Question about Sennheiser Audio Players & Recorders
SENNHEISER EW100 G2 wireless microphone RECEIVER with lcd flashing all the time when the power cable is connected. The power button turn off the lcd once is pushed but at the moment the button is released the lcd is flashing again. Besides this the receiver is dead and does nothing. Does any one have any clue to point the failing component? Thanks Regards E.D.R.
Hi Edgar, it is important that the receiver works, because there is a dialogue between the transmitter and the receiver to confirm that they are on the same frequency, that is why the transmitter is blinking, you should repair the receiver and look for the frequency or channel that the transmitter is found and it will stop flashing
Hola Edgar, es importante que el receptor funcione, porque hay un dialogo entre el transmisor y el receptor para confirmar que est?n en la misma frecuencia, por eso es que el transmisor esta titilando, deber?as reparar el receptor y as? buscar la frecuencia o canal que se encuentra el transmisor y este dejara de titilar
Posted on Apr 15, 2019
SOURCE: CORRECT SETUP CODE FOR RECEIVER
Yes...Lets state this more clearly. Does anyone know the code for the Onkyo HT-S790 or HT-SR800?
Posted on Dec 13, 2007
SOURCE: keyboard not responding
Solution. My wireles keyboard stopped working except for the F-Lock key, the Media key and the sleep key. It wasn't batteries, even though I tried, communication was there because the above keys were working. Remove the batteries from your keyboard and let it sit for about 10 minutes. Press the red connect button a few times and other various keys every few minutes during that time. This may be the whole "capacitor discharge" trick, but I tired that with someone elses instructions and my keyboard did not work after 2 minutes of key pressing. I think it just needed more time to clear out the secure settings. Good luck, I was about to trash this keyboard until I tried again
Posted on Jun 26, 2008
SOURCE: Connecting PS3 to receiver via HDMI
First put the orginal ps3 cable onto ps3 then to tv.set tv to see ps3 and go to ps3 setup,now down to display settings,set to hdmi,picture will go off so now switch tv to hdmi input .Next go to sound settings for ps3 and set to hdmi if your amp can work this way ,if not set sound out to optical.
hope this helps.
CABLE GUY.
Posted on Jun 29, 2008
SOURCE: on/off button broken
You should'nt need a scematic, this happens all the time with the ew100 handhelds. you will need to remove the three star bit screws between the screen and the batteries, pull off the end cover and with a small screwdriver or some long needle nose pliers- put the red button back into the hole from the inside of the cover. Just take care when putting the end cover back on- sometimes its a bit difficult.
Goodluck
PTB.
Posted on Apr 02, 2009
SOURCE: ''Power off ''flashes ten times after the receiver is turned on.
Most often it will require an output IC, but I have seen it be a bad ground or a transistor in the protect circuit.
Posted on Oct 16, 2009
Aug 01, 2015 | Sennheiser Audio Players & Recorders
Mar 09, 2014 | Sennheiser Evolution G2 100 Series UHF...
May 22, 2012 | Sennheiser 100/500 G2 Series Wireless...
Jun 18, 2010 | Sennheiser 100/500 G2 Series Wireless...
Jan 13, 2010 | Sennheiser Evolution G2 100 Series UHF...
Nov 06, 2009 | Sennheiser 100/500 G2 Series Wireless...
Jul 06, 2009 | Sennheiser 100/500 G2 Series Wireless...
Mar 31, 2009 | Sennheiser 100/500 G2 Series Wireless...
Mar 01, 2009 | Sennheiser EM100G2 RACK MOUNT G2 RECEIVER...
Feb 15, 2009 | Sennheiser SK 300 G2 Wireless Bodypack...
95 people viewed this question
