We need more info like a mod. number.
If there is nothing running out side check breaker.
I am not familiar with the error code EF
Do you have a multy meter?
Looking forward to hearing from you with that mod. number.
Testimonial: "Thank you.already i solved it....."
SOURCE: model 6312026 Nexxtech 433MHz wireless
Hello, you have to push few second the mode button and after date, hour etc it will be possible to change F for Celsius. He will flashing and after push one of the two button up or down.
Bye from Quebec Canada
SOURCE: Fujitsu mini split outdoor unit not running, but indoor unit is running after turnning on
Check the disconnect switch and make sure that both the fuses are good and not shot. If one is shot then the system wont work. There are two fuse. Also be careful due to you will be working around 210 volts
SOURCE: Acu-Rite indoor outdoor thermometer won't stop periodic beeping
There is no way to turn off beeping. From this site: http://www.chaneyinstruments.com/FAQ.aspx
found solution - search for - Q: My wireless weather station periodically beeps, why?
A: .. unit's ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. .. any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
There is no way to turn off beeping, d/s designers forgot. I had the same problem, another external temp gauge showed up on the other channel, so my neighbor or someone is using the similar unit. MY SOLUTION: opened back of case and cut black wire to piezo speaker (at base if rear cover opposite side of stand-up prop) that creates beep. Don't use any sound features, ALL good now.
SOURCE: indoor unit flashes 5 times. error code meaning?
I have a lg aircon model lsr122v-4 and when I turn it on it stays on for about 2 mins then turns off. Once it's off it flashes a green light 5 times and continues in intervals. What could possible be wrong with it?
Now i solved this problem...,,,
