Question about Samsung Audio Players & Recorders
I need the Power IC number of my samsung DVD home theater HT-TZ315
Posted by Buchi on
5 Related Answers
Anonymous
  • 3130 Answers
SOURCE: Lost Remote for my Durabrand HT-395 Home Theater Systom
There are no codes you program into the remotes unless they are learning remotes. If you did the manual search for the code, then the universal remote will not work on that unit I'm afraid. You see you are not entering the code into the remote when you push the numbers the book tells you to. What you are doing is accessing the pre programed codes that are already programed into the remote. You cannot add any codes for universal remotes unless like I said before, they are called learning type remotes. Those cost loads of cash. Good Luck
Posted on Oct 15, 2007
Anonymous
SOURCE: comcast remote and need code for a samsung ht-tq85 home theater
http://www.ehow.com/how_2116903_easily-program-comcast-remote-control.html
Posted on Aug 02, 2008
Anonymous
  • 3 Answers
SOURCE: unlock home theater system samsung ht-x20
http://www.videohelp.com/dvdhacks/samsung-ht-x20/8981
This should solve it :) I had similar problems. Swapnil
Posted on Nov 04, 2008
ginko
Ginko
  • 19396 Answers
SOURCE: Protection Problem on Samsung Digital Home Theater
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
Samsung home theatre ht tz315 shows
Clean the rear panel fan. It is probably dirty.
Aug 16, 2013 | Samsung Audio Players & Recorders
Blown resistor and IC
R91 is a 1K Ohm
M1 is FSDM0356
Jul 15, 2010 | Technics SA-AX530 Receiver
Samsung dvd player switches itself onto protect!
hi,i can't connect my audio tv to cinema theater dvd
Apr 02, 2010 | Televison & Video
Removal of region codes
PRESS KEY " ENTER 84269 ENTER "
Oct 28, 2009 | Samsung HT-TZ312 Theater System
I keep getting the 'rear check' message on the tower panel display and all cables are connected what could this be this is on my new HT-TXQ120 DVD HOME THEATER SYSTEM
With the home theater system off, press and hold the REMAIN button on the home theater's remote control for 5 seconds.
Note: You can release the REMAIN button when the POWER LED blinks blue.
With the wireless module turned on, use a ball point pen to press the RESET button on the back of the wireless module. The POWER LED in the front of the home theater blinks two times.
Turn on the home theater. The LINK LED on the front of the SWA-3000 changes from red to blue, indicating the wireless module has connected to the home theater.
If your home theater continues to display rear check after you have tried the steps above, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Jun 29, 2009 | Samsung HT-TXQ120 Home Theater System...
Dvd home theather system
The audio amplifier IC are fried and need to be replaced
Mar 31, 2009 | Samsung HT-X40 System
Samsung ht-tz315 subtitle character problem
Hi Old man
You're going to be in trouble. Beware.
Apr 10, 2017 | GoVideo Go Video DVD/VCR Combo
Problem "protect"
Hey guys, just had the same problem and found out it was because I had disconnected the central speaker. This it was creating a back impedance or something and reonnecting did the trick! i.e. check your speaker connections and check that they work... duff speakers could cause the problem too!
Sep 20, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
41 people viewed this question
Top Samsung Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
