Question about Boating
Installed HDS 10 (no touch screen), and ethernet box for total scan transducer. Unit will not show total scan for install? Also, HDS 7 (no touch screen) on front all scrambled. Help!!!
Posted by michael charette on
5 Related Answers
Editor925
Dean
  • 285 Answers
SOURCE: Mounting a sonor/transducer on a MinnKota Riptide ST
Did the unit come with a strap to mount the transducer to a bow mount electric? Most units do... If not there is probably one available for the unit as an aftermarket accessory or accessory from the manufacturer... Regarding the transducer wire, just wrap and rout this up the front of the bow mount motor shaft so when you pull the motor up and secure it, it is not going to get in the way. You could cable tie the cord down near the bottom of the shaft and one up near the top where they wont interfere with the motor bracket when the motor is positioned up on the boat.
Posted on Mar 17, 2009
Anonymous
SOURCE: Fast ethernet LAN drivers not installed and gives error code 10
Go to setting,control panel,system,device manage then click the network adapter,then properties,in resources uncheck the box "use automatic settings" then click the change setting then "edit input/output range" and try using other value with no conflicting device then click ok.Then go back to device manager and check if the yellow exclamation point is still there
Posted on Apr 30, 2009
Anonymous
SOURCE: Transducer for LOwrance HDS-5
is the HST-DFSBL lowrence transduser combatible whith HDS-5 unit?
Posted on Jun 06, 2009
Anonymous
SOURCE: lowrance x135 not functioning properly
Had the same issue with another brand. Turned out the transducer cable was picking up noise from other cables (power, trolling mtr. etc). Try moving the transducer cable away from any other cables. I put the cable in a 1/4 " plastic housing up to the point where it was above deck and it stopped all the strange stuff. Not sure about the temp issue??
Posted on Jul 21, 2009
Anonymous
  • 9 Answers
SOURCE: i have asus p4pe x/se and installed a 32bit
Asus doesn't list any windows 7 Drivers for this board and
Broadcom says of the windows 7 Driver for this series:
This driver does not support BCM5700, BCM5701 and BCM5702 devices. To use these devices under Vista, Windows Server 2008, Windows Server 2008 R2, or Windows 7, please use the XP or Win2K3 driver above.
So here is the link to grab the Windows XP/2K3 drivers: Good luck!
http://www.broadcom.com/support/ethernet_nic/netxtreme_desktop.php
Posted on Jan 10, 2010
How to set up overlay data on a touch 7
HDS 7 Gen2 Touch Touchscreen Fishfinder Chartplotter
this is a link so you can download a PDC file of your operators manual.
on your has 7 push the pages button on the upper right hand corner of your unit. Then refer to page 18 of your manual to change your overlay data.
This should get you headed in the right direction.
Aug 01, 2014 | Lowrance 000-10767-001 Hds-9M Gen2 Touch...
HDS Gens Touch shows positive red to negative & black to positive?
Lowrance may have goofed on the manual printing. RED is Positive, Black is negative. All these systems have reverse polarity protection. If you wire backwards, the screen will flash on and then automatically turn off.
I install these systems and I have always put the fuse hlder on the positive line at the battery. The fuse holders are always red wires and that may also lead to some confusion if they suggest attaching that to the black lead.
Hope this answers your question.
Jan 05, 2013 | Lowrance 000-10767-001 Hds-9M Gen2 Touch...
Got a HDS 5 and im getting bad or false on my sonar when traveling showing fish and structure.When trying to hold ground and im backing up it doesn't even read?i have it on auto sensitivity
Check the mounting and cable connection of the transducer on the stern. If loose will tilt during movement, in reverse wakes from the prop. CAREFULLY check unit during these conditions. The transducer needs to be completely submerged. Good Luck.
Jan 13, 2012 | Lowrance HDS 5 X Sonar ()
I have just bought a LSS for my boat .On the transom i have already a transducer for my HDS and also a speed wheel .my question is can i remove the speed wheel and put my side scanner next to the HDS...
well if the side scanner is a stern mount. Then opposite side would be best and scanning away from other transducer. Too much wattage and they will mix signals and give you two blank screens. You can mount together but run one at a time. Aloha
Feb 09, 2018 | Lowrance LSS1 StructureScan Sonar (Lss1...
Trying to figure out how to start up my fuel guage on my Lowrance
You need to purchase a EP 60 fuel flow meter. Once you have it installed in your boat, you need to monitor it. You set it up under NMEA DEVICES on your setup menu,
Jun 18, 2009 | Lowrance Lcx 28c Hd 7" Gps Fish Finder...
May 02, 2009 | Raymarine B60 12 Tilted Element Transducer...
Boating Logo
144 people viewed this question
Top Boating Experts
ray gallant
Moderator Canada
Moderator Canada
Bill Boyd
Are you a Boating Expert? Answer questions, earn points and help others
