and you have extra what did you do with it coil it if so uncoil it and lay it out try it. If no luck I would shorten the coax and recheck your SWR.
Jun 22, 2007 | Midland 1001Z 40-Channels Base CB Radio
Radio Communications Logo
131 people viewed this question
Top Midland Radio Communications Experts
eradiostore
eradiostore
Michael Thomas
Michael Thomas
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
