Question about Car Audio & Video
Where can i find connecting strips from the face plate to the back motor?
Posted by clyde okuda on
1 Related Answer
kenw392
kenw392
  • 2226 Answers
SOURCE: The motorized face plate only sits at the half-way
the flexible cable that goes from the face to the main motherboard is probably bad and needs to be replaced
Posted on Dec 11, 2009
Kenwood kdc-mp522 face plate goes out when pushing on buttons
Clean the contacts on the back of the face plate and where it connects to the deck.
Mar 17, 2016 | Kenwood Car Audio & Video
How to replace belt on hoover SH40060
You have to remove the roller to get to the belt' look at the face and bottom to find the screws that hold the plate that covers the roller. Take the plate off and look @ the roller, to see where the belt runs. then take the roller out, you should be able to see the pin shaft that comes from the motor,the belt goes around it and over the roller.Be patient putting it all back together,and don't over tighten the screws, they strip easily, Good luck!
Feb 20, 2015 | Hoover Vacuums
Hi, I have a Fisher Paykel DD603I (integrated) dishdrawer unit. The bottom drawer soap dispenser has water in it after it runs (and leftover soap), and there is a small amount of water sitting in the...
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Jan 16, 2011 | Fisher and Paykel Dishwashers
How do I connect the wiring to my igniter switch on a patio 2 Tec grill?
Hi, You will need to remove the front face plate. There are 4 phillips head screws holding the face plate on - one in each corner. Remove the screws wth a #2 phillps head screw driver. Once the face plate is removed you will have access to the orange pilot assembly wire. Simple plug the orange wire into the igniter on the face plate. Bolt the face plate back in place.
With your gas supply off - turn your rotary ignter and make sure there is a spark present at the pilot assembly.
GrillTechs,LLC
[email protected]
Nov 06, 2010 | Tec Patio II Grill
Dec 10, 2009 | Kenwood KRC-X858 Cassette Player
How do you remove the back plate of a GE profile Harmony. I have the screws out, the top off. Does the back plate slide up? Do the sides have to come off with the back? Or what?Please. Thanks
the back plate does not come off.
to get to the motors, belt, sensors...
remove the screws to the inner top cover(under outer cover) and the plastic strips- slide strips front or back to remove.
remove the screws to the front panel- 2 top front, 4 inside door.
as you pull the front off, unhook the light and the door switch
remove the scres to the front drum plate.
reach under drum and unhook belt-take note how it goes around motor and tensioner.
lift drum out and observe everything else.
Jul 30, 2009 | GE Profile Harmony DPGT750EC Electric...
Face plate went out on my pioneer deh 6800mp
There is a fine strip that runs from the face to the circuit board. It is possible that face has gotten dirty just needs a can of compressed air or the circuit board has failed inside the face. The face plate is very easy to take apart and put back together, just make sure you don't lose any pieces ;) Good luck!
Jun 11, 2009 | Pioneer DEH-P6800MP CD Player
Alpine CDA-9830 doesnt want to work
the cda 9830 and 9831 are known to have issues with the face plate connection that cause all kinds of issues. remove the face plate and clean the contacts on the face plate and the unit.
Feb 07, 2009 | Alpine CDA-9830 CD Player
Where to buy face plate at bottom of 1990 corolla shifter
Some Auto Supply stores like Napa carry this and the Dealership Parts Counter has them Also.
Jan 21, 2009 | 1990 Toyota Corolla
Sony CDX-M850MP Remote wont work when front panel closed.
The problem is the flexible wire strip that cracked. I just had the same problem. A guy has them on auction on e bay. Type in model number and flexible replacment for search.
Fix by.
1. Unscrewing 2 the two screws that connect faceplate to motorized flip bracked. One on each side.
2. Unscrew the screws that are connected to the back plate. Plate directly behind faceplate with Blue LED.
3.Unclip backplate by sliding Deck out 1 inch. Two clips on each side.
4.Unclip the waferboard/circuit board from the back plate.
5.Remove Flexible wire band that connects the faceplate to backplate.
6.Attach new flexible wire band to deck then to face.
7. Reclip everything, Rescrew everything.
Whalah it is fixed.
Dec 15, 2008 | Toshiba Sony CDXM850MP CD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
